Question about Maytag Neptune MAH5500B Front Load Washer
Maytag MAH5500B, FL code and door locked.
Good evening, Thank you for your help!
The washer door is locked and has an FL code.
I have put the washer into the service mode and the to the Board Output test and pushed the extra rinse button to unlock. We hhear clicking sounds, but the door remains locked.
How does one get to the emergancy cord to open the door?
Any thoughts on what part may be needed or where to start once the door is opened?
Thank you,
michael
  • ufers5 Feb 14, 2009
    Cleared the drain and the unit is working!
    Thank you
    President:
  • 1,902 Answers
Check your drain and the drain line all the way to the pump. Here is some info on the F1 code.
FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for "FL" to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Posted on Feb 14, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 14, 2009
    Perfect glad I could help. Have a great weekend
FL code on Washer
FL is a door lock code. open the soap dispenser door, and find the thin flourescent green, or bright red color nylon cord located in the front left or right areas of the dispenser area, this will allow you to manually release the door lock. Empty the washer, close the door and perform another drain and spin cycle, if the door lock still fails, you may need to have the door lock assy replaced, especially if the door lock is making a click, or buzzing soung like it wants to operate, if it's completely quiet than you may need the board replaced...Pleazer Appliance...
Aug 15, 2014 | Maytag Neptune MAH5500B Front Load Washer
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
Door won't open
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/27966-maytag-mah5500b-fl-code-door-locked.html
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/13490-maytag-neptune-mah5500-wont-open.html
Dec 31, 2012 | Maytag Neptune MAH5500B Front Load Washer
Door is locked and has a code of FL on panel
FL Failed to lock. Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.
2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
Dec 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
My neptune washer stop working. has power but doesnt cycle. shows a FL code. cycle i mean as spin to start washing
FL means that the door isn't locked properly. Make sure that its locked tightly and restart the cycle
Feb 16, 2011 | Maytag Neptune MAH5500B Front Load Washer
Have a maytag mah5500bww replaced door lock still do and fl code
fl is usally a water not detected problem,, check ur fill hoses for kinks make sure ur water is on,, possibly have a bad fill valve..
Feb 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer MAH 5500b FL code and door will not unlock.
Open the detergent dispenser door on top of mach. There you will find a small yellow nylon cord, pull on the cord and the door should open
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune model# mah5500b
Unplug from the outlet and wait about 5-10 minutes. When you put the plug back into the outlet, the door should unlock.
Aug 23, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Error Code FL
it is saying failed to lock the door need door latch switch part # 22003269
Apr 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
"FL" light
The "FL" error code indicates that the door is not locking. The buzzing sound you hear is most likely the door lock trying to lock the door. It may only be a matter of aligning the door so that it locks properly. Otherwise, you may have a faulty door lock that needs to be replaced.
Feb 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
358 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
