Question about Uniden BC60XLT Handheld Scanner
L/O is on all channels cant program with L/O on it
Cant program scanner due to L/O on all channels
    Problem Solver:
  • 6 Answers
Push manual then hold down lock 0ut button for several seconds this should unlock all
Posted on Feb 16, 2009
2 Suggested Answers
  • 4 Answers
SOURCE: bc92xlt scanner
Press hold and keep pressing hold until you get to the selected chanel and press (F) and (E) then program the frequency in and press (E) then press (E) again and repeat the steps until all are programed in the press scan.
Cheers Shane
www.rochedalescan.com
Posted on Nov 28, 2008
I cant get my bc60xlt to program any codes. the chanels dont have any codes programed in them. the screen shows the channel number and the L/O .
That means your scanner has lost its programs...It has lost its memory memory loss when you program a frequencie in it the L/O will go away....
Jun 17, 2011 | Uniden BC60XLT-1 Handheld Scanner
Cant get know help to program my scanner
Programming the BC60XLT is simple and straightforward:
- Select the frequency to program.
- Select the channel that you wish to program it into. You can press MAN and the channel number, followed by MAN, or just repeatedly press MAN until the desired channel is displayed.
- Enter the frequency, including decimal point (for example, 156.065). The decimal will display as a dash.
- Press E. The frequency is now programmed into the scanner memory, and you can repeat the process to program any channel.
For more information on your scanner, you can download/print the operating manual here:
http://www.uniden.com/pdf/BC60XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
Apr 25, 2010 | Uniden BC60XLT Handheld Scanner
Need user manual for Uniden radio/scanner BC60xlt-1.
Follow the link below to download/print the manual for your scanner. You may or may not be able to hear the services you mentioned using this scanner due to its limited frequency coverage. Many public service agencies now transmit in the 800MHz range, and many have upgraded to trunked and even digital radio systems. I cannot find any reference to PCH LOCK, but an educated guess would be that it means all programmed channels are locked out. If none of the 10 channels contain programmed frequencies, displays will show 000.0000MHz, and all channels will be locked out. Programming a frequency into any channel should override the lockout. On the other hand, the message could indicate that this old scanner is tired and in need of replacement. Here's the link to your manual:
Jan 03, 2010 | Uniden BC60XLT-1 Handheld Scanner
Cant get off lockout
If a channel does not have a frequency programmed into it, it will display 000.0000 and the L/O icon. Programming a frequency into the channel will automatically release the lockout.
To release lockout from a single channel, select that channel and then press the L/O key.
To unlock all programmed channels, select all frequency to ON, then press and hold the L/O key until the scanner responds with 2 beeps.
For a full reset of the scanner, press and hold the 2, 9, and HOLD keys while powering up the scanner. The reset will take about 3 seconds, and will be confirmed with a display of CLEAr. NOTE: this will reset the scanner to its original factory settings, and will delete everything that you've programmed into it.
Need the manual? You can download/print it here:
http://www.uniden.com/pdf/BC72XLTom.pdf
I hope this helps. Please contact us again if you have any other scanner problems.
BillB
Dec 24, 2009 | Uniden BC72XLT Handheld Scanner
I have a uniden bearcat portable and base I cant figure out how to program it
With the scanner powered ON,
1. Press [HOLD].
“HOLD” appears on the
display.
2. Press [PROG]. CH appears
and blinks to indicate that you
are in the Programming Mode.
To change the displayed frequency,
use [UP] or [DOWN]
while “CH” is blinking.
3. Press [PRIVATE]. “PRIVATE”
appears on the display.
If you want to program it into
another bank, press the
desired bank key. The lowest
open channel appears on the
display.
2 screens alternate to indicate
that open channel is available
to be programmed.
The scanner automatically
selects the lowest open
channel (000.0000) for easy
programming. If all channels
have been programmed (there
are no open channels in the
bank), channel 1 appears.
Use [UP] or [DOWN] to select
a new channel and even overwrite
old channels.
4. Press [PROG] to store the
frequency in the desired
channel.
Note: Press [BAND] to escape
from programming mode before
step 4.
http://www.uniden.com/pdf/BC350Com.pdf
Oct 01, 2009 | Uniden BC350 Base Scanner
Cant program my scanner
first turn it on, then press manual (might be labled man),the type in the channel you want to enter a frequency into and press manual again. next if there is a pgm or program button press it, if it has no program button just type in the frequency you wish to put into that channel. now press enter. repeat this process for each channel you wish to program.
Jan 15, 2009 | Uniden BC72XLT Handheld Scanner
Bc92xlt scanner
Cheers Shane
May 11, 2008 | Uniden BC92XLT Handheld Scanner
Programming Bearcat BC 55XLT Scanner
Ok doc, I'll see if I can walk you thru this as there don't seem to be a manual available for download.
* Push manual button and bring it around to channel #1
Enter the freq including the decimal point. Push the E button to enter the freq into the first channel.
* Push manual again and move to channel #2 and repeat.
If you need some new freq's for your area, go here, click on your state, county, and it'll give you a complete rundown.
http://www.radioreference.com/apps/db/
If you need 10 codes for your area, go here and click on your state.
http://www.nat-com.org/radio.htm
If you need anything else, let us know,, Mechanic
Feb 19, 2008 | Radio Communications
Realistic hyperscan400 channel
cant get channel codes for my uniden hand held
Nov 13, 2007 | Uniden BC60XLT Handheld Scanner
Uniden BC60XLT Handheld Scanner Logo
115 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
