Question about GE GDS18LBP Bottom Freezer Refrigerator
Refrigerator and freezer won't get cold
Power and lights are on the fan is on but compressor will not kick in
    President:
  • 1,902 Answers
Check the compressor for voltage and make sure that it is getting power. If it is getting power and not starting then the compressor is shot and the cost to replace is about 450 to 600 to replace. If that has voltage but you want to double check you can check the relay on the back of the unit and make sure that it has power going to it and from it. Then you know for sure that the compressor is gone
Posted on Feb 14, 2009
Barely cool, fan running and one tubing by compressor warm and one cool on and the cool
Is fan inside the freezer running with the light switch pressed in? To confirm a Freon on a refrigerator that still cools yet not well remove the rear panel inside the back of the freezer APPLIANCE911
Apr 17, 2016 | Refrigerators
ARB1914CW AMANA REFRIGERATOR. FREEZER PART SEEMS TO BE WORKING FINE BUT THE FRIGE SECTION IS NOT. TEMPERATURE IS STARTING TO RISE IN THAT SECTION AND TURNING THE THERMOSTAT UP HIGHER DOES NOT EVEN TURN...
HI,
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
Jul 23, 2008 | Amana Refrigerators
Freezer won't stay cold
What is the model number of your unit?
Feb 10, 2013 | Gladiator Chillerator Top Freezer...
Kenmore Elite 106.53609202 won't get cold (refrigerator or freezer)
When you say it's running, do you mean the fan in the freezer or the compressor is running?
Oct 19, 2012 | Refrigerators
Freezer and Refrigerator are both warm. Fan is
Sounds like the compressor is gone, or the coolant has leaked out. If you can hear the compressor kicking on then the odds are the coolant is out.
Feb 28, 2011 | Maytag MTB1955GRW Top Freezer Refrigerator
The top of the freezer part is getting cold but the bottom of the Refrigerator part is not getting cold. The Refrigerator is only 10-11 months old ; what is wrong?
you need to check and see if the fan in the back of the freezer compartment is running. when the fan is not running the cold air will not be passed to the refrigerator compartment. open the freezer door and turn the unit to its coldest setting until the compressor kicks in then listen to hear the fan in the freezer compartment.
Sep 16, 2009 | Refrigerators
Freezer is ok, but fridge is not cold enough
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked.
Sep 01, 2009 | Kenmore Refrigerators
Compressor making noise and freezer is kicking cold air out but
Sounds like the start relay, start capacitor and overload have become defective. Turn it off to prevent further damage to the compressor internal overload. Check to make sure the condenser fan and the evaporator fans are running and get back with me with an answer yes or no. Thanks, Sea Breeze
If the model number you have above your post are correct I will also send you part numbers and hot to replace.
Aug 04, 2009 | Maytag PTB2154G Top Freezer Refrigerator
Refridgerator and freezer wont get cold
sounds like a bad compressor, or at least the start device plugging in to the compressor has gone bad,
Mar 15, 2009 | Frigidaire FRT21H8 Top Freezer...
Hotpoint FFA70 Freezer High Temp
sum fans only kick on if cold enough
if the whole evap is frosted up u have a defrost problem
if frost is only partial u need to throw it out cause it either has a bad compressor or freon leak
check your fan by compressor and make sure coil isnt filthy too
Jul 08, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
GE GDS18LBP Bottom Freezer Refrigerator Logo
163 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
