Question about Whirlpool GGQ8831L Gas Dryer
How do I open up my Whirlpool dryer(no kickplate) to test ignitor
My dryer has no heat and I'm trying to test the various variables but I can't get to the ignitor to test with my ohm reader?
  • JohnCY Mar 01, 2009
    What troubleshooting steps should be taken to determine why my Whirlpool Dryer (gas) Model # GGQ8858EQ0 is operating, but with no heat?
    Please advise,
    John
    President:
  • 1,902 Answers
You can to the ignitor from the back panel. Remove the back panel screws and away you go. Thank you for using FIXYA.COM please rate
Posted on Feb 14, 2009
Whirlpool dryer heating sporadically?
Remove the lower front panel and turn dryer on. The ignitor should glow bright orange first. After Ignitor glows brightly the next thing will be the flame lighting as the gas valve opens with a click. All this should happen within about a minute or so.
If flame comes on but goes off quickly It's likely one of the Gas valve coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The coils are purchased as a kit.
If ignitor goes off and no flame comes on the coil kit is likely needed because one coil is fully broken inside its case. If flame goes on but shuts off shortly the problem is as described above and the kit is needed.
There is a flame safety assembly on the can above the burner. If the airflow is poor. the flame tip may activate that safety and turn the flame off. Or the flame switch may be open and not allow the flame to come on at all.
The Flame switch can be tested for continuity with an ohmeter but the valves may ONLY show bad with power applied and can not be tested with a meter as they will test good.. Good Luck
Nov 18, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
Whirlpool dryer(LGQ9557HQ0), ignitor ignites but flame does not light
mounted on top of the gas vavlve is black electrical coils when energized it opens the gas valve,if one of the coils are defective it wont open and let the gas thru,its hard to test the coils so most repairmen just replace them all
Jul 07, 2008 | Whirlpool Dryers
I have a Whirlpool Gas Dryer Model LGR8648PWO that will not heat
You will have to remove the back panel to access this part. Be sure that you unplug the machine before starting. Once the back panel has been taken off and placed aside the thermal switch will be located on the left lower side near the blower housing . It will be thin and long and located near the cycling thermostat that has for prongs on it. On certain machines, the thermal fuse is located in the front. To access this you must remove the kickplate, which can be done by pushing the clips, one on each side jsut above the top of the kickplate, in between the top and abottom portion. The part numbers are the same for either style dryer. To test this part you can either take the wires off it and tie them together then plug the machine back in and see if it heats, or you can use amultimeter and check to see if there is continuity, if there is its good, if not, bad. The thermal fuse will usually be white, and if located in the back, be thin and long with two wires on it, left and right. If in the bottom front, it will be front center on the exhaust duct. In some cases the ignitor or the gas coils will go bad. Here is a good process of elimination.
1)Verify that the thermal fuse is good. If you don't have a meter bypass it and turn the machine on. If heats, thermal fuse is bad, if not leave connected and continue
2)When the dryer starts and thermal fuse bypassed, the ignitor should start to get hot and glow, if your thermal fuse is in the back you are going to have to have to the top of the dryer up to see down inside near the front for the glow. You can do this by taking the lint trap out and removing the two screws and popping the top up. If the ignitor comes on more than likely the gas coils are bad and if it doesn't the ignitior is bad. (this is while the thermal fuse is bypassed so the ignitor has power to it regardless)
Jun 04, 2012 | Whirlpool LGR8648 Gas Dryer
Whilpool gas dryer mod. AGD4475TQ2 No heat
May 28, 2012 | Whirlpool Dryers
Gas dryer wont heat. good ignitor
The thermal fuse is bad, the part # is 3392519. This part is located at the back of the machine on the lower left side. You will need to remove the back panel to access this part. Be sure that you unplug the machine before starting. On certain machines, the thermal fuse is located in the front. To access this you must remove the kickplate, which can be done by pushing the clips, one on each side jsut above the top of the kickplate, in between the top and abottom portion. The part numbers are the same for either style dryer. To test this part you can either take the wires off it and tie them together then plug the machine back in and see if it heats, or you can use amultimeter and check to see if there is continuity, if there is its good, if not, bad
Apr 28, 2012 | Whirlpool Dryers
My dryer will not heat up. I took the machine back off and could not see a flame when the machine is turned on. How do I get to the burner? Do I need to take the drum out? Any diagrams would be...
You remove the kickplate in front on most models. 01209c1.jpgThe first thing to check it the flame sensor. It must have continuity to turn on the ignitor.333fe98.jpg
The ignitor must have continuity also.4f11e40.jpg If both of those are good you want to look for an open thermal fuse/limiter. Duet dryer manual
OLD school whlp dryer training manual
Oct 06, 2010 | Whirlpool Dryers
Have a Whirlpool Gas Dryer - model # lgr7646a spins but no heat
Thre is no pilot light. This dryer uses an ignitor (glow bar or coil).
Open the lower front "door" (small access door) and turn on dryer.
If the ignitor does not glow (bright orange), then the ignitor needs to be replaced ($60).
If it does glow, then the gas valve needs replacement ($60).
If it isd the valve, the internal spring is stuck. Do not try to repair it, you must replace it.
Sep 25, 2009 | Whirlpool Dryers
Dryer stopped heating
OK, there are two likely scenarios, depending on whether your dryer is electric or gas. If it is an electric dryer, an open heater element is the most likely cause (change left in pockets is notorious for blowing out heating elements).
If your dryer is gas, the most likely cause is an open ignitor. Whirlpool, GE, and several other makes use a resistor type of ignitor which will burn open with time. It's an easy fix, easy to get to and readily available at most appliance parts stores.
Jul 13, 2009 | Whirlpool Dryers
There is no heat being produced
HI, Remove the front lower panel. Start the dryer and see if the ignitor glows. If it glows but the gas valve does not open, Change the coils on top of the gas valve.
If the ignitor does not glow, test the ignitor for 120V. If there is voltage to the ignitor but no glow, change the ignitor.
If there is no viltage to the ignitor, check continuity on the thermostats and the fuse that are located on the blower housing. Also test the sensor located on the burner.
I hope this helps. Please let me know if I can assist you further.
Vic
May 24, 2009 | Dryers
Where IS the heating element?
don't understand this. if it is a gas dryer, there is no heating element!
Feb 11, 2007 | Whirlpool LGR3624JQ Gas Dryer
Whirlpool GGQ8831L Gas Dryer Logo
780 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
