Question about Compaq Presario Notebook
Write line running across screen is my screen going out?
Compaq Presario F 700 I turned on my computer and a white line is running all the way across the screen. Do this mean my screen is going out.
    Problem Solver:
  • 8 Answers
Maybe.But the more likely situation is that there was some damage done to the screen like something heavy was put on it or someone dropped it. You can ask Compaq if they will fix it for you or you can get another computer and put the hard drive from your computer into the new one.
Posted on Feb 14, 2009
  • Compaq Master
  • 4,806 Answers
Hi there
Either the screen is failing or the cable behind the screen is faulty, it has to be taken to a technician to be looked at.
Good luck and thanks for using Fixya!!!
    Scholar:
  • 53 Answers
Yes it does.the LCD is damaged.
Repair manual for compaq presario M2000
Free Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Go down to the Compaq Presario heading. (Sixth line down)
Scroll across, and click on M2000.
This is a PDF file. It may take as long as 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
(Suggestion: Save it to your computer. Burn a copy off to CD disk. Run the disk to see if it's good, then delete it off of your computer to save harddrive space)
Plus;
http://www.insidemylaptop.com/take-apart-compaq-presario-m2000-notebook/
http://www.insidemylaptop.com/how-to-remove-inverter-and-replace-lcd-screen-in-compaq-presario-m2000-laptop/
For additional questions post in a Comment.
Regards,
joecoolvette
Oct 14, 2011 | Computers & Internet
Compaq presario 700. The screen, after running for about 5-10 min, gets white lines horiz. and vert. and then goes all white. I have to turn it off for a while and it goes away. (for 5-10 min)
The monitor heat sheild is probably damaged. If you don't have a warranty then you will probably have to replace the lcd panel on the computer.
Hook an external monitor up to it and verify that that screen doesn't scramble. if it does not and the lcd does then the lcd panel is damaged. if both do then you have a motherboard problem with the graphics card. either overheating or damaged. There is also a possibility of memory issues but the first 2 things i mentioned usually over this problem
Feb 12, 2010 | Compaq Presario 700 470024-192 Notebook
Vertical White lines on the monitor
iT SOUNDS LIKE THE SCREEN HAS COME TO THE END OF IT'S LIFE, SORRY FOR THE BAD NEWS MATE
Jun 16, 2009 | Compaq Presario M2000 Notebook
I turn it on i get white blank screen. same when external is hooked up
Seems it is the Video card which has gone bad, If in case your system shows Compaq on your screen, os in that case need to install windows in the system again.But if it does not , Please get your system's Video card again.
May 25, 2009 | Compaq Presario 700 470024-192 Notebook
Blank Screen on Start Up. (Compaq Presario 700)
Unplug all external devices and then check. Go to BIOS and restore it to factory defaults
Mar 03, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 Screen is tweaking out. What can i do?
well dude ... this is cause u use ur labtop to much.. or u must hit on sumthing eventually this is gunna get worse and worse.. so u should change that scree
Oct 30, 2008 | Compaq Presario 700 470024-192 Notebook
Line in my lc screen
A line from top to bottom or side to side is a dead or failed pixel sensor. There are hundreds of pixel sensors at the edges of the screen, when one fails it causes a line, the line can be red, blue, white, or black. Unfortunately, there is no way of repairing the line, other that replacing the screen.
Jul 29, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 laptop problem
Most of the time blue screens like that indicate hardware issues. You may try replacing the memory. I wouldn't put too much money into something of that age, though.
May 23, 2008 | Compaq Presario 700 470024-192 Notebook
Mymonitor is black and the on button from the monitor is green and is flashing
i havent seen this question asked, and believe me i have searched. i have compaq presario, windows xp media edition 2005, 64 amd processor, model # SR2017CL, with HP 1703 17" monitor. Prob-put computer in hibernate mode other evening, without turning it off. when i woke up, screen had diagonal lines going across it. i rebooted, well manually restarted, since comp would not respond.
Message comes up white with black writing, essentially, prob with active desktop, restore or turn off. i tried to turn off and screen went back to diag. lines. looks like the horizontal hold of a tv screen is asque. tried adjusting monitor to no avail.
tried a few more times, was fine for a few mins then went to same thing. now when i turn monitor on it blinks red, blue, and so on.
just whole screen that color. so i am at the point where i dont
know if its the comp or the monitor. (i am quite a newby)
ty for any help you can give
ellie
Jan 30, 2008 | HP Pavilion F1703 17" LCD Monitor
Compaq Presario Notebook Logo
80 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
