Question about Logitech Webcam
Mic on msn wont work
Old msn was fine downloaded new now mic wont work
  • jefflaura Feb 15, 2009
    still no mic
    Thats all I changed Can a mic quit working? Should i just add an external mic?
    Genius:
  • Logitech Master
  • 1,102 Answers
Your cam and mic need to set up with the msn
After you start Windows Live Messenger,
expand the view by clicking on the square
on top left next to the red X.
Then on the Windows Live messenger window on the
right side, click on “ “Show Menus.” And then click
on “Show the Menu Bar”.
Next go to the Menu Bar on right side, click on Action.
Go to “TOOLS” and click “Audio and Video Setting
and follow the instructions.
please let me know if this has solved and don't forget to rate
Posted on Feb 15, 2009
  • DEKR
    DEKR Feb 15, 2009
    have you changed anything else besides msn
    have you checked control panel and audio make sure default settings are correct
    also make sure mic is not muted
  • DEKR
    DEKR Feb 15, 2009
    yes a mic can stop working
    in control panel audio devices
    under audio check to see if
    your devices under default are set correctly.
    do you know what audio driver you have
My mic wont work when i do a videocall on msn Live 2011
Does not make any sense to me sorry. Maybe someone can figure this out? MSN is quirky anyway I never use those myself. John
Apr 19, 2012 | Computers & Internet
Well i dont have a webcam on my laptop so i plugged this in, but it wont let me use it.
In the webcam world things are not quite that easy - you need to download drivers (software to make hardware work) and then configure the webcam to any chat program you want to use it in
1) download the driver from here
http://www.bioticaindia.com/pdc-301.html
An example of setting up a cam in msn
Set your webcam mic (if it has one as default)
Vista - If you have an earlier OS, you may have to access your hardware from the Control Panel.
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
If it fails to work here concentrate on your webcam drivers and software before moving forward.
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Aug 06, 2010 | Polaroid PDC 301 Webcam
Mic not working with msn
Start > Control Panel > Classic view > Speech recognition options - run through set up.
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} TEST SPEAKERS Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC Click "Recording" tab. Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK Click "Levels" tab and set slider to 80% ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays Not working ?
Expand 'Imaging' folder in Device Manager and right click on your webcam text - Update driver software from internet
Failing this, uninstall current webcam software and download from here
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
WLM (MSN)
Open WLM > Show menu > audio and video setup > set mic as default and test > Next - set webcam as default > Finish
Sep 13, 2009 | Logitech QuickCam Pro 5000 Webcam
I can see and hear my contact but they cannot hear me I have tested all the audio and microphone tests and they check out fine
MIC SET-UP :- VISTA
TEST SPEAKERS
SET MIC DEFAULT & TEST
Re-start Computer.
CONFIGURE TO MSN
Re-boot the webcam by unplugging and plugging it back in again - Its always good practice to do this before you open MSN. If you have been using your webcam in another program, it can remain hooked up to the old program and you will get an error message " Unable to find webcam or being used elsewhere"
Webcam Connected
Open MSN
Click ( > ) Open Menu >Tools > Audio & Video set-up > Set mic as default and run through audio set-up > Next > set webcam as default and adjust Webcam Settings > Finish
Aug 13, 2009 | Microsoft LifeCam VX-3000 Web Camera
Msn problems with my notebook Toshiba
I to use a notebook (Acer Aspire one) and MSN wont run at all on this but there is a free download called Amsn which is almost identicle to msn you can use mics and web cams etc and all the smileys and you connect using your msn account
Mar 22, 2009 | Toshiba Satellite A135-S4527 Notebook
Logitech headphones not working with MSN
The internet bandwidth or speed is too low or being occupied by some other programs.Thereby leaving a low speed for the msn to work.The solution would be close some applications using internet or reinstall the msn messenger.
Jan 19, 2009 | Logitech 250 Headset
When i am on msn and want to put on webcam a message appears in a conversation saying Messenger is not available right now. Please try again later. (0x8ac70202)
This might be a compatibility problem between your webcam drivers with the new Windows Live Messenger program. You may want to:
1. Update your webcam drivers and see if Windows Live Messenger can detect it when you run the Audio Video setup from its Tools menu.
2. Or you can downgrade back to the older version of Windows Live Messenger which is compatible for your camera. Doing this however also requires that you uninstall all the Windows Live Beta products from your computer.
Note: You will not see a separate Windows Live Messenger on your Add/Remove programs, instead you will either see there Windows Live Beta products or Windows Live Essentials.
You can download the older versions of Windows Live Messenger from:
Windows Live Messenger 8.1:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
Windows Live Messenger 8.5:
http://www.microsoft.com/downloads/details.aspx?FamilyID=7a1aae73-48cc-4f7a-b445-0487bd5e84ef&displaylang=en
~ Carlos
Nov 10, 2008 | Computers & Internet
No sound
You will have to set the logitech webcam up to the medium you are using yahoo...msn. This is done after the software is installed.I don't use yahoo but on msn open it up then go to tools on the msn page at the top above all your contacts.Open the tools and go to webcam setup,click on it and follow the steps.This will get the mic working.It took me awhile to realize you had to do it twice once for the software setup and again to set it up to mate to MSN.
Jul 30, 2008 | Logitech QuickCam Connect Webcam
MS VX-6000 webcam Mic / Video problems
When i try to talk to talk to anyone on msn with the VX6000 webcam they cannot hear me for screeches, echos and distorted voice, i have tried everything on support site and got nowhere. When i test in voice playback it does the same. Any help appreciated!
Oct 23, 2007 | Microsoft LifeCam VX-6000 Webcam
Help please
check the settings on your msn that the input is set to the mic and also on the sound in control panel that input is set to labte mic
Sep 30, 2007 | Labtec Webcam Pro
Logitech Webcam Logo
59 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
