Question about Toshiba Satellite A105 Notebook
Trying to connect laptop to tv
I have a samsung tv that is connected to a dvd player via an RF modulator. Its OK to play dvds on the tv. They both have s video inputs. So does the laptop (compaq v 2000). How do I play a movie in the laptop and see it on my tv? The RF modulator does not come on unless the dvd player is on. All 3 devices have the red, white and yellow cables (except the laptop).
    Scholar:
  • 53 Answers
You need a s-Video splitter that has the round PS2 style connector on one end and the yellow colored plug on the other, you can find it on the internet or in an electronic supply store.
then you plug it in the PC and in the modulator.
then you set up an external monitor on the svideo out. and it should power on the modulator and have signal.
quality though is fairly low...
you need a splitter for the 3,5mm audio jack to use the TV audio.
Posted on Feb 14, 2009
I went s video out of dvd player into rf modulator video converter to rca cabels from modulator to tv and still doesnt work
It sounds like you have got the cables mixed up. You need to plug the output of the modulator into the aerial connection on the TV. The idea of an rf modulator is to let you connect a source into a TV via the antenna connection on the TV.
Mar 21, 2016 | RCA Televison & Video
Tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
on Aug 17, 2010 | Audio Players & Recorders
Cannott get a picture on my tv from my DVD/VHS COMBO
Your DVD player should be connected to either the Yellow White Red connections on your TV set (same color to same color -- dvd OUT to tv IN )
OR it should be connected using the RF cables and connected inline AFTER the Direct TV Box....the box would block the DVD; and possibly the Direct TV Master box would apply 19 Volts to the DVD modulator....destroying the modulator.
Always OUTput to INput on the connections...
Also try with a new set of connections. make sure all the ports are ok.
Hope It's resolve all Problem,
Or
Still having Problem Then follow Us For
Tech support
Feb 07, 2014 | Televison & Video
I'm trying to hookup my Toshiba DR430KU to an older tv that require an RF Modulator. I get a skewded sideways picture. Does This DVDR compatable with a RF Modulator?
Probably not. Better picture results are achieved with either S-Video, standard RCA AV cable (yellow-white-red), or YUV component cable (red-green-blue) (component output does not have audio - this requires extra cable to be connected). The video via either one of these 'AV' connections is stunning (based on a standard 16:9 LCD TV using a Panasonic DVD recorder).
RF tends to be lower quality - as opposed to AV/digital input. AV input/YUV component handles digital better. No one connects their DVD devices to their TV via RF (either directly to the antenna socket or with a modulator/attenuator) anyway. Because a VCR is mostly analogue, it will work fine with an RF connection, but DVD is digital, and so won't work as well, if at all.
RF also goes through the tuner in a TV, creating cross-interference, whereas AV is a direct input and is separate to the tuner.
I would say an RF modulator would not be designed to handle the output frequency that your DVD device generates. Throw the modulator out, or perhaps get another TV, or use RCA cables instead if the TV has AV inputs. Whichever is cheaper and easier, but don't use RF accessories except a standard antenna if/as required.
Apr 27, 2011 | Toshiba DR-430 DVD Recorder
How do you hook up the dvd player to the tv with a vcr hooked up to the tv
Leave the cable box powered on but disconnected from the TV or VCR. All other components should be disconnected and unplugged, giving clear and easy access to all connections. If components sit in an entertainment unit, make sure all A/V cables can reach the RF modulator and the cable from the modulator can easily reach the television.
  • Step 2 Hookup the first coaxial cable from cable box output, usually labeled "TV," "TV out" or "Out to TV" to the cable "In" on the VCR. Connect the second coaxial cable from the VCR's out to "TV" to the coaxial input on the RF Modulator.
  • Step 3 Connect the third coax cable from the coaxial cable "Out" jack on the RF Modulator to the coax cable "Input" on the television.
  • Step 4 Take one A/V cable, connect the red (right audio channel,) white (left audio channel) and yellow (video) from DVD player's "Output," to the corresponding DVD "inputs" on the RF Modulator. Place components as desired but still disconnected from power. Plug in all power cables including the RF Modulator's into the surge protected outlet strip.
  • Step 5 Make sure the Channel select switch usually found on the back of the VCR and the Channel select switch on the RF Modulator are both set to Channel 3. This channel is used on the television to view your components.
  • Step 6 Turn on the power strip and turn on the TV. Cable reception should come on as usual. Set the TV to Channel 3 and turn on the VCR. With VCR on test it by playing a video tape. The RF Modulator should sense the signal and automatically switch to "VCR."
  • Step 7 Switch off the VCR and with the television still on channel 3, turn on the DVD player. As the RF Modulator senses the DVD player signal and switches to DVD, its welcome screen should be seen on the television. Play a DVD to test and once you're done with the DVD turn it off and the cable should come back on.
  • Jul 15, 2009 | Televison & Video
    Brand new DVDs will not play in Samsung Progressive Scan v3650
    If you're trying to play through to your TV through the RF out on your combo unit, it's probably the copy protection that's stopping the playback. Try through the composite/audio jacks.
    Jan 04, 2009 | Samsung DVD-V3650 DVD Player/VCR
    Dvd player not connected properly to TV?
    You might need one or both of:
    RF modulator.
    AV switch (perhaps from an old video game console)
    The modulator accepts the RCA plugs from your DVD player (yellow, white, red) and outputs an RF signal.
    You can then plug the ouput of the modulator into the aerial input of the skybox, via the switch, if desired.
    Sep 28, 2008 | Cyberhome CH-DVD 300 DVD Player
    I have a Samsung 1080P 7 DVD player and Samsung LN-T4071F television. I have them connected via an HDMI cable. Nearly all, if not all DVD movies I play get to a certain point and the picture starts...
    If you have changed the DVDs and the problem is still there, then the problem can only be the DVD player.
    The symptoms you describe cannot be caused by the TV or the connection.
    May 19, 2008 | Samsung Televison & Video
    Zenith xbr716
    ALL cable is digital.
    What type of TV do you have? Does it have any scart conections on it? If not connect the Cable box with a scart lead to your VCR select the AV channel on your VCR, connect your VCR to your TV via the RF connection, (if it has not got one, its not a TV, its a monitor). Tune your TV in to the video channel.
    You do not need an RF modulator for a home TV setup, whoever told you that is a fool.
    Dec 28, 2007 | Zenith XBR716
    Toshiba Satellite A105 Notebook Logo
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
