Question about Toshiba Satellite Pro 490CDT Notebook
Only get 3/4 display screen on monitor
Toshiba 440 cdt sat pro...only displays 3/4 screen on monitor
  • Anonymous May 21, 2009
    I have the same issue after reformnatting. The display area only fills about 3/4 of the screen area. The surrounding area is black.
  • 3,940 Answers
Your post is not very clear on the exact problem you are having. If your issue is that some web pages have large amounts of blank white space to the right or both left and right of the web page, then the issue is you have a high resolution LCD and the web page was written using page frames. (If this is the case, the web page is being displayed as designed and there is no fault to the system)
If that is not the issue, then post specific details as to what you are seeing and what you are doing when the issue occurs.
Posted on Feb 13, 2009
There is light in my display of toshiba 4030 cdt but no video is visuable. An external monitor works normally.
It sounds like the cable between the motherboard and the LCD. My advice is to take it to a repair shop.
May 02, 2010 | Toshiba Satellite 4030CDS Notebook
Toshiba Satellite L310 problem , display cannot appears
If the screen went blank after the driver install, sometimes clicking the mouse on the screen will bring the picture back. It sounds like the monitor is having a conflict with the resolution the driver is throwing out. Reboot the laptop and when you see the Toshiba splash screen, tap F8 until you see the multiple boot menu. Scroll to Safe Mode with networking and reboot. If the screen comes up, go to the control panel > System > hardware > display adapter > click on the plus sign and double click the reported adapter.click on driver tab and select roll back driver > click yes to any prompts and click ok. Reboot normally and see if that clears the problem.
Sep 07, 2009 | Toshiba Satellite Pro L300 Notebook
No display/monitor problem? When I turn on my Toshiba Satellite pro L300, I can see the Toshiba logo, bios menu, windows loading logo etc, then when it loads my desktop, nothing! No display, no graphics...
When you press power button press F8 key then enter in enable vga mode.
Then go to display proeprty and set screen rsolution to 1024*768 then apply.
Then check.
Aug 20, 2009 | Toshiba Satellite Pro L300 Notebook
The display has dimmed, and looks washed out (faded)
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 05, 2009 | Toshiba Satellite 4010CDS Notebook
Screen stays black on startup of toshiba satellite L300
have you tried either switching between external and internal monitor usally Fn + F5 on toshiba or try plugging a monitor into the back and see if it displays.
if you get a display on the external monitor then its probably a screen or inverter fault if you donot get a display to an external screen then it is likley t be the graphics on the board itself.
hope this helps
Feb 22, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
Connecting to Pioneer pdp 4270xd
  1. Go into Start->Control Panel
  2. Open up Display Properties
  3. Navigate to the last tab
  4. Enable your second monitor from this tab.
You can also change your external monitor settings if you have the nVidia graphics chip by right-clicking on your desktop and selecting the nVidia Displays Manager.
Mar 26, 2008 | Toshiba Satellite Pro M15-S405 Notebook
Toshiba Satellite Pro 440 CDT
the password is on the CMOS, best thing to do is open it up, find the CMOS battery and disconnect it for a few minutes.
hope this helps
thanks for the rating
Jan 07, 2008 | Toshiba Satellite Pro 490CDT Notebook
Password lockout on Toshiba laptop
Is it a bios password or a xp login password?
Jan 04, 2008 | Toshiba Satellite Pro 490CDT Notebook
LCD Display problem
THE WIRING OF UR SCREEN IS DAMAGED GET IT REPAIRED BY A PRO
Nov 24, 2007 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite Pro 490CDT Notebook Logo
246 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
