Question about Dell 924 All-in-One InkJet Printer
Photo 924 keeps saying alignment problem. please remove tape from
Replaced color cartridge and ran a test print now it tells me that there is an alignment problem and to remove tape from cartridge and reprint. There is no tape on the cartridge . I dont know what to do!?!?!??
  • Anonymous Feb 23, 2009
    I have the same issue. I replaced both cartridges and ran the alignment test numerous times but kept getting this message. I then unplugged the printer and plugged it back in and it was fixed! You probably already tried this but if not, it worked for me. Good luck!
  • Anonymous Feb 25, 2009
    my dell AIO 926 is doing the same thing
  • 514 Answers
""I have the same issue. I replaced both cartridges and ran the alignment test numerous times but kept getting this message. I then unplugged the printer and plugged it back in and it was fixed! You probably already tried this but if not, it worked for me. Good luck!""
try that for about 10 seconds per the manual at ("http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf" if you don't have it)
good luck!
Posted on Feb 28, 2009
  • 3 Answers
My printer is doing the same thing, lexmark 5000 series, disconnecting power then reconnecting doesnt work. I got on lexmarks tech support and they told me it was because i filled the ink cartridges up and the printer knew I had done so and not replaced them, what a load of ****! It was doing this before I put ink in them can anyone help? thanks
Posted on Jun 29, 2009
My printer says printing alignment and prints out a page, then says alignment problem remove tape from cartridge or look in troubeshooting guide
For alignment complete you need both print cartridges printing all colors.If you have empty cartridge or clogged cartridge alignment will not complete.Look which color missing and replace cartridge.
Nov 15, 2009 | Dell 962 Photo All-In-One InkJet Printer
Wont print black
clean the contact on the printer and the ink cartridge. do not use paper towel. use coffee filter.
Oct 20, 2008 | Dell 924 All-in-One InkJet Printer
Color not the same as photo
I bought 2 new cartridges from Dell and I cannot make my color one to print color.....Please help. I have tried to troubleshoot , cleaning the printer, etc..... Thank you. Nursee
I have a Dell All in one color 924 printer
Sep 30, 2008 | Dell 924 All-in-One InkJet Printer
Printer is printing every line two times and is faint
if you said you have done and removed the tape and run all test, chances are the cartridge itself is the problem , return to vendor for a new replacement, this can sometimes happen
Jul 23, 2008 | Dell 922 All-In-One InkJet Printer
How do I install an ink cartridge? HP photosmart c5280 All in one
To replace the print cartridges Perform the following steps to replace the print cartridges:
  1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. The HP All-in-One can get damaged if the print cartridges are not docked safely when trying to remove them.
  2. Open the print cartridge door. The print carriage moves to the far right side of the HP All-in-One. Figure 1: Opening the print cartridge door c00956268.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. Figure 2: Removing the print cartridge from the slot c00956269.gif 1 - Tri-color print cartridge slot 2 - Black and photo print cartridges slot
  4. Pull the print cartridge toward you out of its slot.
    NOTE: Remove the black print cartridge to install the photo or gray photo print cartridge, and store the black print cartridge in the print cartridge protector or an airtight plastic container.
  5. Remove the new print cartridge from its packaging, and carefully remove the black plastic tape by using the pink pull tab Figure 3: Removing the new print cartridge from its packaging c00956270.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad electrical connections. Figure 4: Do not touch the copper-colored contacts c00956271.gif
  6. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into the empty cartridge slot. Make sure to push the print cartridge firmly until it snaps into place. If installing the tri-color print cartridge, slide it into the left slot. If installing a black, photo, or gray photo print cartridge, slide it into the right slot. Figure 5: Installing the print cartridge c00956272.gif
  7. Close the print cartridge door. Figure 6: Closing the print cartridge door. c00956273.gif HP All-in-One prints a print cartridge alignment page if a new print cartridge is installed.
  8. When prompted, ensure plain white paper is loaded in the input tray, and then press OK .
  9. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer. Recycle or discard the page. A success or failure message appears.
    NOTE: If colored paper is loaded in the input tray when aligning the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support at www.hp.com/support If prompted, choose your country/region, and then click Contact HP technical support.
  10. Press OK to continue.
May 15, 2008 | HP Office Equipment & Supplies
Dell Photo 926 Printer Trouble
reinstall the printer driver
Mar 27, 2008 | Epson Printer
Replaced dell 924 printer cartridge and wont work
Me too. Now it says "right cartridge incorrect" and won't allow me to do anything at all, not even maintenance functions.
Feb 20, 2008 | Dell 924 All-in-One InkJet Printer
Printing Photos
I refilled color ink for Dell Photo 924 but some reason it showing it me low ink.
Dec 09, 2007 | Dell 924 All-in-One InkJet Printer
Color Cartridge Failure
You know, I'm not going to read the other solution. I know 100% FOR SURE, when a cartridge fails, it is dead and there is nothing you can do about it, but there is a good side. HP ink cartridges have a year warranty. Call them and tell them it failed, they'll send you a new one!
Sep 18, 2007 | HP PhotoSmart 7760 InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
1,710 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
