Trying to find instructions on how to use on panasonic dvd
Check this link to download the user manual to your remote control.
SOURCE: URC-4041 Universal Remote
you may have problems getting any replacement remote to work here(or a code for any). The company is based out of China, contact details for them can be found at http://www.made-in-china.com/import-export/eJnQVugPRxZLprofile1/Chitech-International-Ltd.html.
You may be able to get a new replacement remote direct, Hope this helps. a "fixya" rating would be great for my time spent trying to get this info for you. Cheers :)
SOURCE: Remote code
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC4041
just right click and save as on the download links.
if this does not work you can try the search method,
you do
this by either holding down the device button eg: TV or if you have one
the "magic" button for three seconds, a light should then flash twice
to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For low price replacement remotes visit www.sparky-uk.com)
SOURCE: One For All URC-4640B00 Codes for Sanyo DVD Player
I found a downloadable PDF File of the manual and codes for this remote. Hope it helps.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=oneforall&dv=universalremote&md=urc4605access4&kw=&st=&ar=&dt=&so=&pg=2&file=others/one_for_all/urc4605-manual.zip
SOURCE: REMOTE CODES
here is the pdf link for the remote control code to 4640B00
