Printer not printing colour (but colour settings are ok)
My printer started "beeping" at me and stopped printing. After some searching I found a load of discussion about the Waste Tank full error so I took the printer apart and put it back together. No more beeps so I printed a test page and although the text printed (in black), the Windows logo didn't print (in colour)
It's as though the colour cartridges don't exist!
Any ideas as to why the printer no longer prints in colour (I've checked all the settings and everything seems to be ok)
  • karenairving Feb 14, 2009
    HI,
    I've cleaned the print heads and cartridge. Reset the Waste Tank thingy. I've completed a deep clean and head alignment and also run a nozzle check.
    I can print in black (graphics are now printed) but still no colour.
    I'm thinking that maybe by resetting the printer it has set the model to a different type. I've found some instructions on resetting a 6200. Will this work for a 6500?
  • 3 Answers
Try cleaning the contacts in the printer and cartrage.
Rich
Posted on Feb 14, 2009
Printer is not printing the black colour when i load the paper from the rear slot...
Hi
try printing a "Nozzle check" to confirm that both your black cartridges are working ok. One cartridge - the smaller (photo) one is used for printing photos on glossy paper. The second - bigger cartridge is used on plain (copy) paper. Sounds to me like your smaller (photo) black cartridge is not working. It's either empty or may need "Cleaning" or "Deep cleaning". In case you don't know...Nozzle check, Cleaning etc utilities can be found on "Maintenance" page in "Printer properties".
good luck
Lumir
www.inkbank.com.au
Mar 07, 2014 | Canon PIXMA MG5320 All-in-One Printer
Canon ipf605 paper error
Here is what I've found out by trial and error.
Paper Roll Won't Load:
    -Usually occurs when the roll is less than 50% full
    -Printer will give the error "paper loaded askew"
    To Correct This:
      - Press and hold Stop until Job Cancel comes up on the
      screen
      - Press Menu
      o Scroll Down until Adjust Printer menu comes up
      o Press right side arrow next to OK button
      o Scroll down to Manual Band Adjust and press right side
      arrow again (or select one of the other adjustments)
      - Select Yes and press OK
      - Load paper roll - make sure paper is straight
      - When asked (printer will beep) select Plain Paper and
      press OK
      - Let paper load
      - When printer starts to print press and hold Stop to cancel
      job
      - Paper should now be loaded
      When all else fails load a new roll.
      This would be a temporary solution until the sensor is fixed.
Mar 12, 2012 | Canon imagePROGRAF IPF605 InkJet Plotter...
I have a dell 5100 cn it keeps beeping to say load legal tray. everyone in the office can print find except one member when he prints we get the load legal tray beeping
this member needs correction of printer drivers options. Look for IT specialist for help. Maybe regional settings of operating system is not OK
pifonski
Feb 23, 2011 | Dell 5100cn Laser Printer
Printer won't print in black.
Hi, I'm Ian
This may help.
Clck on "Start" ,Printers and faxes, Right click on the printer you wish to use. (Usually the one with a tick as the Default printer) Clickon Properties,
Print Preferences. Select the box "Print in Greyscale" and Black Cartridge only. Cick OK, OK to get out and then Print your subject.Your printer will now only use the black cartridge to print, Saving you loads because normally they use the colour cartridges also to print Black!
Cheers
Ian
Dec 06, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
I have the 660 printing output data from my blood counter and color is not needed, however with daily start-up, color is used up and requires replacing. How can I turn off the color and still print black...
please your printer page setup in go and select to colour printer
second you go the control panelt in select to printer open and go set the printer and colour print set and use the printer.
just you print aply when select colour and printsprieveu check and aply prints ok
Sep 25, 2009 | Epson Stylus Color 660 InkJet Printer
I cant get my printer to print in colour
please use the colour printer ? and you have a colour printer
then your printer job is colour ? your printer cartries is colour & w&w ?
if colour ? then fristime you aply a print and so the print page is ok and so the previue the page in colour job if yes is ok and other no then
print page and in prperty selectand cleck and go immage in colour select the colour and aply the ok and give a print is ok
Sep 24, 2009 | Lexmark X1270 All-In-One InkJet Printer
My i550 Canon Printer will not print colour, black only. Colour cart. are full. Computer checked out OK. Driver is OK. All 3 colours stopped printing at the same time. linda gal 16
try looking under the propertys page for the printer and see if its set to print black only or gray scale. if so set it to auto and you should be ok if the printer and cartrige is ok.
Jul 08, 2009 | Canon BubbleJet i550 InkJet Printer
My i550 Canon Printer will not print colour, black only. Colour cart. are full. Computer checked out OK. Driver is OK. All 3 colours stopped printing at the same timeannabellamt
My i550 Canon Printer will not print colour, black only. Colour cart. are full. Computer checked out OK. Driver is OK. All 3 colours stopped printing at the same time. linda gal16
Jul 06, 2009 | Canon BubbleJet i550 InkJet Printer
HP colour cartridge no. 22 won't print
if the test pages come out OK then the problem can not be the printer !!!!!!!
it must be from the application
Sep 04, 2008 | HP Color LaserJet 2600n Printer
F2100 printer
My HP Deskjet F2100 All-in-One series printer worked up until today. It printed three sheets and then stopped.
Dec 16, 2007 | HP PSC 1610 All-In-One InkJet Printer
115 people viewed this question
jasbo
jasbo
