Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
The detergent container fell off as I removed the full tank from my sink. The top portion of the container broke off and is no longer usable. How and where do I replace it.
    Brigadier General:
  • 8,619 Answers
Hi!
You can order that part from the link---
Hoover parts
Also you can remove it & assemble it by looking at the link---
Posted on Feb 14, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially:
  • if you are referring to a Hoover vacuum cleaner, pls click here; and/or
  • postback to confirm that it is a SteamVac F5914-900 SpinScrub Upright Vacuum or whatever is the exact model;
  • if not, pls do the same and include the brand, product type and exact model.
Good luck and thank you for using FixYa.
  • 3,037 Answers
I can find you a repair center near you to get a new part or have them fix it or you can do a search on the right side of this website, If you want me to seach, I just need your zip code
thanks
bestdarngood
    Brigadier General:
  • 5,158 Answers
  • 6,784 Answers
You can get this replacement part off the hoover main website. you will have to register and, supply them with your model number as well.
  • Michael Masters
    Michael Masters Feb 14, 2009
    If you live close by a sears, they can order this in the store for you as well.
Wear do you put the water
Inside the main tank is another container for clean water.
To fill it, lay machine all the way down. Lift handle and remove container. Take to sink, turn handle, and remove lid. Fill with hot, clean water. Replace and lock the lid. Place container back into tank and put handle down.
Sep 29, 2010 | Bissell 1699 ProHeat Clear View Upright...
Hoover F7425-900 SteamVac V2
http://www.hoover.com/pdfs/manuals/F7452900.pdf Heres a link to the manual if you dont have one, Ive emailed them and they gave me the same solutions that are on page 17. ? Make sure tank is securely locked in position ? Clean water tank or detergent container empty ? Refill container according to instructions for surface being cleaned ? Recovery tank lid not on correctly ? Make sure lid is firmly in place ? Valve cap clogged ? Remove and clean valve cap (see following instructions) 1. Remove clean water tank. 2. Turn valve cap (A) counterclockwise and remove. Soak valve cap in warm water for at least 15 minutes. Wipe cap dry. 3. Align slots (B) on cap with tabs (C) in opening. Turn cap clockwise to tighten.
Sep 17, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
The cleaner no longer vacuums up the water. I have to use the tool device to get the water up. marleneodlekemp@hotmail.com
Try the following suggestions to see if you can get your machine suctioning properly:
1) Remove the Tank-in-Tank Assembly and place your hand over the motor intake valve. This valve is located next to the Floor Nozzle gasket (at the top of the Floor Nozzle window) and behind the SmartMix Bottle. If you feel vacuum-like suction at this area, your suction power of the unit is working but air is escaping at some point. If there is no suction at the motor intake valve your machine will need to be inspected by an Authorized Service Center Technician.
2) It is possible the Floor Nozzle on your machine is inserted incorrectly. This would directly affect the suction of your machine. Please follow the directions below for removing and replacing the nozzle.
Before starting, please be sure the machine is unplugged and the machine handle is reclined.
To remove the Floor Nozzle window, first detach the Phillips head screws located at the base of the nozzle. Then, remove the Tank-in-Tank Assembly. Next, pull forward at the top of the Floor Nozzle window to release the tabs of this window from the receiving holes of the machine. This window is designed to allow access for cleaning.
When replacing the Floor Nozzle window, please be sure the tabs at the TOP of the nozzle are properly inserted into the receiving holes provided. If you do not have the tabs in place properly, the suction power of the machine could be affected.
Rotate the window down into place and replace the screws.
3) Ensure that the Ready Tools knob (diverter knob) is in the proper setting and the valve opens and closes freely. Ensure the black foam gasket is in place under the valve.
4) Check to ensure the Tank-in-Tank assembly is seated properly and that it is not full of dirty water. (If this tank has a drain cap, make sure it is in place and that it has a black o-ring).
5) Check the float and baffle to ensure they are properly installed on the Tank-in-Tank. The larger square portion of this part should be below the clear baffle of the tank with the red flag portion of the float resting on top of the baffle.
6) Check the Tank-in-Tank and lid for damage. Is the lint screen clogged? Make sure the lint screen is in place on the tank lid and not placed into the motor duct. Also, clear the holes on the lint screen.
7) Check to see if the upholstery hose has suction. If the hose has suction and the floor nozzle does not, check the diverter valve to see if it opens and closes freely. This can be seen through the Floor Nozzle window as you switch the diverter knob from the floor to tools setting.
Aug 11, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a steamvac v i was wondering if i fill the container of water to the top and does the water need to be cold or hot? I heard I could use tide liquid if so how much do i put in the detergent holder
Hi there SmartAlec from NelsonVacuums.com.au here. I have looked at literally hundreds of steamvacs over the years and you can use warm but not hot water in the tank. You cant use hot as it tends to slowly warp the plastic container and it stops sealing well. Also as far as i am aware you can NOT use any kind of detergent in a steam product. It will clog the steam jets very quickly and hey presto a broken steamer. Hope this helps.
Happy Vacuuming! :)
Aug 27, 2009 | Hoover Vacuums
I have a bissell proheat 8910 steamer and my red float fell out of the tank-in-tank. i need to know where it goes please. thanks!
the rounded part of the red float goes inside the bottom part of the tank in tank. If you push the bladder down with your hand you can see grooves on the inside of the bottom tank intnak. This is where the rounded part goes. the longer more straight part of the red thing sits straight across on top of the bottom unit on the straight edge. I honestly cannot remember how exactly I got into place but I finagled it in I am sure...
Mar 12, 2009 | Bissell 8910 ProHeat Clear View Upright...
Hoover V2 SteamVac
Under the detergent side, there is a metering plate,(located on the machine) which can be removed. ensure that this is installed. have you verified whether the machine will dispense detergent only without any water in the water tank?
Jan 03, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
My steamvac f5870-900 trigger mechanism isn't working
Here is a picture, maybe that will help:
Dec 01, 2007 | Vacuums
Tank Dispensing
Is the detergent tank cracked at the bottom, under the black seal? If so the whole tank asm. needs to be replaced. But if this is new, then it has a one years warranty on it and you can take in for warranty repair.
Oct 13, 2007 | Hoover F7222-900 SteamVac Upright Vacuum
Bissell 1697w Powersteamer
I have a similar model and occasionally have problems with water/detergent flow. I find it is generally due to an airlock in the piping caused by forgetting to turn the deregent water control off before removing the detergent container. Follow the manual instructions. Turn the knob to off. Fill both containers. locate them carefully. Make sure filters in the water tank and in the flow meter are clear. Start machine with handle laid flat and knob turned to maximum flow.
Dec 22, 2006 | Bissell 1697-7 Powersteamer Pro Deluxe...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
20 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
