Question about Frigidaire Freezers
Refrigerator not wotking, but frezzer is to my frigidaire
I also want to know about the fans. Maybe I can get the fan to start again.
  • 979 Answers
The fan sounds like it is the problem. Without it, your frig is useless. The fane should be running 90-95 percent of time. I would go ahead and get a tech out to look at it. The main question is how old is it/ If it is much older than 12-14 years, it may be time for a new one.
Posted on Feb 14, 2009
Where is the water tube to see if its frozen FGHB2844LF5 dbl door bottom frezzer
Hello Wally, thanks for your post!
Based off the information you have provided you would like to know the location of the water line inside of your Frigidaire refrigerator. The water line is located within the wall of your refrigerator it is not accessible. The best way to clear out a frozen water line is to disconnect power from the refrigerator for at least two to three hours. This will help defrost any ice build-up within the refrigerator. I hope this information is helpful to you. -Matt
Dec 03, 2015 | Electrolux Frigidaire Gallery FGHB2844LF...
Where is the defrost timer on a frigidaire fghn2844lf2
Good Morning Debbie,
I see that you are looking to see what turns on the defrost timer and evaporator fan on your Frigidaire refrigerator, model# FGHN2844LF2. Your appliance comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, simultaneously press and hold the Fresh Food up (+) and Fresh Food down (-) keys for 5 seconds. A "d" in the freezer temperature window and "F" in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, simultaneously press and hold the Fresh Food up (+) and Fresh Food down (-) keys for 5 seconds. A "d" and "F" will be displayed until the defrost cycle is complete. I hope this is helpful.
-Best Regards-
Mar 19, 2014 | Frigidaire FGHB2844LF Gallery 27.8 Cu. Ft....
My amana bottom frezzer refrigerator keeps frosting up
check the defrost timer , element and defrost temperature safety.
and make sure the fan works.
Apr 16, 2013 | Amana Freezers
MY REFERIGERATOR TURNS ON BUT DOESN'T COOL
if it is a fros free check fan in the frezzer that is what cools the frige
Sep 12, 2012 | Danby DFF9102W Mid-Size Refrigerator White
Frigidaire Freezer acting goofy
Make sure everything is clean of debris and I would personally see if you could cool the area around the unit. Maybe use a fan or turn the air down in that room. Humidity and hot temps kill a unit's sealed system.
Jul 24, 2012 | Frigidaire 21 cu. ft. / 595 liter Upright...
My danby 3.6 chest frezzer has stoped working, it was freezing fine yesterday, now its not even keeping cold
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
I hope this helps........
Good luck.
Apr 14, 2011 | Danby 3.6 cu. ft. / 102 liter Chest...
Frezzer runs but the compresser does not comes on
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
let me know if this helps.
Mar 04, 2011 | Frigidaire Freezers
Frigidaire Freezer, model # FFU20FC6AW3. Unit is not cooling and the fan motor inside behind the access panel is not running. My Temperature Alarm sounds and will not shut off, unless I switch it to the...
if the evap fan is not turning try to turn it by hand a few times then start you freezer if it does not turn it needs to be replaced.make sure there is no ice build up on the evap coils.alos check the continuity of the defrost heater below the evap coils.once you het teh fan replace your unit should cool down to the proper temps.
Nov 16, 2010 | Frigidaire Freezer Refrigeration White...
My frigidaire side by side isn't cooling properly,
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 21, 2010 | Frigidaire Freezer Refrigeration White...
Freezxer dosn't work
Is the fan inside the freezer working? If the fan isn't working the freezer will never get ice cold.
Nov 23, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Freezers Logo
43 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
