Question about Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
Syncmaster 913v color problem
I have a Syncmaster 913v and I came home from school and turned it on and everything seems to have a blue tint to it...I don't know what to do. Please help!
    Master:
  • 461 Answers
Appears to be something in the connection. Check the video cable and pins on the video connector. Also verify the color settings have not been changed on the monitor. There should be an area where you change the RGB levels.
Posted on Feb 14, 2009
No picture
The problem can be caused by bad caps in the power supply, bad inverter circuits, worst will be bad lamps. Look inside for bad caps first, report back what you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 28, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung lcd 913v self test ok, no image when vga connected
This problem often occurs in samsung SyncMaster LCD monitors.
The solution is open your look for the LCD monitor power supply module (which have PCB connector to the AC power), on that board look for capacitors, now look for broken one which upper part is bloated, like the image below:
If you find a damaged capacitor as in the picture then you should replace it with the same value.
Jan 22, 2010 | Samsung SyncMaster 913V 19" LCD Monitor
I can't seem to correct a tint problem. The tv turns on and the tint doesn't change. A friend says it could be a vidoe card?
Go to menue on controller, then Picture, then adjust Color and Tint to you taste. The color ajusts Blue and Green move left more blue move the slider right more green. The Tint controlls red. More red move right less left. Also chech Color temp setting.
Nov 08, 2009 | Akai PDP4225M 42 in. Plasma Television
My monitor now has a blue tint to it and everything i put onto the monitor has a blue tint i tried to fix it by changing the colors but it doesnt help
Looks like u have lost one or more of the color channels (RGB) make sure the video cable is plugged in securley (both ends computer and monitor) and locked down with the screws, restart the computer and monitor.If this fails check video card and then monitor, can u plug the monitor into another computer this will determine if the monitor is ok or not. If monitor is ok then problem most likley will be the video card.
Sep 02, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Samsung monitor syncmaster 913v
Either you messed badly with the system color profile management, or, more likely, the VGA cable is faulty or improperly seated. Try unhooking the PC end of the cable (and, if you got yourself a model with removable cable, also the monitor end), and hook them back again, seating the connectors gently but firmly and tightening the connectors' retainer screws.
Aug 24, 2009 | Samsung SyncMaster 913V 19" LCD Monitor
Syncmaster 913v
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Oct 26, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Everything has blue tint
call the Insignia help line at 877-467-4289
Apr 29, 2008 | Insignia LCDTV26 26 in. Television
Monitor is blue-evrything has a blue tint-i can see colors,they just have a ble tint
I've found that strange color tints are usually the result of a loose cable connection, either at the computer end of the monitor end.
Try unplugging both ends, and then replugging both nice and securely (might even try reversing the direction of the cable, if it is a simple VGA-VGA cable).
Feb 27, 2008 | Computers & Internet
Pinkish Color on Monitor
Most likely it is your VGA cable gone bad. I remember doing a warranty call for HP once, I was the third tech to go out and replace a motherboard. When I got there, I found out that the cable was bad and it was giving everything a blue tint. I would certainly recommend replacing the VGA cable. I bet if you wiggled the VGA (monitor) cable on the back of your computer, it will come and go.
Jun 09, 2007 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
249 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
