Question about Mackie SWA1501 Subwoofer
Sw 1501 no sound output
Ive checked the fuses, boards inside for broken solder points etc... everything looks fine. lights power on and stay on, theres a slight pop sound heard when powering on and off, and a slight crackle sound when adjusting the gain knob on the sub itself. the thru ports work fine, and still transfer sound to the mains.
not sure how to test anything else, what should be checked next.
any thought/help much appreciated!!
thx
In my dvd dts audio is not playing
Posted on Feb 14, 2009
My hotpoint Aquarius wdl540 is dead no lights on or power. Ive have checked the socket the fuse and all the earths everything is fine. Could someone let me know what else it could be. cheers adam
Could be a broken wire. You need to check that power is actually getting to the machine control. I don't know your level of experience, but it means getting inside the electrics which can be dangerous. Safest way is to disconnect from the mains and check the continuity of the 3 plug wires as far along the length as possible. A simple multi-meter is all you need. Follow the cable from the plug to inside the machine, check where the blue wire from the plug is fitted inside the machine and with the meter set on ohms, touch one lead of the meter to that spot and the other lead to the blue wire inside the plug. If you get zero then the wire is not broken. Do the same with both ends of the brown wire and then the earth (green/yellow). Doing it this way isolates you from the live electrics.
If the wires are not broken (i.e. you have continuity) then the problem is with the machine itself and will probably require an engineer. It could be an internal fuse or a complete circuit board failure and anywhere in between.
I hope that is of some help.
Jun 03, 2016 | Hotpoint Washing Machines
Furnace wont heat or go to cooling....fuse is fine
With volt-ohm meter (vom) check for 24v input power. Most output voltage will be 5v DC, check for that. If the relays are soldered on to the board, your only solution is to replace the board. A "ticking" sound may be a bad relay. One check you can make is to disconnect any incoming power to the unit and remove the board. Inspect the soldered side of the board, if you see any black or brown spots, most likely the board is bad and will need to be replaced.
Nov 06, 2013 | Heating & Cooling
56 in rca model# R56WH78 having a problem turning the tv on and it actually staying on.. when i try to turn it on there is a solid green light for 3-4 seconds then it goes off.. no picture no sound ....
Replace the deflection/power supply board and return the convergence board. There are probably bad soldering connection points all over the bottom of that board with the fly back transformer. Slight soldering skill required.
Jun 17, 2011 | Televison & Video
Amplifier do not have sound. E-mail: rigo11us@yahoo.com
You may have blown the inline fuses for output sound. Amps have alot of fuses under the hood. take the amp cover off and check all fuses are not blown / wire broke inside fuse. Some fuses are hidden under circuit boards on some amps, check everywhere possible to check all fuses. If all fuses are fine and no broken wires inside them, you may have loose connection where your speaker wire ports are inside the amp. Check they arent black or loose. if they black they are blown as there usually soldered (a silver colour)
Mar 02, 2011 | Yamaha AX-596 Amplifier
Alpine mrp m 1000 turns on, has a good ground, but no sounds from sub. everything is wired correctly, i have tried using a different speaker to see if its just the sub that is bad, and ive tried using my...
Is the amp in protect mode? Maybe a red light on the amp. I would also open the amp and check the RCA connections aren't loose. It's usually a solder joint. Swap the amp out as well. Or check your power wire. Sometimes amps come on when it gets remote power, but actually the power wire has a bad fuse or connection.
Oct 04, 2017 | Alpine MRP-M1000 Car Audio Amplifier
3 blinking power button lights RCA R52WH77
have you tried checking some voltages in the convergence board it could be the damage is there and not the deflection board since the 320vdc was connected thru the yoke. you can also try to deactivate the convergence board to see if the tv set will remain on this will give you a better idea of where the problem is. good luck!
Aug 13, 2009 | Televison & Video
My Cyberhome CH-DVD 300 MU BIOS: VOE won't turn on.
I had EXACTLY this problem. Fuse is OK. LED barely looks like its glowing.
Take six screws off cover, remove cover.
Inside, look at the power supply board. There will be a 2200 uF capacitor, probably rated at 10V. It's about an inch long and 3/8 of an inch in diameter. If it it bulging slightly at the top, it needs to be replaced.
Take two screws off power supply board, There are also two plastic standoffs holding the board on, it's best to squeeze those with a needlenose pliers to release the board.
I replaced the cap with another 2200 uF, but rated at 16V. Now the player works again.
Jun 24, 2009 | Cyberhome CH-DVD 300 DVD Player
2000 Mercury cougar V6 Headlights and instrument light don't work
take a 12 volt test light and test out your headlight switch because that could be bad
Jan 14, 2009 | 2000 Mercury Cougar
Signal light stays on, no sound output
T14 is part of the +15v power supply that feeds the input board.
It is actually a transistor.
If this is the only problem on the board, then this transistor could be resoldered back on but you will have to make sure it tests OK and it attaches to the heatsink the same way it came off. ie make sure it is electrically isolated from the heatsink
It seems if there is no fuses blown on the power amp board you might be one of the lucky ones.
In my opinion this amp is a clever design but is under-engineered for robustness
Aug 09, 2008 | Mackie SWA1501 Subwoofer
Mackie SWA1501 Subwoofer Logo
390 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Shehu Pro
Shehu Pro
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
