Question about Pioneer Elite PRO-1540HD 60 in. Plasma Television
I have an Elite faltscreen television that has been working well for over one year. For an unknown reason, the blue light (next to the on/off switch0 is blinking and the TV is not responding or turing on. Please help.
  • 41 Answers
Please count the number of flashes of the Blue LED. It will flash Ex. 12 times and pause for 2 seconds and then flash 12 times again. The number of times it flashes will tell me more as to what the solution is. I am assuming the set works otherwise ?? What is the model number of the set ?
Scott
Posted on Mar 29, 2009
I am using ultrasurf since 1 year in my pc 8440 but due to unknown reason it dosn't work anymore so, what will be the reason and how can fix this
Did you reload the software? Try that first, check for updates. If it was recently updated then, roll back the update to the previous version.
Apr 21, 2013 | Computers & Internet
Pioneer Elite Pro-111HD 50
Ur video ic inverter board is dead.
U need a new video board.
Aug 23, 2009 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Plasma tv no longer powers up
The gas has leaked out and can't be fixed unless you pay to have a new panel assembly put in. Sorry its trash now as you can replace it cheaper now a days.
Mar 15, 2009 | Pioneer Elite PRO-940HD Television
TV keeps shutting off automatically
Since your plasma is less then a year old, I would suggest to contact the manufacturers to get it fix under warranty. If the plasma keeps shutting off by itself, that is not normal and should be repair.
Jan 28, 2009 | Pioneer Elite PRO-111FD 50 in. Plasma TV
Not Charging
Same thing happened to me the other day. For some unknown reason my wep500 seemed to just die with no apparent cause or reason. So I took the unit apart and tested the battery with a multi meter. It read 3.9V. So power was not the issue, I then put it back together and by chance, happened to continue pressing the power button for 5 seconds in hope I would see the LEDs flash but no dice. Then for no reason, I went to my phone and tried to pair and to my amazement it actually paired (meaning the device must of been on). So I then hit the big button on the wep500 and sure enough it calls the last number stored in my phone. It turns out (out of all things) the led itself went bad for some unknown reason. I suggest you try charging it (you won't see the red led), try turning it on (you won't see the blue led) and then try pairing from your phone. If you phone indicates it paired, then try calling the last number from your wep500. If it works, then you too have a bad LED (I have never seen an LED go bad before). Hope this helps.
Sep 13, 2008 | Samsung WEP500 Wireless Headset
TV Picture cuts off.
The blue screen means that you have lost signal. If the set don't have signal for so long it turns itself off. "power saver feature" Check all connections or replace cables, If that don't work the signal board may be going bad.
Feb 26, 2008 | Televison & Video
One day it worked the next it didn't
These TV's are prone to power supply failure. I can fix the power supply on this TV for approx $100 +s/h.... Contact me and all you have to do is remove the power supply and send it to me and I will repair it with high quality parts. Reinstall and you TV will be good as new...
Jan 25, 2008 | Akai LCT2715 27 in. LCD Television
CONVERGENCE
my set is a few days over 4 years old. same issue. called sony-- told that D-Board needs to be replaced. Board is no longer made. waiting on call back from local service center
Dec 11, 2006 | Sony KP-46WT500 46" Rear Projection...
Pioneer Elite PRO-1540HD 60 in. Plasma Television Logo
504 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
