Question about Panasonic Microwave Ovens
Panasonic microwave ''times out''
No matter what time is set, the microwave works for exactly 17 seconds then switches to start up mode. Always 17 seconds!
Can anyone tell me what has gone faulty? Is it economically repairable, or do I need to buy a new microwave?
  • Shelagh Howe Feb 18, 2009
    Hi artico07.
    Thanks for the advice.
    Unfortunately switching it off, leaving it, then switching it back on hasn't solved the problem - still 17 seconds then power down!
    Guess I now need to find someone who can check it and repair it.
    Are control boards expensive - I bought the combi because I didn't have an oven, now I've got a range with oven and grill so only need the microwave. If repair is too expensive I might just buy a new stand-alone microwave.
    Thanks for trying for me.
    She
    Sergeant:
    Champion:
  • 338 Answers
Sounds like the control has become corrupted. try unplugging the unit for 5 min plug it in and try it again.. if it continues to do it then the control board may need to be replaced..
Posted on Feb 14, 2009
Microwave trips and switches off within 2 seconds
We regret reading about your microwave. At this time we recommend you have the unit evaluated by an authorized service center.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-S254BF Microwave Oven
My nns262 microwave runs exactly 5 seconds then shuts off everything else is working
Possible that the protector works, there is a thermal switch which is located to prevent fire and if there is a malfunctioning of the waveguide, magnetron or the circuit it can cut off the circuit.
click this link for part location. : microwave
Feb 11, 2013 | Panasonic Microwave Ovens
Panasonic NN-F542BF 1300 watts microwave switches off after 3 seconds
It sounds like you were sold somebody else's problem, it could be a bad magnetron, cracked high voltage diode, and a shorted high voltage capacitor to name a few. I recommend a professional if you feel it is worth getting checked.
Mar 09, 2012 | Panasonic Microwave Ovens
Oven only runs for 5 seconds no matter the time programmed in. the power level can be set and it does not matter, the oven runs for 5 seconds and shuts off.
I would need your full model number to help you best, but I'm guessing that at least it's a Panasonic?
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If yours is not a Panasonic, please create a new post with your brand and model number so we can help you.
Oct 10, 2011 | Panasonic NN-H264 Microwave Oven
I have a Panasonic microwave convection that runs for 2 or 3 seconds, then cuts off. It doesn't matter what setting or length of time you program into it, it will run a couple of seconds and shut down. Is...
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Sep 08, 2010 | Panasonic NN-C994S Convection/Microwave...
How do I get my Panasonic Inverter microwave out of demo mode? I think my toddler might have hit something to put it in demo!
Hello Two options to try: a) Press the Clock / Timer button 3 times b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
This should work with all Panasonic Microwave models.
Good luck
Aug 10, 2010 | Panasonic NN-H275 Microwave Oven
Panasonic Microwave only works for 37 secs no matter what time setting
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Jan 04, 2009 | Microwave Ovens
Microwave shuts down after 5 seconds
chech the control panel and wiring and thermal sensors..
Sep 23, 2007 | Panasonic NN-H965 Microwave Oven
Microwave shuts off after 3 seconds
Although your model number doesn't seem to show up, the NNS950-series units are powered by an high-voltage inverter. And yours has failed. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Sometimes a whole new inverter is cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized appliance / microwave repair shops and ask then specifically about inverter component-level repair and simple inverter replacement costs for your exact model number.
Dec 26, 2006 | Panasonic NN-S950WA Microwave Oven
Microwave Ovens Logo
65 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
