Question about White Sewing Superlock 2000 ATS Mechanical Sewing Machine
Threads break and look not right
I bought new acme 5 thread serger in jan and can not get it to stop breaking thread,i have 2 other serger no problem with and I us 2 at a sewing class no problem and suggestions
  • new serger Feb 19, 2009
    the needles (especially the right one) come unthreaded almost everytime I do a seam.
    President:
  • 1,902 Answers
Check to make sure the bobbin tension is not to tight
Posted on Feb 14, 2009
The top tread breaks after about 1inch when trying to do chain stich on my janome cover stich machine
Could be the result of several things. There could be some gunk or threads stuck in the tension disk. Be sure to remove the thread and rethread from the beginning in the order specified. ALWAYS RAISE the presser foot when threading!!!! If you haven't tried a brand new needle, do so, and make sure it is pushed all the way up and installed with the flat side facing the correct direction. Some machines recommend #90 as the largest needle to use. Also, perhaps the needle eye is too small to accommodate the thread. Watch where the thread is breaking to give you an idea of where the problem may originate. Try a different brand of thread. Sometimes black thread causes issues because the heavy dye affects the thread. Set the tensions at the midway point and then loosen the tension on that one needle. There could also be a burr or rough spot somewhere along the threadpath that is catching the thread. Last idea--could be a timing issue.
Serger needle thread breaking sewing discussion topic PatternReview com
http://www.amitymama.com/threads/anyone-have-an-idea-why-my-serger-needle-thread-keeps-breaking.280524
Make It Handmade Threading Your Serger or Overlocker
Help please Serger needle thread breaking
Sewing Machine Thread Keeps Breaking
Dec 08, 2016 | Janome Sewing Machines
Have an Toyota 6600 model Serger. The knives won't cut, won't stitch and tread keeps breaking from the right hand needle...
you might want to replace the knives
you might have the serger checked for a timing problem
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
10. If all of the above suggestions don't help then the serger needs to be checked for a timing problem at a sewing machine repair shop.
Nov 05, 2013 | Sewing Machines
I have a bernette 134 and the tread keeps breaking , the lower loop thread , no matter how I set the tension , upper or lower this thread keeps breaking , HELP
10.check in the needle plate area to see if there is a burr
11. Check the looper to see if there is a burr or if it looks damaged
If all of the above suggestions don't help then the serger needs to be checked to see if there is something wrong with the loopers and also see if there is a problem with the tension.
Aug 22, 2013 | Sewing Machines
SERGER HAS BEEN RETHREADED AND HAS A NEW NEEDLE BUT WILL ONLY SERGE FOR ABOUT 1.5 " and THE THREAD BREAKS AND LOWER LOOPER COMES UNTHREADED.
7. Is the thread feeding off the cone/spool freely?
Aug 21, 2013 | Singer 14SH654
Janome 9200d overlocker
Aug 18, 2013 | Sewing Machines
Kenmore serger thread keeps breaking
Mar 26, 2013 | Sewing Machines
Can serger for about 3 inches on my brother 1354d serger and then thread breaks
Jan 01, 2013 | Sewing Machines
My serger will only sew a few inches, then the thread on the lower looper breaks. I have checked threading, rethreaded many times.
Been there, done that. Old serger almost went out the window more than once.
Raise the thread antenna and loopers to their highest positions.
Set the tensions to zero. If your serger has auto-tension, raise the presser foot as this also opens the tensions.
Begin threading from the right as indicated in your manual or on the door of the serger.
If this continues, the serger may need to be serviced as the timing could be the problem.
Ask before leaving the serger as the service cost usually starts around $100.
I finally gave in and bought a Babylock with instant jet-air threading.
Apr 01, 2010 | White Sewing Speedylock 1600 Mechanical...
I have a acme serger 5, brand new. We have threaded it according to the cd, I even had my son do it also, but the one of the bottom loopers thread keep breaking. I bought serger interlock thread. It will...
I will make this easy first always thread the machine upper looper then lower looper then the needles if a thread breaks especially if it was one of the loopers, make sure to pull the needle thread out before hand then rethread. as for the breakages look to see if the loopers are hitting each other when they cross and see if the needles are hitting the loopers when they go together either of these things will cause problems if so it will need to be looked at by a tech
Oct 20, 2009 | Sewing Machines
Brother 1034D
I had the same problem with the blue thread- it would sew and inch then pop- mine worked wihtout breaking after I re threaded in this order: green, blue, red then yellow
Jun 08, 2008 | Brother 1034D Mechanical Sewing Machine
White Sewing Superlock 2000 ATS Mechanical Sewing Machine Logo
93 people viewed this question
Top White Sewing Sewing Machines Experts
Douglas Plant
Douglas Plant
Derek Massey
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
