Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Engine stops when chain brake is applied
I have a husqvarna 142. As soon as i apply the chain brake the engine stops. it does it every time. Thanks for the help
  • 181 Answers
Sound like the springs are broken in clutch.they can be replaced.but when you replace them you should also grease the needle bearing in clutch durm
Posted on Feb 17, 2009
I have a Husqvarna 142 chainsaw. The saw will idle, however when I depress the throttle the saw chokes down a dies.
What condition is your spark plug in?Is your filter clean?Is your gas-oil mixture correct? Is your gas fresh?Is your brake releasing?Is the blade and chain on correct?
Nov 21, 2016 | Husqvarna Garden
I have a chain saw 55 husqvarna and while the motor turn he stop suddenly often of the time when I put the brake and the motor is truning slowly he stop
Check to make sure the brake binder is not engaged...which is the same as saying: check and make sure the kickback brake handle is fully cocked. The handle should be oriented rearward towards the forward hand grip. If it is forward, pull it back stongly until it lockes in place. (Hint: also make sure the binder is released/brake cocked always before attempting to remove the brake assembly from the saw drive engine subassembly.)
Oct 04, 2014 | Husqvarna Chain Saw Models 51, 55
Husqvarna chain drive stoppped - appears to be frozen sproket
mine meted the chain brake and applied the brake on me also check the chain could be to tight
Jun 27, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
My husqvarna 240 e series cuts out when I apply the brake and the chain turns when the engine is idling?? Can anyone help?
Check the clutch springs. You will either have a broken clutch or a broken spring. It stalls because the clutch is trying to drive the sprocket and the chain brake is stoping it.
Mar 03, 2012 | Husqvarna Garden
Have a Husqvarna chainsaw, model 142, that starts and idles fine, but when I give it gas, it bogs (makes a low hollow sound) and the chain only turns a little or not at all. Any suggestions greatly...
Are you sure the the chainbrake is not on, grab the hand guard and pull it firmly back to the top handle until it clicks and the brake is off.
Sep 18, 2011 | Husqvarna Garden
Reference the Husqvarna 350 chainsaw. Why does the chain continue to turn at idle? I just installed a new clutch. Adjusting the idle down causes the saw to shut off upon trying to accelerate.
Sounds like the clutch is still grabing. Easy solution is to apply the chain brake at idle to stop the chain turning. Try adjusting the L screw for a smoother idle.
Aug 05, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Good Morning : I have a Husqvarna 142 e chain saw about 2 years old and I have an excessive amount of bar oil dripping out . Is there some kind of flow adjustment for this problem ? Thanks , Mark :
First, deactivate the chain brake, back-off the chain adjuster, then remove the bar and chain. Run the engine at speed for a moment or two--the oil should ooze out of the engine side port. If the oil quantity seems about right, then clean the drive end of the bar oil-passages including the two small passages that go out to the chain groove on each side. Clean the chain groove and check the sprocket on the far end (if equipped). Reassemble the bar and chain, then start and run the engine at speed for several moments with the bar tip near a piece of cardboard--it should throw off a thin line of oil onto the cardboard. Check the owner's manual for location of any oil-volume adjustment if needed.
Jun 04, 2010 | Husqvarna Garden
142 chain saw. Starts but will not pick up when
Check the fuel lines for hardness, cracking, splitting, or end rot. Check the muffler for plugging. Check the carburetor fasteners for tightness. Are you using fresh fuel mix? If the carburetor jets have been adjusted, try turning both CW to stops (lightly) then back out each CCW 1-1/2 turns. Engine should start and run--allow to warm up. Pull the throttle full on, and adjust H needle CW until the engine starts to speed up, but still 4-strokes. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Let idle and adjust L CW for fairly smooth running, but still allows the engine to 'follow the throttle'. Hope this helps!
May 13, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Replacing the oil pump on a Husky 136/142 chainsaw. have you any manuals or can you tell me how to do it thanks john
Go to husqvarna.com then united states then homeowners then chain saws then manuals and parts then type in model no.
Apr 06, 2009 | Husqvarna Garden
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
564 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
