Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Hot band/divider between doors of side by side refrigerator
The band or strip between the 2 side by side doors (where they close to) is hot I mean painfully hot to the touch. the entire band from top to top is hot.
very strange, any ideas?
    President:
  • 1,902 Answers
That is your external humidity control so that your doors do not get condensation. You are going to have to replace it. Go to repairclinic.com and they have you part
Posted on Feb 14, 2009
The washer goes through the motions to start but door lock keeps coming on?
Looks like a Daewoo? DE means "Door Error" which is usually a failed door interlock switch. With the door open, have a look at the rubber gasket , around this is a steel band with a spring on it. Prise it out with a flatblade screwdriver. Pull the door gasket from the cabinet. (It has a lip that fits onto the cabinet) Push the gasket back into the machine so you can gain access to the back of the front panel. Undo the 2 screws on the right hand side of the door opening, the door switch will then be able to come out. Make sure the machine is UNPLUGGED from the power!. The door switch will have a socket connection to the switch. Pull the connector off and fit a new switch. Its good to mark the connector first as it can go back on both ways. If you put it on backwards, the machine wont work. Refit in reverse order to stripping the machine. The steel band can be a pain to refit as you have to stretch the spring so that the band and spring fit back into the groove it came out of. Get the model number and call up your nearest parts supplier for a door interlock. If you cant find one and you are in Australia, Castel Electronics in Melbourne are the Australian Distributors for Daewoo Whitegoods.
Apr 13, 2015 | Washing Machines
Check error
Try the following steps
1. Unplug power
2. USING THE FINGER HOLDS ON EITHER SIDE, lock scanner cover into open position
DO NOT TOUCH THE ENCODER STRIP (clear plastic strip in front of the white vinyl band)
3. Remove jammed paper/foreign objects (check under the print head; if the print head is in the middle, slide it to the either the left or the right side, & check for paper scraps underneath the print head)
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE LEFT SIDE]
4. Move the print head to the middle
5. With the print head in the middle, remove any ripped paper/foreign objects from the left corner (SINCE THE RIPPED PAPER COULD BE VERY SMALL, USE A FLASHLIGHT TO INSPECT)
6. Close the scanner cover & plug the machine back into the power outlet
[PERSISTENCE OF THIS ERROR MESSAGE OR NO PAPER SCRAPS/FOREIGN OBJECTS FOUND MEANS THAT THE ENCODER STRIP WILL REQUIRE CLEANING]
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE RIGHT SIDE]
7. Plug the power cord back into the power outlet...LCD will show "Cover is Open"
8. Press Stop/Exit for approximately 5 seconds until the print head moves to the middle
9. UNPLUG MACHINE FROM POWER OUTLET
10. USE A FLASHLIGHT & TWEEZERS TO INSPECT: Remove any debris from the right corner
11. USING THE FINGER HOLDS ON EITHER SIDE, close scanner cover & plug machine into power outlet
TO CLEAN THE ENCODER STRIP... (clear plastic strip in front of the white vinyl band)
[Markings & debris can adhere on the surface of encoder strip FROM HAND CONTACT &/OR GREASE CONTACT INCURRED FROM REMOVAL OF JAMMED PAPER]
DO NOT USE FLAMMABLE SUBSTANCES NOR ANY TYPE OF SPRAY TO CLEAN INSIDE/OUTSIDE MACHINE
1. Unplug machine from power outlet
3. Clean both sides of encoder WITH ONLY A DRY, LINT-FREE CLOTH
DO NOT FORCEFULLY PULL ON ENCODER STRIP
DO NOT TOUCH ENCODER STRIP WITH BARE HANDS
DO NOT FORCEFULLY SCRUB ENCODER STRIP (THAT COULD SCRATCH ITS SURFACE)
4. Clean encoder strip from right to left--stopping just before the left corner
5. Clean encoder strip from left to right--stopping just before the right corner
6. Repeat steps 5 & 6 two or three times to clean thoroughly
7. After cleaning encoder strip, USE FINGER HOLDS TO close scanner cover
8. Plug machine back into power outlet.
Nov 29, 2010 | Brother M 4318 Matrix Printer
Whirlpool refrigerator getting hot on frame where doors close.
Welcome to FixYa.
I`ll start by letting you know first the heat between the doors is normal...to a degree, and done by design to help prevent moisture along the "breaker strip"/divider.
If all else appears fine, temp. Ok, fans running, no significant frost build up on freezer back wall, it's likely nothing to be concerned about.
**Just be sure the condensor fan isn't jammed and still turning.** The fan at the back next to the compressor.
The amount of heat can be determined by several factor's such as,
1) temperature setting - lower ( colder ) the temperature is set the more the run time the hotter the strip.
2) The ambient temperature - hotter the environment the more the unit runs to compensate, hence the hotter the strip.
3) The amount of "fresh" content added to the unit ( especially freezer section if unfrozen items added ) - new items add a lot of warmth thus demanding the unit to run more to remove this heat (btu`s or british thermal unit`s )causing the strip to be hotter.
4) Build up of dust & dirt on the condensor coils - this also causes the unit to run excessively which in turn makes for more heat on this strip.
These are all things which can and do determine the amount of heat between the doors.
Another factor to always consider is of course If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned.
Hope this answer's your question and let me know if I can assist you further.
Thank's for coming to "fixya" and good luck moving forward.
Please take a second to rate the info provided here.
macmarkus :)
Sep 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Samsung RS2630WW Side by Side refrigerator. The center column dividing the freezer from the refrigerator is very hot to the touch. The freezer and refrigerator are working fine. Is this a...
Hi, Welcome to FixYa.
Hope this answer's your question and let me know if I can assist you further. Thank's for coming to "fixya" and good luck moving forward.
macmarkus :)
Aug 13, 2010 | Samsung RS2630WW Side by Side Refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Kitchen Aid Fridge KSRF25FRBL00 - Hot Panel between doors
This strip is warmed to prevent condensation forming here during humid weather. Some models use a refrigerant pass of the compressor to warm this strip other use a heater that can be controlled by a 2 position switch in the refrigerator control panel that reads something like "Turn this on if moisture appears on cabinet exterior". If you have no such switch you should be aware that the strip is ALWAYS warm but barely noticeable until you develop a problem in the cooling system.
Check temperatures in the freezer (Zero Degrees approx.) and refrigerator (Approx. 30). If these are normal don't worry about the heat from that strip. If you find a temperature not normal you have the beginning of a cooling problem unrelated to that strip.
Aug 20, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Roper side by side refrigerator gettig very hot to
Most side by side units have a hot return gas line that is attached to the "mullion strip" to prevent sweating or moisture build up which could cause mold to build up on the door seal. The heat you feel is normal, however excessive or continuous heat is a symptom of the unit running too long.
Below is a link provided by www.repairclinic.com, which will help you understand how a refrigerator works.
Tip: Make sure door seals are sealing adequately and keep entry time to a minimum during high heat periods. Use the rule "Get in, get what you want and get out"
http://www.repairclinic.com/0088_4_3.asp
Aug 16, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Magnetic divider strip is hot. Temperature not cold enough
Yes this is normal. The heat strip is there to prevent moisture from forming around the the door frames. It also is most noticeable if the heat wave is causing your refrigerator to struggle to cool. Cleaning the coil below the refrigerator and making sure good air circulation in that area will help. If you have any questions please let me know and visit my siites. Please rate me if this was helpful, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartseast.blogspot.com/
http://appliancepartsse.blogspot.com/
Jul 30, 2009 | Whirlpool Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
1,956 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
