Question about Frigidaire Dryers
Frigidaire Crown series (FDGB34RGS1) doesn't turn on
Dryer was running and stopped in 5 minutes. does not turn on again. breaker switch is ok
  • 979 Answers
This is more than likely a thermal switch that has gone bad. You will find it located under the top of the dryer. You will need to remove the top and find it at or near the drum. You can bypass it to see if that is the problem. If it is, you can replace it for about 25 dollars. This usually is the problem. If not, let me know back and we can go further.
Posted on Feb 14, 2009
WHY IS DRYER TURNING OFF AND 4 LIGHTS ON PANEL FLASH
Good Morning Friend,
I understand your Frigidaire dryer, model# FEQ1442ES, runs for about 10 minutes then turns off. I also see, that when it turns off, all the lights on the front panel are flashing. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 22, 2014 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire dryer dries for a few seconds then stops and lights blink.
Hi laylabetes - Answering your question, there isn't a way to actually CLEAN the control panel. Depending on an actual diagnose from a professional, the part would need replacing or if possible repair. However, if your model is electric, turns and there is no heat, it could possibly be a blown fuse. There are two house fuses that supply voltage to your dryer circuit in your fuse box. If one of the two is blown, the dryer may turn but will not heat. Check and replace fuse in fuse box if necessary. Please feel free to reconnect if this does not resolve your issue - Best, Chris
Jul 01, 2013 | Frigidaire Dryers
Frigidaire Affinity AEQ6700FSO electric dryer does not heat, then shuts off within 10 minutes.
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
Feb 05, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Frigidaire dryer crown series model #FDEB23SRGS1 will not start
Check the breakers first . Reset both poles even though they may not show tripped. The wiring t the receptacle or plug could be loose. Los check behind it behind the back panel.
Feb 03, 2013 | Frigidaire Dryers
Dryer will not turn on. When I turn the knob, it makes a "buzzing" noise but will not switch on. Was working very well until now. Frigidaire Crown Series. FDEB23RG52
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 05, 2011 | Dryers
Dryer does'nt run. checked breaker, thermal fuse, starter relay, timer stops when door is opened, starts when closed?
2 more things could be wrong,check the blower box to see if you have a thermister thermostat on it,check that with your omns meter,the other thing is the motor is no longer strong enough to turn the drum and it heat up and tips off,let me know what you find-mike
Apr 21, 2009 | Dryers
Squealing dryer
The dryer drum support on the rear of the drum is worn and must be replaced.
It is a ball and cup design. It is worn out.
Feb 21, 2009 | Frigidaire GLER341A Electric Dryer
Whirlpool dryer stops after 5 minutes
Locate the circuit breaker for the dryer. Run the dryer for awhile and with the back of your finger pressed against each of the two switches (it will be a double breaker), see if the breaker is getting warm or wait until the dryer quits then check the breaker for any noticeable increase in temperature. With properly rated breakers, they should not get warm. If getting warm, it is a sign the breaker is bad and should be replaced.
Jun 01, 2008 | Dryers
Drum will not turn
From your description, you may have a bad spot in the armature of the motor, or a faulty centrifugal switch on the motor.
May 24, 2008 | Dryers
Dryers Logo
221 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
