Question about GE WJSR4160DWW Top Load Washer
A sound like a watch in the TIMER ASM WASHER
There is a sound like a watch in the control timer of my washer model:WJSR4160DWW
  • lvargaspa200 Feb 14, 2009
    It sounds all the time, It never happens before
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    Does that sound stay on all the time or only when the unit is running?
  • 1,902 Answers
Replace the timer. The timer is just running all the time which means that its switch is held open and needs to be replaced. you can find the part at
Posted on Feb 14, 2009
Replacing the timer
Are you having a problem replacing the timer or wondering if you should replace the timer?
Jan 13, 2013 | GE WJSR4160DWW Top Load Washer
I want to replace a timer on a Whirlpool washer Model# LSN1000KQW
Good day Mr.james dant..
Whirlpool manufactures many types of washing machines. Whirlpool's top load models rely on an analog timer that controls the cycle used to wash the clothes in the washing machine, rather than a digital control board found in most front load models. The timer contains a number of moving parts and is physically turned to choose the wash cycle. Because of the high usage of the timer, it will eventually break, requiring replacement. Rather than calling a service technician to repair the timer, replace the timer yourself to save both time and money.
1. Unplug the washing machine from the wall outlet
2. Turn the dial to the "Off" position and then unscrew the knob from the timer. To unscrew, hold the dial with one hand and turn the knob counter-clockwise.
3. Lift the dial off of the washing machine.
4. Remove the two mounting screws securing the timer into position. 5. Remove the two screws from the bottom left and right sides of the control panel, then rotate the control panel up 180 degrees.
6. Remove the wire harness from the old timer and remove the old timer
7. Connect the wire harness to the new timer.
8. Place the timer into the control panel. Hold the timer post with one hand and rotate the control panel back down. Secure the timer into place using the mounting screws that were removed from the old timer
9. Place the dial back onto the timer post and then screw the knob onto the post.
10. Plug the washer back into the wall outlet
Try to watch this video:
Nov 25, 2011 | Washing Machines
1.3 year old Frigidaire Stackable washer/dryer model FEX831FS won't drain. Checked pump and hoses. OK. Am in remote Alaska and we don't have service tech's here. Any suggestions.
What you want to check is the lid switch..remove the front panel..on the switch/lid lock asm.will be
the main switch which is part in the black body of the lock asm. the 2 terminals their will have contunuty with zero ohms when lid is closed
when lid closed the white switch will be open and closed when lid open
the one in the black body on the main lock asm. will be open when lid open
IF it does turn out that the lid lock is the problem the part number for it is 134101800
it could be purchased online at;
If the switch checks to be good test for power into the drain pump if no power the timer is what is wrong the washer (not dryer) timer is part# 131758600
Aug 24, 2011 | Frigidaire Washing Machines
Washer works but does not run through the spin cycle. it will if i go to it with the timer switch. but not with the timer. when washer gets to the off pos. still has water in it. sat and watched it on...
Sounds like the timer isn't advancing does'nt it.
See if there is power getting to timer motor, but sounds more like timer getting stuck ,especially if older model .replace timer if out of warranty
good luck
Aug 15, 2011 | Maytag Washing Machines
I need a picture of the inside of the timer asm washer
absolutely need the make and the model number of the washer to provide u with assistance, this is not generic information, thanks await your answer.
Nov 05, 2009 | Washing Machines
My washer is not draining during the spin cycle
not draining your washer at all, pump may be bad or no power to pump, take the drain hose out of the "stand-pipe" where water enters the sewer drain, and lower to floor and see if water drains by gravity if only slowly your pump or hose may have a slug of crud in it blocking drainage to sewer pipe
Aug 02, 2009 | GE WJSR4160DWW Top Load Washer
Maytag Washer MAV7000AWW Washer fills as it
Sounds like a bad timer motor.
Try watching the timer motor and see if you can see it moving .
Jun 09, 2009 | Maytag Atlantis MAV7000
HI, this timer is faulty and, these are early warning signs of potential failuer of this device in the near future. i would prepare to replace the timer control soon. the actual mechanism is showing signs of breakdown.
May 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
GE WJSR4160DWW Top Load Washer Logo
100 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
