Grundig YB 400PE AM/FM/SW Radio Logo
A
Anonymous Posted on Feb 18, 2013
How to remove back cover on YB400PE - Grundig YB 400PE AM/FM/SW Radio
Geoff Radnor
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 11, 2015
Geoff Radnor
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
627
Points
Did you ever get the Grundig YB400 open? If so please tell me as I can not open mine either!!
Grundig yb400pe stopped workinghow to fix?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
tip
Nokia battery
<b>Remove the back cover</b><br /> Place the phone with the back of the phone facing you. Pull up the back cover from the finger grip at the top of the cover.<br /><br /><b>Note:</b> Always turn off the power, and disconnect the charger and any other device, before removing the cover. <a></a><span>Avoid touching electronic components while changing the cover.</span> Always store and use the device with the cover attached.<br /> <b>Remove the battery</b><br /> After you have removed the back cover, insert your finger into the finger grip, and lift the battery from its compartment.<br /> <b>Replace the battery</b><br /> <ol> <li>Insert the gold-colored contact end of the battery into the battery slot. </li> <li>Push down on the other end of the battery to snap it into place. </li></ol> <b>Replace the back cover</b><br /> Place the back cover on the phone bottom first so that the cover tabs align with the slots in the phone and press the cover moving from the bottom to top until the cover is securely in place.
on Mar 09, 2011 • Cell Phones
How to remove back cover ?
Before you remove the back cover, need to unscrew the nails from the back cover. then remove the keyboard (carefully remove the connector ribbon cable), then the top cover nails, after carefully removing the ribbon cables. Then the screws for the display panel. Remove the nails in the motherboard following the markings of the manufacturer. Finally you can take off the back cover separately as required. This procedure has to be followed and the experience is a must to avoid damages to the equipment. Get some professional advice before proceeding.
2answers
Grundig YB400PE Tuning Failure
I has the same problem, could you fixed it?
Removing back cover of hp dv 6915nr
Back Cover?
1) Display Cover: The plastic cover that is on the opposite side of the LCD screen. Sometimes referred to as Top Cover.
Display Assembly is removed from laptop first, then LCD screen assembly is removed from the Display Cover.
2) Base Enclosure: The plastic bottom part of the notebook.
A laptop is disassembled from the Top down to the Bottom.
The bottom 'cover' (Base Enclosure) is not removed first. It is last.
3) There is no back cover per se. Half of the cover for the back (Bottom half) is part of the Base Enclosure. The top half is part of the Palm Rest.
(The back has the Vent in it)
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
[Use the dv6700 service manual. Go down to the subheading HP Pavilion dm1 (dm1 is in blue)
Scroll to the right, click on dv6700. Note that it is a PDF file, and may take up to 30 seconds, before you see the first page come up ]
What is it you are trying to do? What hardware component are you trying to access?
Post back in a Comment.
Regards,
joecoolvette
Display assembly is removed. Palm Rest Cover is removed, and so on.
1helpful
Wind top AE1900 AIO MS-6638. how to replace hard disk
To remove back leg: pull off round end caps where leg connects to back (pressure fit). Then remove black stickers covering screw holes at base of leg. Under stickers are 4 screws - remove and lift off leg assembly.
Remove back cover: remove 7 black screws from back (one hiding under warranty sticker). Lift back from bottom edge (pressure connections on top edge). Back cover will catch on cd/dvd tray door - bend slightly to get around.
Under back cover is metal cover. Remove screws from around edge holding back cover on (note that most screws you will see in pairs - only remove the one holding the metal cover, not the one holding the chassis). Lift off metal cover.
You should now see hdd. One screw holding in position - remove screw, slide out hdd (it will have a metal frame around it). HDD is a 2.5" laptop style.
Swap out hdd from its frame, then re-assemble.
How do I remove the Laset Unit?
Looking from the front of the printer. Unclip the left hand cover from the back and the right hand cover from the front. At the back you will see four screws holding the back cover on. remove these along with the back cover.Then you'll see two screws at the back holding the grey top cover on, remove these and the one screw at the front . Remove the top grey cover and in the middle of the printer you'll see a black plastic box, this is the scanner.
1helpful
Grundig YB400PE broken antenna
Unfortunately, your description of the problem means that your radio must be taken apart to be fixed. Replacement antennas can be found purchased. It would require installing the new antenna and most likely soldering it to the broken wire. Do you have a picture?
1helpful
Need a manual for YB 400PE
If you are looking for the User Manual, it can be found at:
http://www.scribd.com/doc/9196165/Grundig-YB400PE-World-Receiver-Users-Manual
Also, if you do a Google Search for YB400PE Manual, you will find many choices.
Best regards ... Hope this helps.
1helpful
Disassembly of Gateway 610
Found this - should help you
cosmetic screw covers that cover nothing
"remove this panel so you can remove that panel so you can slide the
carriage holder and unscrew the fenortnor rods."
"Flex the case in the middle and the undercarriage will drop out."
"Slide the front cover a couple inches left and remove screws, then
turn it around and lift the cover one inch to remove third screw."
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
