Kenmore EnviroSense 85501 Air Purifier
Problem for Kenmore EnviroSense 85501 Air Purifier
The Kenmore air filter will not turn on.
By eileen1025 on Feb 14, 2009
We have unplugged it, cleaned out the filter, tried a different outlet, nothing works. It will not turn back on.
Solution #1
posted on Feb 14, 2009
Somewhat Helpful)
jgwhomeequip
Rank: Guru  Kenmore Expert
Rating: 86%, 755 votes
Check the switch and make sure that it is getting power. You can also disconnect the connectors to the swiitch plug the unit back in and touch them together if that works then you know the switch is bad
Was this helpful?
Yes
No
Popular Solutions for Kenmore EnviroSense 85501 Air
Questions and Unsolved Problems for Kenmore EnviroSense 85501 Air
Do you recommend Kenmore EnviroSense 85501 Air Purifier?
Answer
Answer
I need to replace the two bulbs, for the Airmaster Ultra air purification system. I will not use the... (More)
Answer
I can't seem to locate the replaceable filter element(#85511). Any help?
Answer
We have an EnviroSense True Hepa Air Cleaner 85500. You turn it on and it comes on for about a... (More)
Answer
just changed filter on the 85501 and the filter light will not turn off
Answer
I replaced the air filter for the first time today. The purifier runs now but none of the indicator... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore EnviroSense 85501 Air...:
Top Air Purifier Experts
Rank: Guru Guru
Solutions: 2528
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Air Purifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
