Question about Kenmore 24902 Top Load Washer
After the spin cycle, my clothes are still sopping wet.
I do not know if it is the belt that operates the spin cycle, or maybe a drain problem during that cycle.
  • 3 Answers
Yes, you are on the right track. Drain maybe clogged. Under the front door is a panel with 3 screws, remove the panel; then unscrew the white looking plug, it may be hard to turn if there is a bunch of **** in drain. be prepared to get wet. Once you have cleaned this out, turn the cycle knob to any position but spin, then unplug washer for at least 30 seconds, this will reset the control board.
Good Luck!
Posted on Feb 14, 2009
Clothes coming out soaking wet
put it in the spin cycle and if nothing is coming out the drain hose it is most likely the drain pump ....just a fyi some are easier than others to replace.
I don't see the make and model of this machine so to give you specifics I can't. just general directions.
also I would check under the dasher there is a screen under there if you wash DIRTY clothes and maybe add a case of dog/cat hair it could be restricting the flow but wouldn't stop it totally.
also another fyi if you do get to that point use a toothbrush to clean it as you don't want to poke any holes in it.
Hope this helps.
Jan 20, 2015 | Dishwashers
Why is my whirlpool auto load sensing washing machine spraying water while in final spinning cycle?
you could have a bad temperture sensor bad are water valve but first check an make sure the washer drain alway check your drain hose for clog are lint are trash in pump an last you could have a bad timer if you dont know how to check these call a applince service for repair ok
Dec 13, 2017 | Washing Machines
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
Clothes sopping wet at end of all cycles
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Frigidaire ATF6000ES Front Load Washer
GE Front load washer WBVHB240EWW. Approx 5 years old. Is not spinning water out of clothes. At end of most cycles clothes are sopping wet. Only speed wash and drain/spin seem to work correctly. Gets stuck...
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 17, 2010 | GE Profile WPRE6100G Top Load Washer
On one wash clothes came out sopping the next there was no water
Check the drain hose for kinks or blockage. The drain hose should be free in the drain pipe so air can get around it. The drain should be good enough to accept a lot of water all of a sudden without overflowing.
Apr 26, 2009 | Frigidaire ATF6000ES Front Load Washer
How can i fix my washer myself?
The washer will not ever completely drain according to Maytag. A certain amount of water stays in the outter tub for balancing the machine for final hyper-spin. However if the machine is not spinning all of the water out and your clothes come out sopping wet....read the long thread I typed out to another person earlier.....it's about 2-3 questions up on the same topic
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machine Problem
if this is a sears or roper or whirlpool unit then check the direct drive coupling, if it sound like it should be spinning but doesn't
May 17, 2008 | Washing Machines
Kenmore 24902 Top Load Washer Logo
223 people viewed this question
Sal De
fordexpert
Robert Rankin
