Question about HP Pavilion a450n PC Desktop
My hp a500n will not turn on
My pc won't turn on. the switch won't light, but there is a green light flashing in the back. We recently had a power outage,but the computer worked after that. I have the side open and tried to follow similar fixes,by trying to unplug and plug in diff. components but the wire colors seem different from the explanation given please help
  • 2 more comments
  • annanicole1 Feb 14, 2009
    I tested the little flat battery and it seems to be working,but the pc isn't thanks
    is the memory the the card about 4.5 in long if it is yes i pulled it out and still nothing oh and the power supply is also ticking when i have it plugged in
    thanks for all your help I was thinking it was prob. going to be the psu thanks again
  • mr jacoma Mar 16, 2009
    My pc has been unplugged for 2 weeks.. now when i plug in the pc ..the blue light on the front panel doesn't come on at all, but a green light on the back of the pc starts flashing..also when i plug the power cord in the wall outlet it makes a little spark.I'm not sure if it's the power supply or the motherboard..
    President:
  • 1,902 Answers
Check your BIOS battery make sure it is working correctly and that it is not out. You can use a battery tester to see.
Posted on Feb 14, 2009
  • 2 more comments
  • Jeremy Reddick
    Jeremy Reddick Feb 14, 2009
    I know that your PC isnt, but that battery can cause you problems. HAve you already tried to reset your memory by pulling it out puttung it back in?
  • Jeremy Reddick
    There are only two things that will cause your computer to turn on with a green light on the board. that is a bad motherboard or a bad powersupply.
  • Jeremy Reddick
    Ok well that is alot more helpful. You have blown your power supply. since it was cause by a power outage they will cover the price to replace it. If it was a brand new on then take it back and say it doesnt work. Makeing a ticking sound if very bad so you need to replace it.
  • Jeremy Reddick
    Not a problem please rate if you are satisfied and thank you for using FIXYA.com
HP Pavilion a 1250n won't turn on. Green light is on under the plug in the back but noghting else.
If the monitor power light is on or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
Sep 22, 2012 | HP Pavilion a1250n (EG194AA) PC Desktop
Cant find speaker outlet
The correct mini jack on the back of the computer for stero is the light green mini jack.
Feb 17, 2012 | HP A500N PC Desktop
Hp pavilion a705w - blue power light flashing, won't turn on
On the back of the power supply there is a 120/220 V AC selector switch.
It's possible that switch got knock on the wrong voltage position.
Pull the power cable. Move the switch back and forth between the two position.
Make sure you leave the switch in the correct selection. 120v = USA
If you have time,open the case and inspect the RAM module(s) and card(s). They can be un-sitted.
plug in power cord and power on the pc.
Jul 29, 2011 | HP Pavilion a705w PC Desktop
I have an HP Pavilion a384x. It will not turn on
First with the computer turned off make sure the switch on the power supply is set to 115v.
If you turn the computer back on and you still get a flashing green light on the back of the power supply and a constant light on the front of the computer with no video, then try replacing the power supply with either a new one or a known working good one.
If that doesn't do it then it has to be the motherboard at that point.
Keep in mind normally on those power supplies, the green light should be constant. So it has to be either the power supply is bad or the moterboard is bad and you'll know when you put a new or known good working power supply in the computer.
Aug 03, 2009 | HP Computers & Internet
HP Mod a500n PC, flashing green ps light
Your power supply is fried. I had the same problem with my Bestec ATX 250 power supply. I fixed the problem by installing the StatTech model: ATXPOWER250. It was easy to install and works well. It is almost identical to the original but more quiet. I got it for $29 at MicroCenter.com. Also at online Newegg.com, Radioshack.com, Provantage.com, June 20,2009
May 20, 2009 | Bestec (ATX-250-12E) 250-Watt Power Supply
Pc didn't start,flashinh green light in the back..I disconnect all inside and the green light is solid now,.How I can check my motherboard?
Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. The dead giveaway is the fact that you are not getting a monitor signal and if you listen to your computer as it starts up, a few of the devices may not start (hard drive, etc). Mobos are usually expensive to replace because the computer makers have them made especially for them and only order so many. They usually do not have a lot of extras laying around. There are a few companies that will repair broken capacitor issues. Hope this explains why they can fail. They can also fail if overheated (like when a case cooling fan fails), the cpu is overclocked and not cooled down (which raises temps), the power supply fails or by lightning and power surges. Also if you add a bunch of extra components without upgrading the power supply you can suffer underpowered situations.
If you can get another power supply unit then you can try that first. Usually when the condition you describe happens it is either the motherboard or Power Supply. If you replace it with another PSU then you have to have at least the same or greater output watts.
Apr 24, 2009 | HP A500N PC Desktop
I got hp pavilion pc the problem is its not switching on there is a green light back of the pc it keep flashing what i ve to do My HP Pavillion will not come on and the green light at the back keeps...
if your network cable is plugged in it will flash green .....if it won't turn on pull the plug and wait 10 seconds or more then plug in again and see if it will start .....are the fans running and no signal to monitor?
Jan 06, 2009 | HP Media Center m1180n PC Desktop
HP Pavilion a450n PC Desktop Logo
451 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
