Question about Samsung DVD-VR357
What channel does tv need to be on to play dvd's
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Depending on where you are and the standards/connections used, it could be:
  • Channel 3 or 4 (if using a single coaxial patch cord);
Other connection possibilities are:
  • AV, Video 1, AUX, Line 1 (if using composite yellow red & white RCA to RCA cables);
  • Component (if using component Y, Pb, Pr, red & white RCA to RCA cables).
  • SCART;
  • HDMI;
  • S-Video.
Perhaps you could post back what is used, what connectors are available at the rear of both the DVD player/TV.
Good luck and thank you for using FixYa.
Posted on Feb 14, 2009
Why can't I play DVD's on my AWA 46" LED LCD TV LE4603-05?
Have you seen an AV input selector on your TV or remote?
Have you start playing the DVD and run a channel scan to see if it comes across it, if so, store the channel that the TV finds.
Are you using correct cable?
Jul 21, 2014 | Televison & Video
Connecting up Digital TV, DVD recorder and VCR
You need to hook the VCR and the DVD recorder to the scart connections on your TV.
VCR to one scart on the TV
DVD recorder to the other scart on your TV
Jan 31, 2008 | Televison & Video
I cannot get the Vcr/ Dvd to play
The TV needs to be on channel 3 not channel 3.1 because is a digital channel and the signal from the VCR is analog. Tune the TV to channel 3 to get the analog video from the VCR.
May 10, 2010 | Toshiba SD-V295
Can't find dvd channel on my tv...
hi does your dvd player have scart lead connection if yes select av1 or ext1 thanks
shaun
Mar 06, 2017 | Zenith SY2569X TV
Cannot get dvd to play on tv, no picture, try different channels, etc.,
on you tv must be a button "video/tv",you have to push this many times to find front, back or video1 or video2 (depent were you plug the dvd)and there is were supost to work. no on channel 3 or 4
Oct 21, 2008 | Disney DTD1363-CAR 13" TV/DVD
Video channel
if your DVD player supports a HDMI cable a single cable is enough for both audio and video channel.
but both your player and TV must support HDMI.
Aug 12, 2008 | Samsung DVD-V4600 DVD Player/VCR
Can't get to "Video 1" to play DVDs
try turning your dvd player on and then doing a channel search if that does not work just buy a RF modulator and hook up your dvd player to it and it will run on channel 3 or 4 and will switch over by itself when you turn on your dvd player
Feb 26, 2008 | Emerson EWF2703 27" TV
Am I connecting DVD player wrong?
on some of these older RCA try simply tuning it from the remote down to chanel 01 or 00 this may work. if not you have to go into the setup menu of this set and enable the aux inputs
Feb 19, 2008 | GE 25GT240 25" TV
New dvd/vhs player but old tv
The easiest thing to do would be get a new TV plain and simple sounds as if you could use one n e ways. But first make sure you are hooked up through coaxal to the tv that will allow everything to run on channel 3. Let me know your current hookup.
Dec 24, 2007 | Televison & Video
Unable to locat and select the AV channel on new LCD HD TV
Hi, try switching your tv to channel 3 or 4 and see if that works- there should be a switch on the back of your DVD player beside the Coaxial Cable outputs-it will allow you to use Channel 3 or 4 as the default to play dvd's. I hope that helps-if more detail or wiring diagram is needed-please leave make and model numbers and i'll try to help.
Cheers and have a Happy Holiday Season!
Dec 21, 2007 | Televison & Video
Samsung DVD-VR357 Logo
1,588 people viewed this question
Henry  Thomas
Henry Thomas
