Question about Metrologic Instruments Metrologic MS 9540 Voyager (MK9540-72B41) Handheld
Metrologic ms9540 will not communicate with windows xp
I have not been able to find a driver that is accepted by windows xp. I am using an USB cable connection and all of the software for configuration is looking for a com port.
  • Anonymous Mar 04, 2009
    I have the same problem.I'm using a PS2/USB convertor , but all the scanner is doing is making the default sound.It does not communicate the barcode.
3 Suggested Answers
e-Guru
  • 3917 Answers
SOURCE: we have the metrologic scanpal 2 units and
Hi
Check that the RS232 cable is correctly connected to the host system and to the
ScanPall2 Portable Terminal or to the download cradle.
For transmission using the download cradle, check that the ScanPall2 Portable
Terminal is correctly inserted in its cradle.
Check that the communication settings of the host system match those of the
ScanPall2 Portable Terminal.
Check that the IR transceiver is correctly connected.Check that the communication settings of the host system match those of the ScanPall2 Portable Terminal.Check that the ScanPall2 Portable Terminal is correctly positioned in the IR transceiver read area (a distance of 5 cm to 100 cm, and a maximum angle of 30┬░).
If the problem persists, contact Technical Support.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jan 10, 2011
ginko
  • 19396 Answers
SOURCE: How can I get a replacement user manual for my
Hi.
Please check the files below:
Installation and Users Guide - Resource
metrologic MS9540
Metrologic MS9540 MS7120 USB Default Setting
MS9540 VoyagerCG®
Posted on Jul 14, 2011
What is the proper cable for my MS9540 scanner?
Now Metrologic is under Honeywell AIDC
Voyager 9520 9540 Laser Scanner Hand Held Honeywell
If not mistaken,the USB cable P/N should be MX009-2MA7S
Jul 24, 2014 | Metrologic Instruments MS9540 Voyager...
What kind of cables do I need? my friend says that they are doggles - or something like that
RS232 Barcode Scanner Cable
Handheld scanner cable
Connector: DB9, DB15, RJ45
Cable: PU, PVC, 26AWG, 28AWG...
Application: Computer POS system, Scanner 0R Metrologic Honeywell barcode scanner MS9540 MS5145 USB Cable ???4 Similar from this Supplier Straight USB Cable with chip for Honeywell Metrologic MS5145, MS9540, MS9590, ETC....
May 04, 2011 | Computers & Internet
How do you change the button / trigger in MS9540? I have problem that the trigger in MS9540 sometimes works fine, and some need to press really hard to make it work. The scanner and mainboard seems fine...
hi firstly remove the cover untill you can access the switch ,with a flat headed screw driver or pointy nose plyers prize both clips each side of the switch untill they are just about touching place the cover back and try this should work fine for you now cheers
Mar 18, 2011 | Honeywell Metrologic (E64392) VoyagerCG...
Fail to configure metrologic usb barcode scanner to use virtual RS232 port interface
First check the com port speed of computer port which you connected scanner .Com port speed should be 9600.
To change com port speed in computer go to computer/properties/device manager.
Select the ports eg com1 .Right click communication port go to properties and select port settings Bits per second should be 9600.
Serial scanner can not be test in word or note pad.you can download the RS232 software from below link and test the scanner
http://www.lookrs232.com/
Oct 30, 2008 | Metrologic Instruments MK9540...
MY METROLOGIC BAR CODE
What Is The Communication Method You used, usb or Kbw,
Aug 06, 2008 | Metrologic Instruments Metrologic Barcode...
Connecting Problems with Metrologic MS9535 BT
hi
that you have cable usb?rs232?ps2?
You have the power adapter?
you have windows xp?
is not difficult
May 20, 2008 | Metrologic Instruments MS9535 VoyagerBT...
Metrologic Instruments Metrologic MS 9540 Voyager (MK9540-72B41) Handheld Logo
1,341 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
