Question about Cobra 29 WX NW ST 40-Channels Base CB Radio
Cobra 29 wx st
The radio lights up even shows when i key up and shows swing but i cant hear anything and doesnt seem to be transmitting i have also tried different mics on the radio to see if that was the problem but it got me no where when u put the radio on pa it works just isnt receiving or transmitting on the cb side or weatherband side i welcome all solutions or possibilties
  • AnyMHz.com
    AnyMHz.com May 11, 2010
    If pa works then audio ic should be ok.. check antenna/swr. otherwise loose connection on the pcb any other problems to clarifiy it more??
  • Tom Arsenault
    Tom Arsenault May 11, 2010
    "radio lights up even shows when i key up and shows swing"Need to know if the meter swings when you transmit and modulate,or does it just shoe a deadkey with no foward swing? If this is so, I would suspect a loose leg on the audio chip on the pcb.No recieve or no recieve audio? This a new radio? Any work done?
  • 55 Answers
IF YOU CAN RECIEVE THAT IS A VERY GOOD SIGN THAT YOUR SWR MATCH IS OFF....I DONT KNOW IF YOU MATCHED UP YOUR RADIO WITH YOUR ANT.IF NOT YOU CAN BUY A CHEAP SWR METER @ RADIO SHACK...CHECK THAT YOUR COAX CABLE IS OK TRY TO REPLACE THE COAX......GOOD LUCK
Posted on Feb 21, 2009
My cobra 29 wx nw st can recieve, but will not broadcast
Could be anything from a broken microphone wire to a bad final or regulator.
Sep 11, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
Cb transmit noise
Its just RF feed back, that's normal, try to re-route the coax, or just turn the FM down, o try turning your modulation down....hope this was helpful....
May 29, 2010 | Cobra 75 WX ST 40-Channels Handheld CB...
Cobra 18 wx st for mobile use, ned to switch reg mic for cherokee power mic. need mic diagram for the four pin
You probably don't want to hear this, but the cobra 18 wx st is just about the worst, and most hated radio ever made. Its a very poor radio.
to be very honest with you, you should get rid of that radio, or return it. Then buy a cobra 29 instead,
for proper mic wiring, please reference this page.
Jan 03, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
Cb is Keying Down instead of keying up when trying to talk
if you are transmitting fine Don't worry about the meter. Get an external SWR meter, they are better anyway.
Also, make sure the the switch next to the meter is all the way up on s/rf setting. thats for signal power and receive strength.
Aug 30, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
I can hear others but when i talk noone hears me
Try switching a different mic, sometimes the transmitting wire comes loose inside the connector. If you are handy enough, you can even unscrew those two tiny screws on the end of the mic cord and see if a wire is loose and if so, solder it back into place.
Oct 04, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Transmits but doesnt receive
If the meter shows that it's receiving something, the microphone may be the problem. Another possibility is the speaker & plugging an external speaker in would confirm this. Aslo make sure the squelch control is turned all the way to the left (counter-clockwise) & the RF gain is turned to the right (clockwise).
Jul 18, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 wx st
Take it back to your 'pro'. Let him fix it.
Jun 22, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Codra 29 nw ltd classic
For the money,the Cobra 29 nw/st is just as good if not better than a Galaxy. Cobra is more durable by far. I have had 3 of these cobra's in the last 30 years. Only had to replace the last one because the tractor got hit by lightning.
Sure would not pay big money for a name.
Mar 19, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
237 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
