Question about EA - Electronic Arts Command & Conquer 3: Tiberium Wars for Windows
Cannont play via network
In network it recognizes the other computer, but when starting a game it say serial already in use. In options I try to refresh NAT but it is greyed out. in the read me file it says to delete options.ini file and refresh, but i cannot locate this file. My computers are networked via cable, and can play Age of Empires networked perfectly. Any ideas what im doing wrong?
  • MANISH lohan
    MANISH lohan May 11, 2010
    your net speed is very slow this game so you are not connect with via network so your not play this game with other
    Scholar:
  • 164 Answers
Try using your search option in startup and type in the file name and that will locate it for you.
Posted on Feb 19, 2009
No internet or lan lights on? Tried reset, hard reset. All other lights, power, wireless, router are on and green. No lights on internet and lan connection. I have tried another wireless router and have no...
The LAN lights will only turn on once you have an Ethernet cable connected to it and the other end of the cable is connected to a working computer.
If you already have a computer connected to the Ethernet port of the router via an Ethernet cable and the lights are still off. Check if the computer you have connected recognizes a network via LAN.
If the lights on the router are still off and the computer doesn't recognize a network then that means that the port for the ethernet of your Router is bad and sadly there's no way of getting that fixed but to have the router replaced.
Otherwise if the lights are off and the computer recognizes the Network and lets you connect to the internet or other computers on the same network then its just the LED of the LAN light that's broken and I think you can live with that.
Hope this helps!
Jul 18, 2011 | Buffalo Technology AirStation Nfiniti...
Tip
The "Bubble Breaker" Get on the iPod Touch
<p>The iPod Touch, a portable media device, Apple has a 3.5 inch screen touch screen, making it suitable to play games like Bubble Breaker. Bubble Breaker is a game you play by choosing the same color bubbles and playing to make them explode, earning a higher score more bubbles you burst at once. The iPod Touch connects to the Internet via Wi-Fi, so you can easily access the App Store to download Bubble Breaker on the device. <br /> <p><br /> <p>1. Press the "Home" button, located below the iPod Touch. <br /> <p><br /> <p>2. Tap Settings, then "Wi-Fi and tap the" Wi-Fi "option set to" On. "Touch the" Ask to Join Networks "to" On. "Go to a place where you are within range of a hotspot Wi-Fi as a home or a corporate computer network or a public library. The iPod Touch will automatically try and connect to WiFi networks <br /> <p><br /> <p>3. Enter a password for the Wi-Fi network when prompted. <br /> <p><br /> <p>4. Press the "Home" to return home from the device. <br /> <p><br /> <p>5. Touch the "App Store" icon. Tap "Find" and type "Bubble Breaker", and then tap again on "Search". Tap "Bubble Breaker" from the search results. <br /> <p><br /> <p>6. Tap the price, next to the icon located Bubble Breaker, then "Install". Enter your Apple ID at the prompt. Bubble breaker game downloaded and installed on the home page screen iPod Touch. <br /> <p><br /> <p>7. Touch the Bubble Breaker game to start playing. <br />
on Jul 21, 2011 | Computers & Internet
Nat help
Hi jman92592,
Here are some options with that router. Some online games and videoconferencing applications are incompatible with NAT. The WGR614 router is programmed to recognize some of these applications and to work properly with them, but there are other applications that may not function well. In some cases, one local PC can run the application properly if that PC’s IP address is entered as the default in the PORTS Menu. If one local PC acts as a game or videoconferencing host, enter its IP address as the default
To set up an additional computer to play games like Half Life, KALI or Quake III:
1.Click the button of an unused port in the table.
2.Select the game again from the Service Name list.
3.Change the beginning port number in the Start Port box. For these games, use the supplied number in the default listing and add +1 for each additional computer. For example, if you've already configured one computer to play Hexen II (using port 26900), the second computer's port number would be 26901, and the third computer would be 26902.
4.Type the same port number in the End Port box that you typed in the Start Port box.
5.Type the IP address of the additional computer in the Server IP Address box.
6.Click Apply
The WAN Setup options let you configure a DMZ server, change the MTU size and enable the router to respond to a Ping on the WAN port.
Connect Automatically, as Required
  • Normally, this option should be Enabled, so that an Internet connection will be made automatically, whenever Internet-bound traffic is detected. In locations where Internet access is billed by the minute, if this causes high connection costs, you can disable this setting.
  • If disabled, you must connect manually, using the sub-screen accessed from the Router Status menu "Show WAN Status" screen.
