Hose on whirlpool washing machine
I just took apart my whirlpool washer to replace the motor coupling. I have it almost all back together...but i have a LONG CLEAR hose that is attached the outside of the plastic agitator tub....
WHERE DOES THE OTHER END ATTACH TO???
HELP :)
Thanks, LORI
  • Imanokie Feb 14, 2009
    Well, it would help if i had ever seen the inside of a washing machine before! haha
    Im a fix-it queen....but this is my first experience with a washer. :)
    I looked at it and i dont see a pump anywhere on it, but that clear tube is attached to a lump on the lower, outside of the plastic tub (is that the pump?)
    I just cant remember where i pulled the other end of the hose from....Im a full time college student and this washer was a 2 day project.....I shouldve taken notes! :)
    GOT IT! I hadnt replaced the control board yet which is why i couldnt find where the end went!!
    THANK YOU THANK YOU! :)
    I just tried it and IT ALL WORKS!!! Now i know how to replace a motor coupling!!
    Thanks for your help!! :)
    LORI
    President:
  • 1,902 Answers
To the pump at your drain line. up top.
Posted on Feb 14, 2009
  • 1 more comment
  • Jeremy Reddick
    Jeremy Reddick Feb 14, 2009
    If this worked please let me know. Rate me also please if this worked
  • Jeremy Reddick
    Yes that is the pump. Then the hose goes all the way up top at the control board. You are going to have to remove the top cover to get behind your knobs to get the hose plugged in
  • Jeremy Reddick
    You are welcome. Please rate on the assistance that I gave. And thank ou for using fixya.com
Whirlpool washer fills and then does nothing else. Replaced lid switch.
See if there is 120VAC at the drive motor while the machine should be agitating... if you have voltage, but no movement, replace the motor. Sometimes, the neutral connector on the motor plug will fail and there will be a brown spot on the white plastic "molex" plug. Whirlpool Washing Machine Drive Motor WP661600
Mar 30, 2017 | Whirlpool Washing Machines
Washer agitates but will not spin drain spin or fill
Well I have a Roper Top Load Washer, bought it in 1998 ,no problems til back 6 years ago we had someone come fix it. My problem was the same wouldn't drain or spin. The problem was it was clogged, in the front when you lift off the washer casing theres a white piece connected to to tubes that drain. well there was my daughters pair of underwear in there and a couple small socks. He took them out put it back together and worked ever since. Until earlier tonight we had same problem so we took it apart ourselves and found my boyfriends sock in there took it out and put it back together and works great again. So far so good. Hope this helps Good luck. Tammy
Nov 05, 2010 | Whirlpool LSR8433K Top Load Washer
My washer did not spin agitate or pump. When I
you could have 2 problems,, first one- the motor bearings could be locked up-or the motor could be burnt--if so you would smell it--
2.you could have something logded in side the pump fan--the older models you can take apart & dislodge the item--the newer ones have to replace the whole pump..
Aug 01, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I took apart my kenmore seires 90 washer not knowing what i was doing. i took out the tree bolts holding the transmission on and a c-clip holding what apears to be brake parts. how do i get it back...
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
The brake is a part of the spin tube.
The clip you removed is probably for the clutch.
Also see the following Whirlpool Service and parts manuals for their top load, direct drive washers.
WHIRLPOOL PARTS SITE
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/
$FILE/787772%20%234.pdf
I' d also suggest the Sears parts site.
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Welcome to the wonderful world of washer repair.
Mar 01, 2010 | Kenmore Washing Machines
F 02 Error code, took apart and found 2 small
WHAT DID YOU TAKE APART AND FIND THE NAILS? WAS IT THE PUMP? SOME MORE NAILS MIGHT HAVE GOTTEN BACK IN THE PUMP OR THE PUMP IS DAMAGED.
Feb 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Clutch Problem
H i there.........it sounds as if your incorrectly assembling the clutch ....there is a diagram with the new clutch....no its part of the assembly
regards Sir Galahad
Aug 20, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II drum does not spin.
Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool toploader gearbox/clutch removal
Last Night I took the machine apart to find clutch/brake assy ok gearbox was also ok then I noticed shaft coupling was different than new part I had in stock, new part made totally of nylon, old part fitted to machine has steel insert built into nylon. this was not fully located onto motor shaft and the first 1/4" of motor shaft had been stripped back to round ( no flat faces) also inside the steel lined bore of the nylon coupling had been worn to round.I replaced with new coupling of nylon and ensured both nylon parts fully pushed home onto motor shaft and gearbox shaft with any freeplay / gap being allowed in the rubber drive link. This has worked for now but expect trouble in future with worn motor shaft.
Oct 17, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
My roommate removed the water in hose and I need to find a manual to put it back together
starslight07 You can find the repair manual for your washer here: http://tinyurl.com/32d5lu Good luck. Gendos
Jul 06, 2007 | Whirlpool LSR9434PQ Top Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
