Question about Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 No Picture
I have a Sony KDF-E50A10 LCD Projection TV, and it doesn't seem to want to turn on. The TV seems to atempt to turn on (the power/standby light blinks green for about 4 seconds) after this, the light turns to red and blinks 4 times then stops and then blinks 4 times again. The power/standby light continues to blink red for 4 times until it is unplugged. I have replaced the lamp, and still no change. Before I spend a bundle on service calls I thought I'd see if there were any ideas that may help solve this little problem of mine.
  • Anonymous Feb 20, 2009
    sony KDF-E50A10 SNOWY SCREEN and NO SIGNAL displayed at top, any solutions? THANKS!!!!
  • 10,594 Answers
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Posted on Feb 14, 2009
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
Have a Sony HDTV LCD projection tv model ***-50a10 that sometimes turns off and back on from time to time. Doesn't do all the time but does every other day
Look to the owner manual to see if the set has an error buffer that detects and stores errors--if it does you should be able to see what error has been detected---Sony if called might be able to tell you how to access it.
Apr 16, 2012 | Sony KDF-E50A10 50 in. LCD HDTV
I have a Sony TV model # kdf-E50a10, there is a shadow in the middle of the screen . I can still see the picture, but there seems to be a cloud in the center of the screen. How can I fix
problem is called the optical block assembly. repair runs around 1200 dollars. if you call sony with your model# and serial # they may offer you a new tv at a discounted price. 1800-282-2848
Mar 24, 2011 | Sony KDF-E50A10 50 in. LCD HDTV
My Sony Grand Vega (KDF-E50A10) LCD just made a loud pop sound and now there is no picture. The only sounds are a loud buzzing coming from the back....is this a burned out lamp??
Yes, loud pop sound was broken lamp in tv, replacement of lamp will fix tv problem.
Lamp replacement procedure is easy and would be written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
Nov 02, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Turns off/on every few minutes
I would replace the Lamp. This is a common symptom when the Lamp is failing.
I hope this helps,
Skyassoc
Oct 30, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Standby lamp keeps on flashing.
Seems its time to replace lamp in your Sony KDF-E50A10
When lamp in TV got weak in result, standby light start blinking and if lamp got broken / dead, you will see lamp light ON.
Lamp replacement procedure is easy and written in user manual, please buy Sony original lamp for TV safety.
Thanks.
Jul 30, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Kdfe50a10 Sony lcd projection TV. No red color
Make sure you get colors by bringing the TV menu and see if looks normal, if it does
maybe the problem us the signal source
Apr 03, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10
Replace the lamp, sounds like a weak or old lamp. Use an original Sony, the replacement lamps are unreliable
Jul 10, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
No red color
Scott,
what do you have hooked to the set?
How is it hooked to the set?
does this happen on all inputs?
Jun 24, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
SONY GRAND WEGA KDF-60WF655 - VERTICAL LINES
This seems to be common problem with Sony projection tv. I have the KDF-E50A10 that lasted only 2 years. It's sitting in a corner now until I figure out what to do with it. I am not going to spend another grand to repair it!! Never Sony again.
Jun 16, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDF-E50A10 50 in. LCD HDTV Logo
1,228 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
