Question about iRiver U10 Digital Media Player
Won't play downloaded songs and deleted songs won't go away
I have an iriver u 10 and i try to add some new songs to it. When i do the computer says its downloaded but as soon as i get usb out and look through my mp3 it isn't there. Also i delete songs and it never goes away.
  • ncordon May 09, 2009
    deleted songs would not go and new songs would not show on the database. now i have reintalled the firmware none of the music displays and says 'cannot load the music database'
  • Cameron
    Cameron May 11, 2010
    What program are you using to transfer the songs?
SOURCE: iriver mp3 player
Try this. Worked for me.
http://forums.whirlpool.net.au/forum-replies-archive.cfm/751249.html
Cheers
James
Posted on Mar 17, 2008
  • 4 Answers
SOURCE: i river s 10 not workng
Have you formatted the drive through settings? There is a reset on the side that you can try also. you will need a paper clip to do it though.
Posted on Sep 22, 2008
  • 3 Answers
SOURCE: iriver T10 will not allow me to add songs
The updater that I could find directly via iRiver support did not work, but based on one of the other tips, I googled for the Version 2.7.0.0 updater ([MTP] iriver Firmware Updater for MTP devices).
http://www.iriver.com/flash/popup/flash_pop.asp?board=down&code=736
I recommend that you try the "normal" updater from the website (maybe yours is not an MTP version), and if that can't recognize your player, try the updater from the link above.
Note: The updater seemed to hang at 50% for over 5 minutes... I gave up and unplugged it. Then it asked me if I wanted to upgrade the firmware. "OK," I said. It took a few minutes. The screen went blank. I put in a fresh battery. Turned it on. It works. I was able to use Media player 11 to synch some songs to it.
BTW: It did blow away all the songs on the device, even though I chose "update" instead of "recover".
Posted on Nov 27, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: how to delete video files from iriver e100 mp3
The video files should be in the video folder instead of the music folder - use Windows Explorer to be sure. If they are not showing up, switch the device's mode to MTP mode and see if the video files show up as available for deletion.
-Tha Mp3 Doctor
Posted on Dec 29, 2008
Here is what I do when I need to reset - format S10 machine from windows
1. plug the S10 into the computer via the USB key
2. You should see the S10 in Windows Explorer as a portable flash disk
3 Right Click and select format - Warning! all data will be lost if you have not backed up!
4 In the File System drop down list select FAT (the default is FAT32)
5 Click start to format the device.
6 Once the S10 has been formatted unplug it from the computer
7 Turn the S10 on and scroll down to SETTINGS
8 Right click and scroll down to Advanced
9 Right click and scroll down to Format Device
10 Right click and then click OK to confirm
On the same menu as Format Device is Reset All Settings - I recommend you do this as well.
11 Plug the S10 back into the computer
12 When you look at the S10 in Windows Explorer you will see it has created some extra folders
13 drag and drop MP3 music files into the Music folder and away you go!
14 you can create additional folders in the Music folder if you want to organize your music
Posted on Jan 01, 2009
Hi, my problem is that the display says there are mp3's loaded, but when I connect to my pc, it shows only 1 song listed. And it only plays that 1 song. How do I delete the mp3's using the I...
You can't delete songs off the iRiver from the device, you have to do it from the PC using the iRiver Music Manager Software that can be found on their website
www.iriver.com/support/download_view.asp?dNum=859&n=-1
Please rate this solution to show your appreciation!
Jun 01, 2011 | iRiver Audio Players & Recorders
Cannot delete musice from iriver h10 need to know how
I presume that you are running the original firmware with windows media player to add your music.
There is an option on the Sync screen to delete.
Let me know if you are not using WPM to add your track to your h10
Jun 09, 2009 | iRiver H10 MP3 Player
Song names in X20
i think you should try this...
if you dont already, download iriver plus 3
install it
open iriver plus 3
plug in iviver
go to tools>Portable Device>Disk Initialization
this should format your iriver and replace all the original files
i reccomend only putting music, video, pictures and ebooks on via iriver plus 3
and also please make sure you safely remove the iriver each time you connect it to the computer
if you dont, there is a chance that you will screw your iriver, you may have heard of the "building library" problem, which nobody has found a solution for yet.
i hope this helps you!!
good luck!
Jun 06, 2009 | iRiver X20 MP3 Player
Iriver E10.....wont play songs
well it seems you deleted your songs but not the titles. weird huh but that happened to me too. so hook it up to your computer, go to " my computer", and then right the icon that is your device, and then click format and that should take care of that.
May 28, 2009 | iRiver E10 Digital Media Player
Computer says songs are there iPod says there not
your ipod will not function properly with windows media player. it may play the music but it won;t get functionality from the ipod.
You have to use iTunes to get your ipod straightened out. Once you mount it on iTunes you will see the music and be able to add music and delete music.
May 24, 2009 | Apple iPod classic 7th Generation
I try to delete songs on my I river but they never go away?!?!?
go to your music sourse on the computer and delete it from there, then make sure the file is out of your computer completely by deleting the raw file. next plug your iRiver into the computer and syncronize it to you music source, the song or songs should have been deleted. I used to have an iriver but got an hour glass that never ended when I turned it on, i fixed it but then it happened again so i got fet up with iriver and gave in and went and bought an iPod
Mar 28, 2009 | iRiver E10 Digital Media Player
Cannot delete or add music to iriver h10
I had this problem at first too. the only thing you have to do after it's done syncing disconnect it and turn it on. then afterward go through the options till you find database refresh and wait for it to refresh and all your new music should be in it.
Jan 04, 2009 | iRiver H10 MP3 Player
New hard drive has trouble downloading songs & won't play
hi there, open iriver again and take new drive out (reinstall hard drive, just an adjustment process). close it up and try to download / play a file.
now if this process dont work, save iriver software to pc and format the hard drive (this will erase the hard drive songs and all)..now reinstall the software from the pc...download your songs back to iriver and you should have a brand new Iriver ihp-140............if heplful feel free to rate
Oct 22, 2008 | iRiver iHP-140 MP3 Player
I river s 10 not workng
Jul 26, 2008 | iRiver S10 2 GB MP3 Player
New Music files copied to my iriver will either not play or partially play
Backup the h340 to your pc, format the h340 hdd and reload it, refresh database.
Oct 17, 2007 | iRiver H340 MP3 Player
iRiver U10 Digital Media Player Logo
61 people viewed this question
Top iRiver Audio Players & Recorders Experts
aliasger yq
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
