Question about Dryers
Asko 700 model dryer has no power
Asko Electric Dryer has no power. Power light comes on-All thermostats are good. Heater element is good. Motor is good. Fuses are good. The reset thermostat/fuse is good. All were even tested with a multi-meter. Still no pwer.
  • 9 more comments
  • Ismael Gonzalez Feb 14, 2009
    Yes--also door switch was check and has continuity--thanks
    Yes and also door switch is good-thanks
    The lint has been clean out-I dismantle the whole machine and its now clean.
    I have 220v from the breaker and into the machine-but will try to verify again-was leaning towards that posibilty.
  • Ismael Gonzalez Feb 15, 2009
    All fuses were tested and are good. Also, power sorce is good(I have 220v coming into the machine).
  • Ismael Gonzalez Feb 22, 2009
    Tested power and power is coming in and out-Is anybody out there that can tell how to get a electrical diagram before this machine hits the junk yard.
  • Dan Webster
    Dan Webster May 11, 2010
    Did you locate all the duct fuses? Sometimes they mount one near the filter/blower housing and another neat the heater chamber.
  • Dan Webster
    You could have a bad circuit breaker. Have you got 220 coming into the machine?
  • Dan Webster
    Did the dryyer or the vent pipe have a lint issue?
  • Dan Webster
    Did you remove the wires to the components you were testing so you won't get no false reading on your meter?
  • robert sanko May 11, 2010
    Have you checked the on switch and the door interlock switch?
  • 979 Answers
If you have done all of the above, check your on off switch. It may not be getting or letting power in or out.
Posted on Feb 15, 2009
My electric Asko t 721 dryer is not heating
You may have an open thermostat or burned out heater element. The easiest and safest way to diagnose the problem is to unplug the dryer, open the control panel, and use an ohmmeter to check for resistance between the temperature selector switch and the opposite leg of the 240 V plug. If it's open at both the medium and low heat terminals, check the thermostats. You'll probably need a wiring diagram to identify the connections - they're color-coded to make it easier.
Aug 03, 2015 | Asko T721 Electric Dryer
What does the code C3 mean on my Asko Dryer
Asko electric dryer model T701 has timer-controlled drying in addition to the two automatic (thermostat-controlled) programs. Without electronic, there isn't possible display fault code.
Dado
Sep 26, 2014 | Asko T701 Electric Dryer
Asko T760 Dryer - Computer Screen Blank
you have either a frequency related issue or there is a lot of t.h.d. total harmonic distortion on the line, this will raise cane with electronics, I would try a power line conditioner on the dryer power circuit
Jul 30, 2009 | Asko T761 Electric Dryer
Zanussi tumble dryer spinning but not heating up
I have same problem and been tol its either the heater or the thermostat inside the front of the drum open circuit hope that helps
Apr 13, 2009 | Asko T701 Electric Dryer
My Asko dryer shut off and my clothes are still wet. It won't start and the light on the pannel will not come on. I know I probably have lint in the system that escaped the lint trap or maybe something...
YOUR DRYER Has a fuse in it look for it probably somewhere close to where the main power comes in at. if it's good check the heat relay contactor assembly. www.repairclinic.com has the model you have and it may even be as simple as the door switch
Apr 09, 2009 | Asko T701 Electric Dryer
Dryers Logo
127 people viewed this question
Top Dryers Experts
