Question about Kenmore 15516 Mechanical Sewing Machine
Can't tighten clutch on Kenmore zig zag sewing machine.
Oiled machine, filled bobbins on my Kenmore zig zag sewing machine. Can't tighten clutch. When moved forward, needle moves up and down instead of moving with the hand wheel, causing the machine not to sew.
  • 4 more comments
  • Anonymous Mar 15, 2014
    sewing machine belt turns but needle doesn't go up and down
  • Anonymous Mar 25, 2014
    the overlocker is dificult to move and makes a noise will only move by hand and not easy
    Needle goes up and down when filling a bobbin
  • Anonymous Mar 26, 2014
    stopped moving up and down stuck or very stiff, ive been sewing already today
  • Anonymous Mar 27, 2014
    the belt doesn't move. How do I change the belt? this machine has been in storage for years. I oiled it, wiped out very little lint and it sewed a nice stitch for a few minutes then the belt stopped turning. the motor and motor pulley turns but it's not moving the belt, the belt is tight and it will turn when I turn the hand wheel but not when the motor is running. Could I have possibly gotten oil on the pulley and that is causing the pulley not to grasp the belt? But why would it turn it without the motor running? What do I do? Change the belt? If so how do I do that?
  • Anonymous Mar 29, 2014
    Kenmore 15008 Clutch is jammed, no bobbin problem, motor works but wheel does not turn when engaged. What part is likely to be seized and how do I get to it? Is there an adjustment or possible release needed?
  • 323 Answers
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
How can i find a manual for a universal sewing machine kzm 022951
Universal Sewing Machine Product Support ...
www.manualsonline.com/support/universal/sewing-machine/
Just aquired a universal sewing machine model Kzm. Universal Sewing ... Needmanual for Universal AZZ Super Zig Zag sewing machine. Universal Sewing ...
Universal Zig-Zag Deluxe sewing machine w/ manual ...
? 4:06
www.youtube.com/watch?v=ZWmBB6za9-s
Oct 28, 2013 - Uploaded by hindsight80
Universal Zig-Zag Deluxe sewing machine w/ manual. I just cleaned and oiled it it is ready to go. Awesome ..
Nov 05, 2015 | Sewing Machines
Kenmore model 158.1789280 needs a new zig zag guide. Can't find one doing an online search.
Sad but when NO LONGER MADE there is nothing we can do to assist , I guess you have a straight stitcher only now ,SORRY
Sep 27, 2015 | Kenmore Sewing Machines
Clutch of Kenmore 1311 zig zag sewing machine won't disengage-how can I resolve?
Have you oiled it? Often can get even *very* old machines to loosen up with a good oiling and cleaning.
Nov 20, 2014 | Kenmore Sewing Machines
My Kenmore 19233 refuses to zig zag stitch past 2mm wide. At 2mm it is a reliable stitch, moving toward 7mm it is a straight stitch with one or two zig zag blips.
Do you have it on zig zag or maybe it is in one of the hem stitches. Make sure you have not selected a special stitch. Sometimes with a small width setting it looks like no zig zag, then when you increase the length you see it is not.
Oct 20, 2014 | Kenmore 19233 Computerized Sewing Machine
Sews straight when on zigzag
it's possible the zig zag gear or cam could be worn or damaged
and the machine should be checked to see for sure what's happened.
Nov 29, 2012 | Sewing Machines
Singer stylist 7258, will only pick up bobbin on one side when doing zigzag stitch
try using a washable stablizer or interfacing.
if that doesn't help then it's possible that a gear or cam may be worn enough to cause the machine zig zag not to work properly
Mar 27, 2012 | Singer 7258 Sewing Machine
Bobbin winder will not spin on sewing machine
If you take the top off you will see a tiny rubber tire that engages the winder to the handwheel. Over time they get really soft are really hard and disintgrate. If you have a local sewing shop take the old one in and get a new one to slip on it takes only a few minutes and cost usually less that $2.00
Jan 20, 2010 | Sewing Machines
Tension underside looks good, but top side the bobbin thread show
sometimes when you reset the top tension dont forget to reset the bobbin tension so try to tighten the bobbin tension
Nov 08, 2009 | Kenmore Sewing Machines
Bobbin wont catch
Try flipping the bobbin. The thread must come off in a certain direction to work properly.
Jan 23, 2009 | Kenmore 15218 Mechanical Sewing Machine
Kenmore 15516 Mechanical Sewing Machine Logo
1,398 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
