Question about Pioneer DEH-P2000 CD Player
Pioneer DEH-P2000 - turns on but no sound goes through speakers
I recently took this CD player out of my '92 ford ranger because the transmission died on it and was going to put it in the '89 ford crown victoria i'm driving now. it has the same plugs as my ranger did so i pluged it in and it turned on but no sound is coming through the speakers. i know the speakers work fine because when the original radio is hooked in they work fine and i didn't damage anything on the CD player because i hooked it back up to the ranger and it worked fine. any suggestions?
  • 2 more comments
  • pcgamer_stum Feb 13, 2009
    no, the CD player just turns on and acts like its playing the CD or radio but no sound is coming out of the speakers
  • pcgamer_stum Feb 28, 2009
    does anyone know if maybe the speaker wire could be causing this?
  • Anonymous May 01, 2009
    I'm having the same problem with my pioneer - bought a car and the stereo doesn't work. it turns on and switches from radio to cd, but no sound.
  • Michael Masters
    Michael Masters May 11, 2010
    are you getting an error code by any chance?
5 Suggested Answers
TRocky
  • 4 Answers
SOURCE: i have a pioneer DEH-P3000
Hi nhmteam. I have the solution for you: 1. With your DEH-P3000 turned off, press your FUNCtion button. It's a tiny button towards the upper right of the faceplate. Hold it down until you "ALARM OFF" or "ALARM ON" on the display. Release the button. 2. Press the FUNCtion button again and you should see another feature. I don't remember how many features you need to cycle through, but keep releasing and pressing the FUNCtion button until you see "M-CD ON" on the display. If you miss it just keep going and eventually it will come back. 3. On the right side of your faceplate there is a button with 4 arrows. You will need to push the up or down arrow until the display reads "M-CD OFF". If your display already reads "M-CD OFF", kip to the next step. 4. Press and release the FUNCtion button again and you should see "AUX OFF" on the display. Again press the up or down arrow until the display reads "AUX ON". 5. Now, turn on your unit, then press the INPUT button until the display reads "AUX". You are now ready to use your iPod in the way you always did. Keep these instructions for the future since I believe every time you disconnect the unit from the battery the unit will reset itself and disable your iPod cord. Best regards - TomR
Posted on Sep 23, 2007
SOURCE: pioneer deh-p2000
turn off radio with ign. on-- depress source button for 3 sec. then function button for 3 seconds until clock appears--use arrow keys to set hours and minutes.
Posted on Oct 12, 2007
  • 124 Answers
SOURCE: how do i turn aux on my pioneer deh-7600mp radio
Shut it off then hold the function button, cycle through till you find your option to turn it on, the turn the radio back on and use you source button to change to CD, TUNER, and AUX
Posted on Dec 27, 2008
  • 102 Answers
SOURCE: can not find a wireing diagram for a pioneer DEH
Try Pioneer's website, I've downloaded similar info before.
Posted on Mar 11, 2009
  • 85 Answers
SOURCE: How to set a clock on a Pioneer DEH P2000 car
turn radio off and press clock then press function for about 4 seconds and the display will appear with the clock functions
Posted on Sep 08, 2009
Do you need to connect the yellow and red wires together if not used in a car on a pioneer DEH-X1950UB
Yellow - Connect to the constant 12 V supply terminal.
Red - Connect to terminal controlled by the ignition switch (12 V DC).
Jan 11, 2017 | Pioneer Car Audio & Video
What do you think the problem is as to why my ipod want load up,i keep getting the message ipod communication aborted.
bad receiver in the radio, or, the transmitter on the ipod is bad. try it on another bluetooth source to see if it maintains connection, if not, the ipod could be damaged or bad. If it works with another bluetooth source unit, then the radio has a bluetooth receiver issue.
We sell low priced replacements!
http://advancedelectronic.net/
Nov 22, 2014 | Pyle PLDN74BTI Car Video Player
How to on bluetooth
KD-R200 does not have the ability to add Bluetooth to it
Apr 03, 2014 | JVC KD-R200 Car CD/ MP3 Player
Usb
You need a new USB cable the new Kenwood and pioneer headunits have to have there own USB cable, go to you local audio dealer or go online and get a pioneer USB cable, they run $24 , I got my Kenwood one and they just have the option of total control from the headunit or not
Nov 16, 2012 | Car Audio & Video
Lightning audio b150.2 as soon as +12 is hooked up blows 25 amp fuse and the c2 1000uf/35v capacitors blow???????
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections .A thumbs up would be greatly appreciated if this answer is helpful to you.
Aug 25, 2009 | Lightning Audio PC2 Capacitor Car Audio...
Pioneer DEH-P2000 CD Player Logo
112 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
