Question about Creative Labs Zen Micro MP3 Player
My mp3s headphone jack always crackles and you can hardly hear it
I got
  • bugsmjd Feb 25, 2009
    I have the same problem.
Perx sound driver
Posted on Feb 14, 2009
Occasional Crackling
your headphone jack may be caused problem.
Mar 27, 2013 | Bose (R) MIE2 Mobile In-ear Headphones
Bose AE2 not working properly
Get a new cord from Bose. $8.00. You've lost the ground connection and you're hearing everything out-of-phase.
Jan 21, 2013 | Bose Corporation AE2 Audio Headphones
Broken headphone jack on dell d630
Yes! if the plugin is not secure the connection will be poor causing unstable reception in the audio department.
May 10, 2012 | Dell Latitude D630 Laptop Computer PC...
MY sennheiser 205 headphones stopped working overnight. I can hear everything fine, the only thing is that i can barely hear the vocals. I did switch devices to see if that was the problem and it was not....
1) You are turning up the volume too much. Headphones, especially non-top of the line headphones, are not meant to be listened to at very loud levels. In this case, the crackling you are hearing is the speaker trying to reproduce a bass sound that is "clipping", or exceeding the maximum output level for that system. Remember - headphone speakers are very small; they have a harder time producing low sounds accurately. The solution is to just turn them down a little.
2) Assuming problem 1 is not the problem, the other likely issue is that they came with some sort of mechanical defect built in. If you are not playing them loudly, but you are still getting a crackle, especially if it is only on one speaker, they probably are broken. It is probably the jack itself, or the wiring leading up to the earpieces. Either way, it is not a terribly hard fix if you have some electrical know-how, but if you don't, there are plenty of people who can rewire them for much cheaper than it would be to buy a new set. However, if this has been happening since you got them, I would call the manufacturer first and see if they will replace them. Sennheiser tends to pride themselves in the quality of their equipment, so I would not be surprised if they sent you a replacement set.
Hope this helps!
Jul 01, 2011 | Sennheiser HD 205 Professional Headphones
Hello. With my HD205 headphones, in the left headphone it has a small crackling noise with certain songs.. I don't know if its meant to be like that? Its done it since I had them first - Happens to bass...
There are two likely causes for this. One is much, much easier to fix than the other.
Hope this helps!
May 03, 2011 | Sennheiser HD 205 Professional Headphones
Crackling sound
Have you tried some headphones directly into the headphones socket? Does the sound still crackle? Usually 'crackle' is associated with dodgy leads and you will be able to hear the lead responding to movement by crackling more, a hissy sound often means that there is a fault with the socket and sometimes removing and reconnecting the jack into the socket a few times will help this. If it sounds like hiss with little pops it's usually electrical interference and could mean a bad earthing in the circuit somewhere
Jun 06, 2010 | Dell (8H390) Sound Card
The headphones crackle, tried several different headphones, no better. I have to twist the end of it to get it to work. The slightest bump will make it crackle again.
This happens when the headphone jack gets rust on its surface or it is loose.
Clean the jack using a tissue paper on matchstick (or a similar thin object). Be gentle or you may destroy it!
If cleaning did not help you may need to replace the jack. Contact for repairs or if you have experience in soldering, you can purchase a replacement jack online (search ebay) and solder it in.
Jan 29, 2010 | Sanyo Audio Players & Recorders
Intermittent Crackling noise in the right headphone
Hello Rachel, I use my QC3 for 2.5 years Mon-Fri for 3 hours a day. I have the same problem when battery is weak and/or it is cold outside. The cracking nose stops for me if battery fully charged. This is known problem andBose put it in the manual.
Vlad
Aug 28, 2008 | Bose QuietComfort 3 Acoustic Noise...
Cannot hear music
The bad news is that your headphone jack is most likely shot. The soldered connections inside are most likely broken. This is not repairable generally, at least not for a cost that would be reasonable. Music will play through your computer because it can be read off your player through the USB connection. Use it as a data storage drive and buy a new one, or a used one. I've seen used T30s on Amazon for around $30 to $40.
Mar 26, 2007 | iRiver T30 MP3 Player
Audio Problems with Sansa e260
apparently you may need to defragment your player with disk defragmenter because the mp3 has a hard time getting the pieces of your file fast enough to not hear an almost unnoticeable pop or crackle. if this isn't the reason, it is probably the jack, try a different pair of headphones even. or check the settings on the program synchronizing as it may be syncing the files at a noticeably lower sound quality. Or you are drag and dropping which may not be recommended for inexperienced users. no offence :).
Jan 28, 2007 | SanDisk Sansa e260 MP3 Player
Creative Labs Zen Micro MP3 Player Logo
78 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
