Question about Mitsubishi VS-50502 50" Rear Projection Television
Mitsubishi vs50502 we have a mitsubishi vs50502. While watching tv it went from clear picture to almost 3d and warped? what can i do?
    Novelist:
  • 184 Answers
That's a convergence circuit failure. You may have to have the convergence output IC(s) replaced. Sometimes, if you catch it early and its still intermittently doing this, you may get lucky and only have to re-solder the pin connections under the convergence IC(s). If you're not up to doing this yourself, contact a Mitsubishi authorized service center. If the IC(s) need replacing, expect to pay $400-$500 to resolve this issue.
michtech
Posted on Feb 14, 2009
  • Billy Bauer Feb 14, 2009
    michtech
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
The picture is not clear anymore. It seems as though the picture has gotten gradually darker. We still use the television, it is just not clear enough. When watching nighttime scenes, we cannot see mu
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Jan 21, 2013 | Philips Magnavox 9P6034C 60" Rear...
View 3D on wd-y65
Ur tv does nt support 3D. U can still see 3D if connected to PC. With power DVD 11 u can able to watch anaglyph 3D.
Dnt get confused any standard screen (e.g. CRT (big boxes with curved screen)) can view anglyphic 3D content.
Jan 08, 2012 | Mitsubishi WD-Y65 65" HDTV
I have mitsubishi vs-50800 i was watching a movie and the screen just all of a sudden went blury and the color is all mixed up i went to the convergence menu and it wont allow me to move the colors left or...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 03, 2011 | Mitsubishi VS-50800 50" Rear Projection...
MITSUBISHI WD62525 - bad fuzzy picture with lines and waves - have MonLink hooked up to DTV. Picture does not improve even when playing a DVD. Used same MonLINK with another tv and picture was great !
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 27, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Its a 2004 and picture isn't real clear what can be done?
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
Feb 24, 2011 | Mitsubishi WS-65809 65" Rear Projection...
My Mitsubishi WT-42315 is almost like watching tv with 3d glasses on with the way the colors all seem split. Once in a blue moon it won't do it. But only for like a minute or so. What can I do to try and...
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 22, 2011 | Mitsubishi WT-42315 42" TV
Hooked up PS3 to system and when watching DVD's the right side of the picture is blurry and appears doubled, like an old 3D movie without the red and blue glasses. When watching TV everything looks fine.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
WE HAVE A MITSUBISHI VS-60719, AND THE PICTURE LOOKS LIKE 3D AND WARPED, DO YOU KNOW WHAT THE PROBLEM IS AND IS IT FIXABLE
  • Screen looks 3D
Here are some images of convergence problems.
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself.
Nov 27, 2010 | Mitsubishi VS-60719 60" Rear Projection...
Tv screen is warped on edges. what to do?
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Mitsubishi WS-65807 65" Rear Projection...
Televison & Video Logo
217 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
