Question about Panasonic Toughbook CF-51 Notebook
Computer suddenly turns itself off.
Computer will suddenly turn off when cooling fan starts. sometimes it must be restarted 3 or 4 times before it will complete loggon.
  • David Sciara Sr
    David Sciara Sr Feb 14, 2009
    Yes when in use. It seems to do it more often if not on ac power. After it turns itself off, it will turn off at startup several times before it will start up completely. It seems to power off when the cpu fan starts.
  • Aenim4 May 11, 2010
    does it ever do it when in use? or just when powering on?
    Scholar:
  • 53 Answers
Your best hope is that the CPU heatsink is dusty and the CPU is overheating and therefore shutting of for thermal protection.
Try to clean it deeply with canned air caring not to short the fan speed sensing with the condense caused by the expanding air(do not hold the nozzle too close to the fan).
If it keeps doing it, then it's probably because of the motherboard's voltage regulator and you need to replace the motherboard or at least the voltage regulator if it is not on-board(usually it is onboard.)
Posted on Feb 14, 2009
I have a ~4year old Dometic RV refrigerator that does not start cooling when started after periods of being shut off (as little as 2-3 days). When I turn it on I can hear the fan start but after 2-3 hours...
ammonia absorption refrigerators need continuous heat either by
a heating coil powered by a transformer or, a propane flame
check/replace your gas thermocouple or, transformer to the heating coil located on the refrigerator back
Aug 21, 2013 | Refrigerators
2004 mazda mpv engine racing and cooling fan not working
coolant temp sensor tells the computer how hot or cold the engine is so it can regulate the idle and fuel mixture, when it fails there usually is no cooling fan and you will have trouble starting the engine and keeping it running.
Oct 08, 2012 | 2004 Mazda MPV
Dell pc turns off sometimes for no reason
If the systems overheats, then the pc turns itself off to prevent damage.
Your computer needs to be kept cool. Clean the fans and install more fans if possible.
Take care!
damnor01
Aug 05, 2012 | Dell Computers & Internet
HP Pavilion zv5000 Turns off every 10 mins and restarts itself?
When the computer is on try using that computer cleaner compressed air that comes in the can on the fan that is not working. If you hit it with the compressed air and get the fan to spin and then it starts to spin on it's own the fan could be sticking. This will cause overheating and the computer could shut down like it's doing. Also does it do it when the battery is on or a/c power or both?
Sep 08, 2009 | CMB T43 750 Notebook
Latitude d400 suddenly starts turning itself off
Could also be a virus, some viruses shut the computer down. Try downloading avg free edition from http://free.avg.com
Otherwise you have to take it apart to check the fan etc
Jun 21, 2009 | Dell LATITUDE D400 D500 D505 D600 D800...
Condenser fan running backwards on heat pump
I am having the same problem, sometimes it runs in the wrong direction, blowing the air down. Sometimes something gets tripped and I need to turn the thermostat to off and wait a bit then restart it. If I am lucky it will run int the correct direction and also will warm the house. Sometimes it send nothing but cold air to the house's forced air.
Jun 13, 2009 | Goodman CKL24AR24 Air Conditioner
Sometimes my computer restarts suddenly.
this problem is due overheating, and you say yo have a C2D with this mobo.... at intel site it said that this mobo works fine with intel P4, Pentium Duo an Celeron but not C2D. Its true that you have 800Mhz FSB and it will detect the micropro.... and work fine but the C2D will overheat the mobo for its need of energy and overheat it so it start restarting. I dont know how much that mobo is going to last but start installing all cooler you can....the mission is to cool down that mobo and micro...
Nov 29, 2008 | Intel D101GGC Motherboard
Lenovo laptop shutdown suddenly after working for a while
Hi James, replace the fan or If it's still under warranty have it serviced. Suggest you stop turning it on until the fan is replaced. It could be the fan cooling the CPU. You don't want it to fry.
The shut down process is normal when over heating is detected by the system.
lenovo link. http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-63446
Mike
Mar 24, 2008 | Computers & Internet
Panasonic Toughbook CF-51 Notebook Logo
357 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
