Question about Apple iPod shuffle MP3 Player
Ipod not getting chargedand not responding
My apple ipod shuffle which ipurchased one year back was not charging and responding,when i connect to the computer usb dock it used to respond previously and getcharged but recently it is not responding and not even showing in itunes i even downloaded the latest itunes setup but no use plz solve my problem
    President:
  • 2,559 Answers
Either the usb cord is bad or the battery needs replacing.
Posted on Feb 14, 2009
NEED INSTRUCTION FOR Apple iPod shuffle 3rd Generation Silver
Connect the iPod shuffle USB cable connector into a high-power USB port on your computer.
Note: To charge an iPod shuffle battery, connect the device to a high-power USB port.
Please be aware that USB keyboards and non-powered USB hubs generally do not have high-power USB ports.
If you connect to a low or non-powered port, iPod shuffle will not charge.
The computer must be turned on and set to not go to sleep.
Plug the other end of the iPod shuffle USB Cable into the headphone port on the iPod shuffle.
Verify the iPod shuffle is connected securely.
Once the iPod shuffle is plugged in, it will take about 2 hours to charge the battery to 80% capacity and about 3 hours to charge it to 100%.
Find out how to check the battery charge here
hope this helps
Sep 18, 2012 | Apple iPod shuffle 3rd Generation MP3...
How to recharge the Apple iPod Shuffle Silver MP3 Player
According to the manual found here: http://manuals.info.apple.com/en/ipodshuffleuserguide.pdf
"Remove the USB cap and connect iPod shuffle to a high-power USB port on your
computer. The battery status light on the back of iPod shuffle turns on.
The iPod shuffle battery is 80-percent charged in about two hours, and fully charged in
about four hours.
When the battery is charging, the iPod shuffle status light is amber. When the battery is
fully charged, the light is green until you disconnect iPod shuffle. If you don't see the
status light, try another USB port on your computer"
Batteries also wear out from time to time, so if you find that it's not charging no matter what you do, it's likely that you need a new battery. Here's a link to more info on iPod batteries: http://www.apple.com/batteries/ipods.html
May 10, 2011 | Apple iPod shuffle MP3 Player
How do I re charge battery with electrical plug
To charge the battery using your computer:
Connect iPod shuffle to a high-power USB port on your computer using the included iPod shuffle Dock. The computer must be turned on and not in sleep mode (some models of Macintosh can charge iPod shuffle while in sleep mode). When the battery is charging, the status light on iPod shuffle is orange. When the battery is fully charged, the status light turns green.
If you don't see the status light, iPod shuffle might not be connected to a high-power USB port. Try another USB port on your computer.
To charge the battery using an iPod USB Power Adapter If you do not have then you have to buy the same from Apple Store) 1 Connect the AC plug adapter to the power adapter (they might already be connected). 2 Plug the USB connector of the iPod shuffle Dock into the power adapter. 3 Plug the power adapter into a working electrical outlet. 4 Put iPod shuffle in the dock. You can disconnect and use iPod shuffle before it is fully charged.
Apr 05, 2011 | Apple iPod shuffle MP3 Player
Hi my apple ipod shuffle 1g wont charge.. or play songs
You are supposed to transfer songs usin itunes....simple drag and drop doesnt work.... You can download itunes from www.apple.com\itunes
If you are already using itunes,perform a restore on the ipod using itunes...you will find restore option under the summary tab in itunes.
Sep 29, 2009 | Apple iPod shuffle MP3 Player
Cannot get my shuffle to charge.
Please rate this a fixya
Jan 25, 2009 | Apple iPod shuffle MP3 Player
My iPod shuffle will not charge
If iPod shuffle won’t turn on or respond
â If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
â Connect iPod shuffle to a high-power USB port on your computer. Your iPod shuffle
battery may need to be recharged.
â Turn iPod shuffle off, wait five seconds, and then turn it on again.
â You may need to restore iPod shuffle software. See “Updating and Restoring
iPod shuffle Software” on page 26.
Jun 25, 2008 | Apple iPod shuffle MP3 Player
IPod shuffle 1st gen. Not Recognized By PC
Try a different USB port first. Here are some other suggestions:
Connect iPod shuffle to a high-power USB port on your computer. iPod shuffle may
â Make sure you have installed the latest iTunes software from
www.apple.com/ipod/start.
â Try connecting to a different USB port on your computer. Make sure iPod shuffle is
firmly seated in the dock. Make sure the USB connector is oriented correctly. It can be
inserted only one way.
â iPod shuffle might need to be reset. Turn iPod shuffle off, wait five seconds, and then
turn it back on again.
â If there is no status light (or the status light is dimmed) and iPod shuffle doesn’t
appear in iTunes or the Finder, the battery may be completely discharged. Let
iPod shuffle charge for several minutes to see if it comes back to life.
â Make sure you have the required computer and software. See “If you want to doublecheck
the system requirements” on page 25.
â Try restarting your computer.
â If none of the previous suggestions solves the problem, you might need to restore
iPod software. See “Updating and Restoring iPod shuffle Software” on page 26.
â If restoring iPod shuffle doesn’t solve the problem, iPod shuffle may need to be
repaired. You can arrange for service on the iPod shuffle Service & Support website at
www.apple.com/support/ipodshuffle/service.
Jun 09, 2008 | Apple iPod shuffle MP3 Player
IPOD Shuffle (the tiny silver one) won't charge
Is the IPod able to be recognized on the computer? If not, you could try the 5 R's,
Reset
Retry
Restart
Reinstall
Restore
You could also try to restore the ipod back to factory defaults and see if that would help
Nov 03, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Cant get shuffle to work when not conected to pc
How long have you had the unit? If it's been a year and a half or 2 years your battery needs to be replaced. They loose their ability to retain a charge in that time frame, and when you test a good battery or a bad battery they will both read 3.6v as a tester does not put a load on the battery, meaning you have 3.6v when the unit is off but when it turns on (load) it drops to zero. You could also try resseting the unit, to do so follow these instructions. To reset iPod shuffle: Disconnect iPod shuffle from the computer (if connected). Move the switch on the back of iPod shuffle to the off position. Tip: When iPod shuffle is off, the green stripe by the switch is not visible. Wait 5 seconds. Move the switch on the back to the play in order or the shuffle position. The green stripe will be visible in either position. iPod shuffle is now reset. If after resetting iPod shuffle you are going to attach it to your computer, be sure to place the switch in the off position. If you were resetting as part of some troubleshooting steps, continue with those steps now. For general troubleshooting steps see the iPod shuffle troubleshooting and service FAQ. To reset iPod shuffle: Disconnect iPod shuffle from the computer (if connected). Move the switch on the back of iPod shuffle to the off position. Tip: When iPod shuffle is off, the green stripe by the switch is not visible. 1st generation 2nd generation Wait 5 seconds. Move the switch on the back to the play in order or the shuffle position. The green stripe will be visible in either position. iPod shuffle is now reset. If after resetting iPod shuffle you are going to attach it to your computer, be sure to place the switch in the off position. If you were resetting as part of some troubleshooting steps, continue with those steps now. For general troubleshooting steps see the iPod shuffle troubleshooting and service FAQ. http://docs.info.apple.com/article.html?artnum=302110 Hope this helps.
Sep 15, 2007 | Apple iPod shuffle MP3 Player
Apple iPod shuffle MP3 Player Logo
589 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
