Question about Dell Dimension 8300 PC Desktop
Need a 1394 PCI Firewire card for Dell Deminion 8300run.XP-SP3
Can't get my Dell 8300 to recognize my firewire card-Adaptec 4300 Firewire card. I am running Win XP and Service Pk 3.It is installed but will not recognize the firewire can someone recommend a compatabile one to use in my Dell 8300 that will work?? Is there any other than "DELL's" on the market?
  • Anonymous May 06, 2009
    After installing SP3 my firewire card stopped working even though it is still showing in windows XP system devices. So must be a problem with SP3
    My PC is not Dell
    President:
  • Dell Master
  • 1,314 Answers
Sure....this will work for you.
Thanks and please take a moment to give this solution a rating of fixya. Thanks! :c)
Posted on Feb 13, 2009
Will it support a IEEE 1394 firewire card?
Yes, it can, but it needs to be a low-profile PCI board. Here is a link to a site that can sell you one. There are other sites as well.
low profile firewire card Newegg com
Sep 19, 2015 | Dell OptiPlex GX620 PC Desktop
I have a acer aspire, ,what kind of pci card do i need so i can have a firewire port ieee 1394
Hi John,
The Acer Aspire 3502WLCi does not has the ability to use any PCI which can be compatible with Firewire IEEE 1394.
The model was designed not to support such type.
Regards,
Suhail
May 22, 2012 | Acer Aspire 3502WLCi Notebook
Windows won't recognize my sony dcr-trv19
Need a 1394 firewire port and suitable software like Corel Videostudio. Then no problems. When no 1394 port thoes pci cards come cheap, $15 or so. Video studio retails about $100 I think, you can download a free limited 30 day trial from Corel. Please uninstaal that demo after 30 days with the same install programm otherwise deep ****.
Jun 05, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Firewire port missing
You can add a PCI Firewire card to your computer if you have an empty slot.
May 22, 2009 | Dell Dimension 3000 PC Desktop
Dell Optiplex GX620 will not recognize firewire controller card
1394 drivers should be native to XP, you may be able to correct this by running an SFC scan
Take out the IEEE1394 card
Insert your Windows CD (if you do not have it order a backup from dell)
Exit out of 'install screen'
click Start
click Run
type 'sfc /scannow'
press enter
you should see a progress bar, when finished restart the computer
this compared critical windows files on harddrive vs CD, and replaces missing and corrupt files
Feb 03, 2009 | Dell 2-Port IEEE 1394 FireWire CardBus PC...
1394 Header pin-out
http://ritmotech.com.au/onlineshop/product_info.php?cPath=21_25&products_id=57&osCsid=aeefcbb79e7dab18e3439d5d6c64cb0f
Ritmo PCI to USB + 1394 (CC-C15)
PPA USB2.0 + 1394 Combo PCI Card Model 1509
http://www.ppa-usa.com/products/usb/usb_pci/1578.htm
click on get pinouts for pdf file of card
Pinouts:
USB board is slikscreened with numbers but for reference
pin 1 ground is at top edge of board
and pin 5 plus 5v is towards gold connector edge
1. case Gnd (thick black)
2. D- (green)
3. D+ (white)
4. no connection
5. +5v (red)
Firewire: (8 pin header on board)
this board uses the 4pin firewire connection standard
NOT THE 6/9 PIN!!!! you only need to connect 4 pins
and if you have a thick case ground cable you can use it
pin 7 is towards bracket towards top edge of card
pin 8 is towards bracked towards gold edge connector
card header
5 TPB- Orange
6 TPB+ Blue
7 TPA- Red
8 TPB+ Green
3 Case Gnd Thick Black (not thin black) if you have one
(white 30vdc) and (thin black, signal Gnd)
wires are not used
pins 1 and 2 are also unused for firewire connections
please note that this card has +12v on pin 2 instead of the
30v dc that a normal firewire 6 pin connection has
Sep 01, 2008 | Televison & Video
Downlading onto Laptop
Firewire and USB are not the same things
You will need a Firewire host adapter installed in your PC - such as Q-Tec PCI card (IEEE 1394 compatible) which comes with software / drivers
Good luck
Apr 13, 2008 | Panasonic NV-DX100 Camcorder
My computer doesn't even recognize my camera
if you are using a desktop, you require a an addon card called IEEE 1394 firewire card, which you have to install it on your motherboard's PCI slot, then using the firewire cable which you get along with the card should be connected to the card and DV port of the camera, then using the MOVIE MAKER software of windows XP, you can download the video.
Aug 13, 2007 | JVC GR-D290 Mini DV Digital Camcorder
Techgear 3-port 1394 FireWire CardBus
Jim, Have you run the add hardware wizard? Are your pcmcia card slots enabled? If not in Control Panel then in the BIOS? Good Luck, Tim
Feb 06, 2007 | A D S GBR-101 (GBR101) Serial Adapter
Cannot retrieve video from miniDV camcorder using Adaptec Fireconnect 8300 firewire card on Windows XP Home SP2
I have found you a Manual if that is of any help? www.adaptec.com/en-US/support/firewire/FireConnect/AFW-8300/_docs/afw8300_ug_pdf.htm All I can think of is a faulty cable? Also sometime just changing the PCI slot will help?
Dec 25, 2006 | Adaptec FireConnect 8300 (2065200) Serial...
Dell Dimension 8300 PC Desktop Logo
220 people viewed this question
Alun Cox
