Question about Samsung 226BW Monitor
Power on but display cuts out
I have had the monitor a year and out of the blue it stopped displaying a picture. The monitor shows the screen with a beautiful picture for 1 second when turned on or if turned off and then back on but immediately goes blank again. I have tried two different dvi cables and an analog and its always the same.
I have also tried it on another system. Other monitors work in its place so its NOT the video card. Any thoughts are welcome. Thank you.
  • Anonymous Mar 29, 2009
    Have the same exact monitor: 22" Samsung 226BW. I have been using it for over a year, perhaps almost two. Now, it will turn on for only a brief while and then it turns off. However, the power is still coming through. I have noticed though, that the screen is still coming through... but hardly! But through all the black I can tell something has to be there!
  • Anonymous Apr 10, 2009
    Sounds like my problem as well. After cycling the power on and off many times, the monitor will stay on, but I'm not sure how much longer that will continue to work.
  • 31 Answers
Sounds like the backlight's gone. You can try to open up the case and replace it, but an easier (and probably cheaper) option is to simply buy a new monitor
Posted on Jan 07, 2010
Tv power cuts on power light lit no picture then Tv turns it self off, when picture appears there's waves in picture and tv turns itself back off and on with no picture just black scree
Hi Patty
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 14, 2015 | Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
I have an Acer laptop approx. 2 years old. I am trying to show a folder from My Pictures on a InFocus in 20 series. Projector is up and on computer source. When I start up the computer, the projector...
You need to enable the 2nd video output in the video card settings!
right click on desktop select properties and select the settings tab
Select the monitor 2, click on extend my desktop to this monitor.
Then you can drag windows either out from your main monitor, to up, down, or the sides debends on where you set the 2nd display, you can also change the position of the 2nd screen by draging it around in the middle.
Aug 11, 2008 | InFocus Computers & Internet
My RCA 46 LCD has no picture or sound but the blue lights on?
- Flickering screen
- Dim screen
- Slow start
Mar 02, 2015 | RCA Televison & Video
Why did my computer monitor stop showing an image?
Disconnect it from computer and power. wait 15 minutes and plug only the power back in, press the power on button. The monitor may display a message that there is no signal or something like that. If that happens the problem is either the cable or the computer. If you get no message then look for the menu button and press it to see if any thing appears. If not find the manual on line and read it. Many times monitors get over-driven by computers to the point that they can't display OR they self destruct.
OR
Another way is to just unplug everything computer and monitor for 15 minutes. Plug in monitor first then plug in computer and press the power button, the display should display the booting information if the cable is good and the monitor is good.
Jul 19, 2014 | ViewSonic Computers & Internet
No image, Just red and blue vertical line on display.
- Flickering screen
- Dim screen
- Slow start
Apr 05, 2014 | Sceptre X405BV-FHD3 40 in. LCD HDTV
Macbook and 24" display flicker when plugged in
MiniDisplay will probabely not support the Cinema's screen resolution...
Sep 05, 2012 | Apple LED Cinema Display 24 inch LCD...
E248WFP (external) Monitor Won't Power Off when Laptop Screen does!
this is not a pc problem... this is because the connection loss between pc and monitor... not all pc's have sleep mode in externa vga connection.... it just cuts power off... u can configure monitor of possible to do that..
Jul 09, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
No display except in BIOS SETUP. Menu shows ''analog 720 X 440''
my monitor 943NW if power on the blue led light on normally,but no picture or blue colour display,please help me to solution,tanks.
Mar 23, 2009 | Samsung 943NW Monitor
Power Light Blinking & Black Screen
A blinking blue light indiactes that your power-inverter board is not putting out what it should. It needs an overhaul which may be a simple as changing out the capacitors on the boards.
It could go beyong that to transistors or even a bad bulb.
It will have to be opened up to do that.
A picture may show visual signs of damage. If you can take one and email it to me , I'll take a look.
Fran
Oct 18, 2008 | HP vs19 (Silver) 19" LCD Monitor
Open Questions:
See all Samsung 226BW Monitor Questions
Samsung 226BW Monitor Logo
333 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
