Question about Sub-Zero 695/S Side by Side Refrigerator
No water for my sub zero ice maker system 532
I can hear the ice maker turning but there is no water coming into the tray, thus no ice cubes! I've defrosted for 2 days to make sure the line wasn't frozen up, and I'd like to check the water filter line but I'm not sure were it is located. Any help would be appreciated!
    President:
  • 1,902 Answers
Check in two places either behind the fridge or under the cabnit where the water supply is. If not there then check up underneath th back of the fridge
Posted on Feb 14, 2009
2 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: 532 sub zero evaporation tray is filling up with a
This is only normal in an environment of high humidity. My question is the condenser fan blowing over the condensate pan and is the air hot enough to evaporate the water that is in the pan? Has covers been removed on the rear of the refrigerator that may cause a different flow of air. Are all covers in there correct place and not missing panels that could change the flow of air over the pan? Let me know, Thanks, Sea Breeze
Posted on Aug 26, 2009
My Sub-Zero 561 ice maker works fine however when it dumps ice into the tray and fills back up with water, the water pours out on the right side and into the ice tray. any suggestions
I had the same thing - turns out the wife tried to put a wine bottle in to the ice tray to chill it - in turn it had pushed the water pipe back a little too far and so was causing water to spill out - see if you can pull the pipe forward a little - you will need to remove the ice cube bin - and get in to a funny angle to get to it -but its do-able.
good luck
Aug 28, 2010 | Sub-Zero 650 / O Bottom Freezer...
Our model 532 keeps over filling the ice maker causing a build up on the back and down all of the drawer. We can turn it off and thaw the entire box and the water keeps filling the tray even though the ice...
The fill valve for the ice maker could be stuck partially open and dripping into the ice maker. If this is the case shut off the water line to the ice maker and if the water stops you will need to replace the ice maker fill vavle
Aug 10, 2009 | Sub-Zero Freezers
Ice Maker not discharging properly
you will need a new icemaker the mold is not releasing the cubes
Jun 07, 2009 | Sub-Zero 632 / S
In door water and ice cube not working
Water dispenser is a simple touch switch in door energizing a solenoid water valve behind ventilation grate above refrigerator. Water tube runs down into and ends at ice dispenser chute. Should hear solenoid click at top of fridge when activate water touch switch. Can unhook discharge side of solenoid valve temporarily to prove water output. If water dispenser tube acts blocked it could be frozen where it ends-look up the hole at the bottom of refrigerator control buttons.
Ice maker is totally different system. No clicking when push ice button but ice in bulk tray may mean the simplest of malfunctions: Ice bin not pushed in the last half inch if ice auger not lined up with drive pegs. There are hidden switches behind ice bin that need to be engaged or nothing will happen in the ice maker: no auger noise, no clicking, no new ice making. Ice bin will be flush with sheet metal if it is in the right spot. Also plastic juice rack won't hang properly if ice bin not pushed in all the way.
Dec 19, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 632 Ice Maker Leaking into Ice Bucket
Ice Maker is overflowing and leaking into the ice bucket: There are several things to check for.
Go for the easy stuff first, make sure the icemaker is level, some of the plastic liner fridge's will move and allow the icemaker to tilt over and leak. Other troublemakers..... the fill valve
staying on and over filling the icemaker..... the finish sometimes comes off the icemaker body and all the ice cubes don't come out. This will allow the new water to fill on top of an icemaker
that still has a ice cube or two left inside the body, if you have had trouble with black specs in your ice cubes, this may have been the beginning of your finish problem on the icemaker body.
On the module style ice makers (Whirlpool, Maytag Family, Sub Zero) the printed circuit in the
module head often wears and the contacts become too long and allow the icemaker to over fill = new ice maker or new module head.
Older style icemakers: This gear is bad for breaking and the icemaker quits turning to eject the ice.
You can remove the front cover to see the gear.
This is a common parts breakdown of the older style icemakers
Water fill volume: The water fill adjustment screw will change the fill volumes by changing the fill time.
One half to one full turn usually ( approx ) is equal to 20cc ( 0.68oz ) to 40 cc.
The correct fill is usually 130 to 150 cc ( 4.5 to 5.0 oz ).
When a water valve is replaced the fill volumes must be re-checked!
http://www.SubZeroLosAngeles.com
________________________________________
Sub-Zero Service Experts in LA Metro
Aug 15, 2008 | Sub-Zero 632 / S
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Ice maker leaking
what is the model number of this fridge?
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
May 19, 2008 | Sub-Zero 632 / S
Sub Zero 532 Freezer Not Making Ice
These all sound like there is no water coming into the ice trays. The main water valve where the water feed line comes into the unit is probably plugged or not working at all. The solinoid may not be opening the valve..If you can operate a voltohm meter then test the solinoid coil to see that it is good by seeing an ohm reading below 1000 ohms. Also if you are crafty enough you could unplug the wires from it and connect 110vac directly to the solinoid coil to see if it clicks and lets water run in.. Also be sure the water is coming to the solinoid...If water is coming to it and the solinoid is letting water go through when fed directly with 110vac the problem is in the control circuit that operates the ice maker.
That problem would be on the Ice maker itself...
Jan 05, 2008 | Sub-Zero 632 / S
Sub zero 532 ice maker
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
Nov 21, 2007 | Sub-Zero 632 / S
Refrigerators Logo
587 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
