Question about Panasonic PT-51HX41 51" Rear Projection Television
Lines on the screen
Everytime I turn on the TV lines appear. After if warms up the lines start to fade. I have had the TV for eights years. We have an HD box connected to it, but that doesn't help.
    Novelist:
  • 184 Answers
Are they thin, white lines running east to west? If so, they are called retrace lines and indicate that the screen settings for the picture tubes is set too high or there may be a mal-function of the CRT driver circuitry. Try adjusting the screen controls which are located behind the front grill of the TV behind an access panel. Once you remove the grill and access panel, you'll see a small control assembly the has two sets of controls. Three for adjusting the red, green, and blue focus, the other, the red, blue, and green screen controls. To adjust correctly, put the TV on an unused input(dark, blank picture) and adjust until there are no visable retrace lines or color in the image.
michtech
Posted on Feb 14, 2009
I have a 55 inch vizio flat screen. it turns on but the screen fades away.
//If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 22, 2014 | Sanyo DP50747 50 in. Plasma TV
White vertical lines like jail bars
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 26, 2017 | Samsung HLN5065W 50" Rear Projection...
Display fade out
replace bad inverter board for screen back light.
Sep 03, 2012 | Polaroid 3211TLXB 32 in. LCD Television
Acer aspire 5738 screen fade
From your description, you may either have a bad cable to the LCD on your laptop or the LCD screen itself is going bad. I would guess a repair shop may charge $100-200 for the parts and labor, but you'll have to check your local area for price estimates.
Since your computer is nearly 3 years old, you may want to consider purchasing a new computer, especially since they start at $300-500 brand new.
May 19, 2017 | Computers & Internet
Laptop screen fading in streaks
this thing happened in my laptop also i got green screen fully
then when i hit it behind the screen it was gone but comes many times then again i would hit
later on the screen was completly lost then had to replace the screen
yous is a starting period so go to a nearby computer service and fix the screen
May 27, 2009 | Compaq Presario M2000 Notebook
HL-P5063W Green lines when the tv warms up
My Samsung DLP is having the same problem.  Not sure what to do, but I will contact my warranty place for the second time.  Hopefully they'll fix it.  Any other suggestions?
Mar 23, 2008 | Samsung DLP HL-P5663W 56" TV
Vertical Black bar on the screen
What is the model number it sounds like pixel problems or board problems. For more info ctechnicians.com
Jan 06, 2008 | Televison & Video
The TV turns on and you can hear the sound but the picture is dark except for a thin line of blue dots in the center of the screen.
You have whats known in the biz as a cold solder connection on the vertical output IC or on the associated components. Not a job for the handi-man unless you know the issues with safty, and precautions to take with Hi voltage inside of tv sets. Shouldnrt cost much for the local shop to find your problem . Now on rare occations the poor connections are inside the IC and the IC has to be replaced. Good Luck
Jun 17, 2006 | Panasonic CT-25G6 25" TV
Panasonic PT-51HX41 51" Rear Projection Television Logo
261 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
