Question about Cerwin Vega IT-15.0 Car Subwoofer
Box dimensions for 15 in cerwin vega
I need the box dimensions for a single 15 inch sub
  • 74 Answers
Do you want the box ported or unported (holes or no holes) if you don't got a lot of room than you dont want a ported box. keep in mind the box has to have the correct amount of cubic air space or you could seize your sub... if you're building it make sure you use OSB board (oriented strand board) or MDF board(medium density fiber) your sub needs .7cubic feet of air space in an unported box
Posted on Feb 17, 2009
    Sergeant:
  • 290 Answers
Actually, for a 15", a sealed box would need to be closer to 2.5 cu. ft. Go to the Cerwin Vega site and find your model sub (if it is listed). The specs for that sub should give the recommended sealed and ported box volumes.
Subwoofers
Posted on Oct 28, 2015
Need a wiring diagram to hook up two 10 inch subs and 15 inch sub a kicker 250.1 amp
Series or parallel? Single, dual voice coil? I'm not sure you have the right size amp for all 3 speakers. And I wouldn't wire the 10's together with the 15. The larger sub is going to have a larger power demand. You could wire the 2-10's together on this amp, and get another mono amp for the 15.
Oct 02, 2014 | Car Audio & Video
Would a 10ZX750.1 amp be alright on a Single Solobaric L5 10" inch in a ported box???
yes, the 10ZX750.1 is capable of running two L5's at two ohms in either a ported or sealed box. Just be sure to wire it up to suit your needs correctly (if you need to know how i can help) and make sure that your box dimensions match what kicker specify. the L5 is actually one of the subs that kicker reccommend for that amp.
Hope I helped , and please dont forget to rate.
cheers
Jan 15, 2011 | Kicker Car Audio & Video
15PLB76 15 Inch 800 Watt Woofer Car Speaker: what subs will be good to fit in my gmc sierra sin...
single shallow with a sealed box it would sound great!! no air tombs they **** thats called ported they really ****
May 17, 2010 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
What is the best enclosure volume for 15" Juggernaut 2000watts rms car subwoofer. i want to know the dimension of the box along with ports size.
Subwoofers differ in only one way. You get an "Open Air" and a "Closed air" subwoofer, That being said, you'll have to check on your magnet which one you have to make the boxes for that sub. If it is an "Open air" Subwoofer, you should see a "wire mesh" or "grid" in the centre, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.
If it is a "Open air" sub, your boxes should be sealed with silicone, and no ports are to be cut in your box.
With "Closed air" subs, you should have 2 ports below your sub and the port sizes should be around 50mm in diameter. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require.
On a 15 inch subwoofer ranging between 80Hz and 120Hz, the box size required should be around 27 liters, meaning that you will end up with a box of 16 inches high, x 16 inches wide, x 16 inches deep. Or 320mm high, x 320mm wide, x 320mm deep.
Enjoy!
Dec 01, 2009 | Mmats Juggernaut 15'' Car Subwoofer
I have a circle 15'' sub woofer and i need the dimensions of the hole to cut
Draw a pattern of the sub on the box then take 5/8 of an inch off the inside,that should let it slide in easy.
Oct 26, 2009 | Car Audio & Video
15" Lanzar 400 watt sub
you would have to build a ported or sealed box with a sloped back
Sep 19, 2009 | Lanzar OPTI1222D Car Subwoofer
2 15" and a 10" sub
10" subs need 1 cubic feet. 15" subs need 2.5 cubic feet. install them on its own volume of the box...
Jul 17, 2009 | Cerwin Vega IT-15.0 Car Subwoofer
What is the sealed and ported box volumes for the audiobahn dub 200 subs?
If you can access the inside of the sub box by removing the speaker, you may be able to measure the 3 dimension of each side of the enclosure.  1 cubic foot is 12x12x12 inches cubed.  That is 1728 cubic inches per cubic foot.  If you measure the inside dimensions of one of the enclosure sides as 10x14x8 inches, then that is 1120.  1120 divided by 1728 is 0.648 cubic feet.  Alternatively, you could estimate the volumes of each side of the box by measure the outside, figuring out where the box divider board is, subtracting the width of the boards used to make and then calculate.  Otherwise, I do not know the enclosure that that sub comes in.  Good luck.  Let us know how it goes.
Jan 02, 2009 | AudioBahn DUB200 Car Subwoofer
Box dimensions
I've Got The Same Subs, I Got A Formula On The Net, Its Dimension Is Aprox 9 D X 24 H x15 W.
Although I Have Them In A Home Made Ported Box I've Made, Its Dimensions Are 8 D X 23 H X 17 W And Its Sound Pretty Damn Good. I Have A 2 Inch Round Port X 6 Inch Long. The Formula Says I Should Have A 3 Inch Long Tube.
Feb 23, 2008 | Volfenhag ZX-4712 Car Subwoofer
Cerwin Vega IT-15.0 Car Subwoofer Logo
3,651 people viewed this question
Top Cerwin Vega Car Audio & Video Experts
xxxxxx xxx
Are you a Cerwin Vega Car Audio and Video Expert? Answer questions, earn points and help others
