Question about Whirlpool CSP2761 Gas Commercial Dryer
Whirlpool commercial gas dryer - heating problem
3 heating settings - high, medium , low
On "high" does not heat up, works fine on medium and low.
Any suggestions ???
    President:
  • 1,902 Answers
Check the voltage to the switch when turned to high and the power button pushed on. If you are not getting any power there then the setting switch is bad replace it at repairclinic.com
Posted on Feb 14, 2009
LG Dryer low heat doesn't work
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
May 04, 2014 | LG DLEX7177 Dryer
Whirlpool Dryer LET7848A - no HIGH heat
yes the coils which heat the heater heating plates are faulty because of broken wire.
they hshould be replaced to make it work.
thanks.
Sep 21, 2008 | Whirlpool Dryers
Kennmore Elite HE4 no heat on low or extra-low setting
Assuming this is a gas dryer, it is likely the igniter has failed. The igniter plate has to heat up to glowing in order to heat up the thermocouple that turns on the gas valve.
Sep 03, 2012 | Kenmore Dryers
Two problems with Whirlpool Dryer
I would suspect the heating element. I bet you are asking why this clown is saying that when you already told him that on high heat it worked fine. SIMPLE! Your heating element is made up of five coils. For low heat your dryer uses two heating elements and for high all five. So if one or two of the heating elements are open and they happen to be the low temp dry setting ones, that would explain it. That model doesn't have the dryness sensor on it (according to my documentation) so the heating element is the most likely cause.
Hope this helps!
ImJustAvg aka Hal
Dec 30, 2011 | Whirlpool Dryers
My dryer runs, but no heat when I place on low, medium, or high heat?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 28, 2011 | Frigidaire GLGR341AS Gas Dryer
Ge profile dryer drum turns but therte is no heat
heatman101
Oct 27, 2010 | GE Dryers
I have a asko t700 it goes on drum turns but no heat when set at high or low heat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 09, 2010 | Asko T700 Electric Commercial Dryer
Whirlpool electric dryer, Model LEC6646ANO. On
Make sure the internal and external exhaust vents are not blocked with lint.
Will it complete a 45 minute time dry and dry the laundry?
Mar 09, 2009 | Whirlpool Dryers
Dryer Heats on High all the time
I don't think it is the heating elements. You have checked out all the important stuff. Is there power coming from the controls on medium and low. It sounds like this is the problem.
Jan 23, 2009 | Frigidaire FEQ332E Electric Dryer
Consequences of using high heat in dryer
the vavle in using high heat only comes in to play when you have a load of towels or some other heavy cotton,,thats what high heat is mainly for,,more moisture,,,on the norm medium with a regular load is the way ..now go to the dryer and look at the back vent where the heat comes out does it look like burnt and dark as if you burnt shirt and it stuck to the iron,,that comes from high heat scortching,,rubber in elastic in your sock and other clothing...onthejob slow low and steady
Dec 27, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool CSP2761 Gas Commercial Dryer Logo
225 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
