Question about Mitsubishi VS-50605 50" Rear Projection Television
Picture rolling when I first turn on my tv
When I turn on my Mitsubishi tv model #50605 the picture rolls how do I adjust the picture to fix the problem? also can you attach me some pics as to what I am looking at or for.
Thank you
    Novelist:
  • 184 Answers
A rolling picture or loss of vertical sync can be caused by several components including a bad signal board or jack panel assy. You will not be able to resolve this yourself. contact a Mitsubishi authorized service center.
michtech
Posted on Feb 14, 2009
Vertical hold problem on 1999 Mitsubishi rear projection VS 50605 can't find reset button.
Put it back to the mid point of it's adjustment range.
If the V hold won't stop the picture rolling at some point in its adjustment range then the circuit that it affects has drifted out of tolerance. The defective parts in that circuit need to be replaced.
Sep 10, 2014 | Mitsubishi WD Televison & Video
I have a Mitsubishi VS 50605 projection tv that needs to have the vertical hold reset. How do I reset it.
If the V hold won't stop the picture rolling at some point in its adjustment range then the circuit that it affects has drifted out of tolerance. The defective parts in that circuit need to be replaced..
Hour glass cannot adjust red horizontal convergence
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 09, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Screen rolls maybe vertical sync
II NEED TO RESOLVE A PROBLEM OF VERTICAL SINCRONICE I SALLBE GRETFULL TO HAVE ADJUSTMENT INFORMATION I SHALL BE GRATEFULL IF YOU COULD HELP ME
May 26, 2009 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi TV picture rolling
Look on the back and see if you have an adjuster.(It should say
H-HOLD) Just turn it very slowly until the picture stops rolling,You can do this by watching the tv screen in a mirror.
Please rate this solution.
Jan 16, 2009 | Hotpoint HSS25GFP Side by Side...
Picture rolling horizontally and vertically
tv needs repair c2c52 and c2po5 need to remove .both should be on the signal pcb
Nov 16, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Rolling screen
Good Day; lanniejo;
1. VERTICAL ROLLING, ALSO MAY HAVE HORIZONTAL PULLING OR TEARING. REPLACE C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. REPLACE C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
It should not be that costly, always get an estimate, if you can't repair it yourself. Don't worry about the light bulb, it should be okay, as long as the picture color is ok. Good Luck, big IRISH.
Sep 29, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Rear project TV problem
yes it can be fixed depending on your model number if its the VS50605 they have a kit to repair the PIP module which controls vertical sync (Rolling) or you can bypass the module to correct it but you would lose the PIP function. Let me know if you need more info.
Apr 17, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Whats a quick solution
The problem may be related to bad capacitors on the PIP module. This is a commom fault as vertical sync runs through the PIP board and this is the symptom of the pip board having bad capacitors the TV rolls.
Mar 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi vs-50605
does not sound like convergence have had a few with bad capacitors. any good at soldering
Oct 23, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
268 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
