Question about Golden Technologies Companion II Travel Scooter
Reversing thumb controls
Does anyone know step by step how i can reverse thumb controls on companion 2 scooter
  • william32254 Feb 14, 2009
    THANKS. THEIR REPAIR GUY WILL BE IN MONDAY.
  • 10,865 Answers
Your authorized Golden Technologies, Inc. dealer can reverse the thumb lever controls so that when you push on the “left” lever, your scooter will move in the forward direction, and pushing on the “right” lever will move your scooter in reverse.
If you don't want to go to a dealer, any mechanic who is willing can make this adjustment for y ou. hope this helps.
Posted on Feb 14, 2009
How do you remove the forward/reverse assembly?
You will need to remove the tiller cover to see the assembly. Then you will see the screws to remove. Be sure to disconnect the batteries so you do not short out anything. Scooter Doctor App
Nov 05, 2015 | Golden Technologies Golden Mobility...
My golden companion 2 Gc 321 goes forward when i push reverse and goes reverse when i push forward
It sounds to me like someone has gotten inside & tampered with it, Cameron. Maybe they twisted the drive belt 180 degrees or something? Or rewired the motor backwards?
Aug 12, 2014 | Golden Technologies Golden Companion 2 -...
Sounds like the motor cables are in reverse at the controller. Check that the red is in the positive and the black wire is in the negative on the controller.
No forward or reverse. lights and horn work micro switch on brake has continuity with brake off batteries charged and all connectors reseated. Motor spins forward and reverse when voltage appled...
Joe with a scooter there can be a number of things wrong to cause your problem Since the motor turns and you have power at the console. It could be the throttle pot or the speed pot or both or it could be the cable that runs from the console to the rear of the scooter and finally a problem with the controller. But that would also give some sort of error to the console light if it is equiped with a power light. If Medicare paid for your scooter then they will pay most of the cost of repair. Your provider can work on it for you or they can contact a repair service that will fix it for you Hope this helps
Sep 27, 2010 | Golden Technologies Companion II Travel...
Golden Companion Scooter not moving - diagnosed via owner manual
Hi. Many scooters will display this fault code if the potentiometer is not exactlly centred when you turn on the key. The pot is not always faulty. Some scooters also have a smaller additional pot to controll the speed. If this pot is faulty it will cause the same fault code. Any other switches such as indoor/ outdoor switches. I have had a few machines fitted with curtis controllers where the fault is in the controller.
Check the wiring and plugs and connectors.
Good luck. Neil.
May 09, 2010 | Golden Technologies Companion II Travel...
We have an scooter an this scooter have an electronic's device's have self diagnostic an this scooter dont work an 7 times the green led is flashing an stop an repet again the cicle. we want know what...
If the batteries are charged and the brake is in the drive possition, it is possible that either there is a problem with the Wig Wag (forward/reverse paddle control) or the speed pot. Some ideas for you to look at.
Nov 10, 2009 | Golden Technologies Companion II Travel...
Goes in reverse but not forward
hi, that sounds like the scooter
a. the speed pot is faulty (Wig wam) thumb throttle , check just in case there a reverse switch,
b. been taking apart and reassembled incorrectly.
Regards
GeWiz.
Jul 03, 2009 | Pride Mobility Victory 3 Wheel Electric...
How to dissasemble golden companion II
Companion-2 scooters. Remove seat by holding up on seat lever and picking up seat at the same time. Then remove bolt from seat post and remove seat post. Remove rear cover. Unplug and remove batteries.
Jun 29, 2009 | Golden Technologies Companion II Travel...
Golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ lxrixta.co.uk (remove the spaces)
Mar 23, 2009 | Golden Technologies Companion II Travel...
Golden Technologies Companion II Travel Scooter Logo
317 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