•Disable SPI Firewall
  • Normally, this option should be Enabled, so that your local network will be protected by the Stateful Packet Inspection (SPI) firewall included in the WGR614. However, certain communications functions like VPN may require turning off the SPI feature.
Setting Up a Default DMZ Server
  • The default DMZ server feature is helpful when using some online games and videoconferencing applications that are incompatible with NAT. The router is programmed to recognize some of these applications and to work properly with them, but there are other applications that may not function well. In some cases, one local PC can run the application properly if that PC’s IP address is entered as the default DMZ server.
Note: DMZ servers pose a security risk. A computer designated as the default DMZ server loses much of the protection of the firewall, and is exposed to exploits from the Internet. If compromised, the DMZ server can be used to attack your network.
The WAN Setup menu, shown below lets you configure a Default DMZ Server.
  • To assign a computer or server to be a Default DMZ server, follow these steps:
1.Click WAN Setup link on the Advanced section of the main menu.
2.Type the IP address for that server. To remove the default DMZ server, replace the IP address numbers with all zeros.
3.Click Apply.
Good Luck and don't forget to leave a rating.
Thanks Mark
Apr 23, 2009 | NetGear WGR614 Wireless Router
D-link DGL-3420 wont work with Xbox 360 and Airport Extreme
For gaming it is best to use WEP personal, if you are try connecting with a computer. A linksys or cisco router is ideal.
Mar 14, 2009 | D-Link DGL-3420 Wireless Adapter
Computer does not recognize coby mp705
remove the device, swear a few times, promise your son you'll buy him a proper ipod, then give it to the dog to play with.
Dec 25, 2008 | Coby MP-C7085 MP3 Player
Cannot get my USB wireless-G adapter to work
hi mark, if the wieless G is already installed don install the linksys cd,  in ur working computer go to the lynksis page and set the wireless to manual and to channel 9 then in the non working computer  open the wireless g utility and look for options such as let this tool mange wireless if ticked uncheck it, or let windows manage wireless check the option close that box then start-control panel-network connection-wireless network connection-right click on it -view avail wireless networks and slect ur network and click to connect enter the wireless key and u will be connected to internet
Oct 31, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Psp protable
Have you tried looking at the options on the start of the game? Usually there is an option there that says "control" or "control configuration" or somethin' like that...i believe most of the games have that at the options or settings at the start of the game or when in-game (meaning when you are already playing the game) press either select or start button, then there are options there...or if there aren't, try downloading a walkthrough of the game fromthe internet...most walkthroughs should have maps for the controls of the game you wish to play...
Jul 26, 2008 | Sony PlayStation Portable (PSP) Console
Psp wont load any games or do anything bdoes come on to menu
Simply dead laser , search on ebay for the part and look for guides on google or service it to sony
Dec 06, 2007 | Sony PlayStation Portable (PSP) Console
Samsung SGH-J600
There are a few specific steps you need to follow. 1) Download this - http://malschaun.at.interims.de/Uploader 2) Set up a new network connection. Right-click, properties, on My Network Places. Choose 'Create New Connection'. Choose 'Set up Advanced Connection'. Choose 'Connect Directly to Another Computer'. Choose 'Host'. Select the Com port that your bluetooth dongle is on. Select the User Permissions. Click Finish. You'll see you have a new 'Incoming connection'. Right-click, properties. Make sure the correct Com port is selected on the General Tab. Make sure you check 'Always allow directly connected devices....without providing a password' 2) Make sure you've paired your phone (right-click option on your phone in entire bluetooth network). It might be necessary to unpair and repair after you've created the incoming connecttion. 3) Connect your phone via serial connection (also right-click menu) 4) Type #*536963# into your phone. This will enable the Serial Java download. 5) Type #*5737425# into your phone. Choose option 1 (PPP UP), then Bluetooth. Only do this once, or your phone will reset. 6) Start up the Uploader program. Select the .jad file of the game you want to upload. 7) Select option 2 on the #*5737425# menu on your phone. This should start the upload, hopefully. It can be quite intermittent, so you'll need to play around with all these steps. The order is quite important. i.e. select PPP UP before you start up the Uploader program. remember to wait after selecting the "ppp up" as it does take some time or phone will sound like its been shot and then reset... as to where you can get games from.... http://315.fiberworld.nl/d500/games.html go nuts bro!!!
Sep 30, 2007 | Samsung SGH-E900 Cellular Phone
EA - Electronic Arts Command & Conquer 3: Tiberium Wars for Windows Logo
488 people viewed this question
Top EA - Electronic Arts Video Game Consoles & Games Experts
James Wishart
 Shayaan Tanwir
Shayaan Tanwir
Person On the...
Level 1 Expert
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
