Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Loud noise our frig is making a loud popping sound about 15 times a day ....what could this be
  • Anonymous Mar 17, 2014
    Frig makes a loud noise
    President:
  • 1,902 Answers
Check the relay on the side of the compressor. Has a metal clip holding it to the compressor. Check with a volt meter and also check the compressor for voltage. no voltage or low at the compressor replace the relay. You can also take the relay off and shake it. If it makes a rattling sound replace it
Posted on Feb 14, 2009
Loud noise then lose picture
The green power LED probably is merely indicating that power is getting to your TV but the internal power supply is failing as evidenced by the loud "pop".
Dec 31, 2013 | Vizio P50HDTV20A 50 in. Plasma HDTV
Refrigerator makes a loud thud every 15 minutes
compressor has a broken spring inside. only way to fix it is replace compressor. call management.
May 07, 2017 | Refrigerators
My frig is making a loud knocking noise it seems to happen all day on and off and coming from the back of frig plz help
the fan that blows cold air from the freezer to cold storeage area , is going to brake .
Feb 18, 2012 | Kenmore Refrigerators
Fridge makes a fairly loud popping noise at intermittent intervals...otherwise works fine and maintains wine temp as set....makes this noise approx 10-15 times a day....unable to determine any set pattern...
What you are hearing is the new refrigerant going through the system. The old Freon 12 did not make that noise but the new stuff does. Nothing to worry about, it is normal. Thank you for using Fix ya and I hope you found this info helpful.
Jun 23, 2011 | Magic Chef MCWC30MCG Compact Wine Cooler
My refrigetator randomly makes a loud popping sound like a fire cracker. I hear it more at night but can't I'm not sure if it's just because the kids are sleeping and the house is quieter. It is a loud pop...
If it's cooling ok, they're probably normal sounds. Modern refrigerators can make many noises, most people aren't home long enough to hear them. A popping sound could be defrost water hitting a hot defrost element, or refrigerant making noise in the cooling lines. If it's working ok, ignore it.
Good luck.......
Jul 27, 2010 | Refrigerators
Loud popping noise?
its just the unit in defrost mode,the popping sound is water hitting the defrost heater and boiling away,no need to worry
May 24, 2010 | Magic Chef CTF2125 Top Freezer...
My refrig occassionally makes a loud "popping" sound. It has been doing this for quite some time. Frig works fine otherwise. Should I be concerned?
The "popping" sound is more than likely to be generated from the defrost cycle that it goes through normally about 3-4 per week at varying times. If all is working well then you should have no worries as this is a normal sound that comes from the expansion of materials when the defrost heaters come on. If this sound is annoying or bothersome, you can have a noise reduction kit installed to help alleviate the sound. You may be able to purchase one at; www.repairclinic.com, or www.appliancepros.com, or from a local dealer/servicer.
Jul 16, 2009 | Maytag Refrigerators
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Frig makes a very loud booming noise/ratteling what is the cause?
The noise is coming from the compressor and is a result of a broken support spring inside the compressor. When the unit shuts down, the inner casing rattles against the outer casing because the spring is not there to keep them apart. The only fix is to replace the compressor but otherwise it is just bothersome.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Refrigerators
Loud Buzzing noise
Sounds like the fan is hitting some ice build-up. If you can access the area of the fan motor you can try a hair dryer to defrost the ice out of it.
Apr 15, 2008 | Frigidaire FRS23R4A Side by Side...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
367 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
