Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
Can't reset the voice message
My 10month old grandson changed my voice message. I can't figure out how to change it back
    Problem Solver:
  • 5 Answers
Press and hold the greeting button then you will here a beep then the machine will say record your message after you have finished push the greeting button and your greeting will play back
Posted on Feb 23, 2009
What does OGA stand for
Hello, I`ve tried to change the voice message on my phone and I hear the new message, when I play it back but if I call, the old message is still on. Also I`ve tried to desactivate the information and now the only message I hear is "Please leave a message" even though I still hear the old message true a call. Thanks for your input. This is a commercial phone so need to be reset asap!
Mar 22, 2014 | RCA 25250RE1 2-Line Cordless Phone
Furby boom voice changed
I think you could reset him he may change a little or hold his young sensor and pull his tail to 2 to 3 seconds
Dec 26, 2013 | Tiger Electronics FURBY Interactive...
I purchased the 16 inch Ultimate Buzz Lightyear for my grandson, and it seemed to work fine, but all of a sudden he quit speaking. His lips continue to move, but no voice is coming out. We have changed...
We had the same problem - sound got quieter and quieter until Buzz was mute. My husband gave Buzz a sharp whack on his back where the AAA battery compartment is located and Voila - Buzz is speaking again.
Jun 08, 2011 | Disney Pre-Order Ultimate Programmable...
We have a old message for after hours calls and can't figure out how to change it.
I assume that your message is on Voice mail, if this is the case , dial into the VM via the night VM key (where the night messages are stored), enter the passcode then dial 0 - 5 - 7 then 3, record the new message then press the # key to store, hopefully this will help, I've sent a clip from http://www.abbeytelecom.com .
Feb 28, 2011 | Samsung Prostar DCS Phone
Voice mail message will not change
Press the table button then enter in table 1
Jun 25, 2010 | NorStar Meridian M7310 Phone
How to set a speed dial and delate old speed dial no
Just figured this out (though a lot of people seem to have tried giving an answer without seeing if it works.
Setting speed dial numbers doesn't allow you to choose one for the voice mailbox. Go to Messages -> Voice Mailbox Number (option 12). There you can change the number.
May 21, 2009 | Nokia 1100
Accidentially deleted 3 saved messages from grandson
Sorry for such a late reply. I just saw your question.
You can recover deleted messages with the help of USB SIM card reader. For more info, please revert back.
Regards
Nov 09, 2008 | Lucent 1872 Corded Phone
Message tones and vibrate facillity
To change the vibrate function:Go to main menu, phone settings, phone profiles, highlight the 'normal' one & press the 'options' soft key to the left of the touch screen keypad. Pick 'edit', then the 'call alert type' will be highlighted. Press the left soft key saying 'options' & select 'change'. You can then opt for it to vibrate by highlighting the vibration one & pressing the tick on the touch screen bit. Then don't forget to save the changes!
To Change the ringtone:
  1. From the standby screen, press Menu (Figure 1).
  2. In the main Menu, press Settings (Figure 2).
  3. In the Settings menu, select Phone profiles and press (Figure 3).
  4. You will be presented with a list of phone profiles for different situations and environments. The one you're currently using will be ticked. Highlight the one you want to use (in our example, Normal) and press the Edit button at the bottom of the display (Figure 4).
  5. You are taken into the profile settings (Figure 5). At the top of the list you'll notice three tab icons - these represent (from left to right), ringtone, message alert, and keypad sounds. You can switch between settings for these by tapping one of the tabs.
  6. You should be taken first into the ringtone settings list. Should you want to change the Call alert type (from melody to vibration then melody, for instance) tap this option and scroll through the list of options to choose the one you want.
  7. To change the Voice call ringtone, tap this option on the screen. You will be taken into a list of phone file folders from which to choose your ringtone (Figure 6). You can tab across to view files stored on a memory card, if you have one installed.
  8. Press the Sounds option. You now have the choice of choosing from yourMusic files, Ringtones that are loaded onto the phone, or My voice clips(clips you have recorded) (Figure 7). You can select from whichever of these folders you want - the setting procedure is the same for each. In our example, we'll choose from our Music folder to select one of our tunes as the new ringtone.
  9. Press the Music option. A list of tracks appears (Figure 8). Tap the one you want in order to highlight it (Figure 9). Press Options, then tap on theSelect menu option to install it as your ringtone (Figure 10).
  10. You are now taken back to the Normal profile settings, where the Voice call ringtone has changed (Figure 11). To save this change, press Options and then Save (Figure 12). Alternatively, press Back and you will be asked whether you want to Save?. Press Yes.
In the ringtone settings menu, you can also change the video call ringtone (which is lower down the menu) by following the same procedure.
Aug 27, 2008 | Samsung U900 Soul Cellular Phone
Changing message on Comdial Impact Telephone
Sounds like you are trying to change a voice mail recording. Your Comdial phone can be used on several different Comdial phone systems and with several different voice mail systems that all program and set up differently. Do you have any manuals or instructions for your voice mail system? If not, you will need to find out which voice mail you have and try to locate manuals.
To change main greetings, etc.. you would need administrative rights to the voice mail. There will probably be a password, hopefully you know it or it's still at default.
Nov 28, 2007 | Comdial 8324S-PT Corded Phone
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
168 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
